Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
140PEX
CHASSIS MOUNT – SHIELDED
IMPEDANCE MATCHING TRANSFORMER
This transformer operates in the 20 Hz to 20 KHz range.
The metal can provides excellent shielding from a broad
range of external sources. While the nickel core provides
high permeability combined with low losses.
Typical applications Input/output Isolation, Line Matching,
Driver, Hybrid applications.
ELECTRICAL SPECIFICATIONS
Characteristic
Input Impedance
Output Impedance
Output Power
DCR
Primary
BRN – RED
ORG - YEL
Secondary
GRN – BLU
VIO - GRY
Typical
150/600 Ω
600/2400 Ω
10.0 dbm
Inductance
Primary
Secondary
Impedance
Primary
Secondary
@ 1.0 kHz, 1.0 V OC
14.5 H
55.0 H
@ 1.0 kHz, 1.0 V OC
7.0 kΩ
26.0 kΩ
Frequency Response
Turns ratio
±1db from 20 Hz to 20KHz
1:1, 1:2, 1:4
Insertion Loss
Return Loss
Longitudinal balance
很抱歉,暂时无法提供与“140PEX”相匹配的价格&库存,您可以联系我们找货
