10/4/22, 8:19 AM
Audio Chassis Mount (143-146 Series) - Hammond Mfg.
Quality Products. Service Excellence.
Audio Chassis Mount 143-146 Series
Features
Small, economical, open, two hole horizontal bracket mount.
Insulated, color coded flexible leads, 4" long minimum (143, 144 & 145 Series) or 3" long
minimum (146 Series).
For a similar, P.C. board mount version, refer to the 148 and 149 series.
Frequency response 150 Hz. to 15 Khz. (+/- 1 db, reference 1000 Hz.)
When operating at impedances below nominal, power capability and the frequency
spectrum are proportionately lower, conversely, at higher impedances power capability
and frequency spectrum will be proportionately higher.
Net weight: 0.5 oz. (143, 144, 146 Series) & 1.4 oz. (145 Series).
Part No.
Applicaton
143B
143D
Nominal Impedance
Primary
(Ohms)
D.C.
Primary
Secondary
(*1) ma
Input
3.2
4000
Input
200K
1000
143H
Driver
1500
D.C. Resistance
(Ohms) +/- 15%
Output
Overall Dimensions
Primary
Secondary
(mW)
A
B
C
D
Schematic
245
15
1.26
0.69
0.69
1.06
1
30
25
1.26
0.69
0.69
1.06
1
500 ct
4
111
24
30
1.26
0.69
0.69
1.06
2
143J
Driver
3000
1000 ct
2.6
265
53
30
1.26
0.69
0.69
1.06
2
143L
Driver
10000
200 ct
1.5
720
9
30
1.26
0.69
0.69
1.06
2
143N
Driver
10000
2000 ct
1.5
720
89
30
1.26
0.69
0.69
1.06
2
https://www.hammfg.com/electronics/transformers/audio/143-146
1/2
10/4/22, 8:19 AM
Part No.
Nominal Impedance
Primary
(Ohms)
D.C.
Applicaton
Primary
Secondary
143R
Driver
25000
144B
Output
200 ct
144D
Output
144F
D.C. Resistance
(Ohms) +/- 15%
(*1) ma
Primary
Secondary
600 ct
1
1890
3.2
10
10
300 ct
3.2
9
Output
500 ct
3.2
144G
Output
500 ct
144H
Output
144I
Output
144P
Output
Overall Dimensions
(mW)
A
B
C
D
Schematic
25
30
1.26
0.69
0.69
1.06
2
1.26
0.69
0.69
1.06
3
15
0.33
150
1.26
0.69
0.69
1.06
3
6
27
0.33
150
1.26
0.69
0.69
1.06
3
8
6
27
0.9
150
1.26
0.69
0.69
1.06
3
500 ct
50
6
28
7.3
150
1.26
0.69
0.69
1.06
3
600 ct
150 ct
6
45
8.2
150
1.26
0.69
0.69
1.06
4
Output
10000
3.2
5
575
0.5
50
1.26
0.69
0.69
1.06
1
144Q
Output
10000
8
5
575
0.9
50
1.26
0.69
0.69
1.06
1
144S
Output
20000
8
3.5
1240
0.9
50
1.26
0.69
0.69
1.06
1
145A
Driver
100
200 ct
45
14
19
100
1.63
0.88
0.81
1.38
2
145B
Driver-Output
600
600
18
30
38
200
1.63
0.88
0.81
1.38
1
145C
Input
50000
1500 ct
1
2400
52
50
1.63
0.88
0.81
1.38
2
145D
Input
200K
1000
0.5
3600
33
10
1.63
0.88
0.81
1.38
1
145E
Input-Output
600 ct
600 ct
5
65
83
200
1.63
0.88
0.81
1.38
4
145F
Driver
600 ct
200 ct
9
135
1.63
0.88
0.81
1.38
4
145G
Driver
2000
200 ct
12
140
9
135
1.63
0.88
0.81
1.38
2
145H
Driver
2000
500 ct
12
148
17
135
1.63
0.88
0.81
1.38
2
145J
Driver
4000
600 ct
8
340
24
135
1.63
0.88
0.81
1.38
2
145L
Driver
4000
2600 ct
8
340
100
135
1.63
0.88
0.81
1.38
2
145N
Driver
10000
2000 ct
5
700
89
135
1.63
0.88
0.81
1.38
2
145O
Driver
15000
200 ct
4
850
10
135
1.63
0.88
0.81
1.38
2
145P
Driver
20000
1000 ct
3.5
1180
50
135
1.63
0.88
0.81
1.38
2
145R
Driver
20000
2000 ct
3.5
1180
89
135
1.63
0.88
0.81
1.38
2
146B
Output
48 ct
3.2
0.3
700
1.63
0.88
0.81
1.38
3
146C
Output
48 ct
8
0.7
700
1.63
0.88
0.81
1.38
3
146D
Output
100 ct
3.2
14
4.4
0.3
700
1.63
0.88
0.81
1.38
3
146E
Output
100 ct
8
14
4.4
0.7
700
1.63
0.88
0.81
1.38
3
146F
Output
250 ct
3.2
8
11
0.3
700
1.63
0.88
0.81
1.38
3
146G
Output
250 ct
8
8
11
0.7
700
1.63
0.88
0.81
1.38
3
146H
Output
500 ct
3.2
6
26
0.3
700
1.63
0.88
0.81
1.38
3
146I
Output
500 ct
8
6
26
0.7
700
1.63
0.88
0.81
1.38
3
146J
Output
1000 ct
3.2
4
56
0.3
700
1.63
0.88
0.81
1.38
3
146K
Output
1000 ct
8
4
56
0.7
700
1.63
0.88
0.81
1.38
3
146N
Output
2000 ct
8
3
97
0.7
700
1.63
0.88
0.81
1.38
3
146S
Output
4000 ct
8
2
220
0.7
700
1.63
0.88
0.81
1.38
3
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
2/2
很抱歉,暂时无法提供与“145C”相匹配的价格&库存,您可以联系我们找货
