Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
124D
TUBE DRIVER - INTERSTAGE TRANSFORMER
This transformer operates in the 150 Hz to 15 KHz range.
Designed for general purpose or replacement use in single ended
or phase inverter tube driver circuits
Open style, 2 point mount with minimum 5” long leads
Core material Grain Oriented Silicone Steel laminations
ELECTRICAL SPECIFICATIONS
Characteristic
Input Impedance
Output Impedance
Output Power
DCR
Primary
BLU – RED
RED – BRN
Secondary
GRN – BLK
BLK – GRN
Inductance
Primary
Secondary
Typical
7,000 ΩCT
15,800 ΩCT
5.0 Watts
297 Ω
394 Ω
@ 1.0 kHz, 1.0 V OC
6.45 H
14.4 H
Leakage Inductance
0.125 H
Impedance
Primary
Secondary
@ 1.0 kHz, 1.0 V OC
40.5 KΩ
90.25 KΩ
Frequency Response
Turns ratio
±1db from 150Hz to 15Hz
1:1.49
Dielectric Strength
500 Vrms
218 Ω
236 Ω
124D
5W 150Hz - 15kHz
BRN - RED - BLU: 7000Ω CT
GRN - BLK - GRN: 15800 Ω CT
MADE IN CANADA
SCHEMATIC DIAGRAM
PRIMARY
BROWN
7000 Ω CT
RED
BLUE
SECONDARY
GREEN
15800 Ω CT
BLACK
GREEN
TYPICAL TEST CIRCUIT
PRIMARY
R S/
SECONDARY
2
RL
Measurement instruments
Hp4192a impedance analyzer
Hp3456a DVM
Keithley 2002 DVM
D scope series iii audio analyzer
R S/
OUT
2
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of
Hammond Manufacturing. Data subject to change without notice.
很抱歉,暂时无法提供与“124D”相匹配的价格&库存,您可以联系我们找货
