101J
101J
    HAMMONDMANUFACTURING
    TRANSFORMER AUDIO 2500CT/600CT
101J 数据手册
10/4/22, 2:39 AM Miniature Audio Potted (101 Series) - Hammond Mfg. Quality Products. Service Excellence. Miniature Audio Potted 101 Series PC Board Mount Features Pin type, miniature size, P.C. board mount, net weight of only 0.1 oz. Rugged potted construction produces a completely sealed unit withstanding severe environmental conditions. Secondary may be used as primary and primary as secondary. Power level: Minimum frequency range: 300 Hz. to 100 Khz. +/- 0.5 db @ 100 mw Frequency range @ +10 dbm is 200 Hz. to 100 Khz. +/- 0.5 db Frequency range @ +15 dbm is 200 Hz. to 100 Khz. +/- 0.5 db Frequency range @ +20 dbm is 300 Hz. to 100 Khz. +/- 0.5 db Frequency measurements with no D.C. current saturation. See data sheets for more detailed information.     Nominal Impedance Nominal Resistance (Ohms) (Ohms) Useful Impedance Range (Ohms) Part No. Primary Secondary Primary Secondary Pri./Sec. to Pri./Sec. 101D 300 ct 600 ct 20.4 54 150/300 600/1200 101F 600 ct 600 ct 44 52 300/300 1200/1200 101H 1200 ct 600 ct 80 53 600/300 2400/1200 101J 2500 ct 600 ct 150 54 1250/300 5000/1200 101P 300 ct 50 ct 20.4 4.8 150/25 600/100 101R 600 ct 50 ct 44 4.7 300/25 1200/100 101V 2500 ct 50 ct 150.7 4.9 1250/25 5000/100 Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/audio/101 1/2 10/4/22, 2:39 AM Miniature Audio Potted (101 Series) - Hammond Mfg. https://www.hammfg.com/electronics/transformers/audio/101 2/2
很抱歉,暂时无法提供与“101J”相匹配的价格&库存,您可以联系我们找货
