10/3/22, 1:31 AM
Universal Single Ended Tube Output (125SE Series) - Hammond Mfg.
Quality Products. Service Excellence.
Universal Single Ended Tube Output 125SE Series
Audio
Features
Designed for general purpose or replacement use (not Hi-Fi), in single ended, tube output
circuits.
Frequency response: 100 Hz. - 15 Khz at full rated power (+/- 1db max. - ref. 1 Khz).
For full frequency response (20 Hz. to 20 Khz.) - see our 1627-1642 Series.
For push-pull output use, see our 125 Series.
Open style with minimum 12" long primary & secondary leads.
All sizes use butt stacked cores (using 29M6 steel) with an air gap, to reduce D.C. core
saturation.
Primary impedance range from 2,500 to 10,000 Ohms.
Secondary impedance range from 4 to 32 Ohms.
Gallery
Audio Power
Max. D.C. Bias
Weight
Part No.
(Watts)
(ma)
( lbs.)
125ASE
3
25
0.5
125BSE
5
45
1.1
125CSE
8
60
125DSE
10
125ESE
15
125FSE
125GSE
Dimensions
A
B
C
Mounting Hole
D
E
G
2.81 1.35 1.69
2.38
0.19
3.25 1.63 2.00
2.81
0.19
1.3
3.69 1.86 2.31
3.13
0.19
70
2
4.00 2.10 2.63
3.56
0.19
80
3
4.50 2.36 2.94
4.00
0.19
4.5
3.76 2.52 3.15
3.13
2.25
0.20
x
0.38
25
100
6
4.15 2.88 3.46
3.45
2.50
0.20
x
0.38
Primary Winding Data
Inductance
DC Resistance
Part No.
(Minimum)
(+/- 20%)
125ESE
5.43 H
103 Ohms
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
https://www.hammfg.com/electronics/transformers/audio/125se
1/2
10/3/22, 1:31 AM
2/2
很抱歉,暂时无法提供与“125CSE”相匹配的价格&库存,您可以联系我们找货
