Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
140TEX
CHASSIS MOUNT – SHIELDED
IMPEDANCE MATCHING TRANSFORMER
This transformer operates in the 20 Hz to 20 KHz range.
The metal can provides excellent shielding from a broad
range of external sources. While the nickel core provides
high permeability combined with low losses.
Typical applications Input/output Isolation, Line Matching,
Driver, Hybrid applications.
ELECTRICAL SPECIFICATIONS
Characteristic
Input Impedance
Output Impedance
Output Power
DCR
Primary
Secondary
Inductance
Primary
Secondary
Impedance
Primary
Secondary
Typical
1,000 Ω
1,000 Ω
10.0 dbm
89.7 Ω
89.7 Ω
@ 1.0 kHz, 1.0 V OC
7.20 H
7.20 H
@ 1.0 kHz, 1.0 V OC
62.7kΩ
62.7kΩ
140TEX
5mW 20Hz - 20kHz
RED - YEL: 1000 Ω
GRN - BLU: 1000 Ω
MADE IN CANADA
DATE
SCHEMATIC DIAGRAM
PRIMARY
Frequency Response
Turns ratio
±1db from 20 Hz to 20KHz
1:1
Insertion Loss
Return Loss
Longitudinal balance
< 1.0 db
20 db
-65 db
Dielectric Strength
500 Vrms
RED
1000 Ω
YELLOW
SECONDARY
GREEN
1000 Ω
BLUE
TYPICAL TEST CIRCUIT
PRIMARY
R S/
SECONDARY
2
RL
Measurement instruments
Hp4192a impedance analyzer
Hp3456a DVM
Keithley 2002 DVM
D scope series iii audio analyzer
R S/
OUT
2
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of
Hammond Manufacturing. Data subject to change without notice.
很抱歉,暂时无法提供与“140TEX”相匹配的价格&库存,您可以联系我们找货
