1750T
1750T
    HAMMONDMANUFACTURING
    TRANSFORMER TUBE GUITAR AMP
1750T 数据手册
Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com 1750T PRIMARY TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER • • • • • • SECONDARY RED BLK COM Designed for drop in replacement of original units such as VOX1 AC30 Reissue (P-TVO30R) Constructed to look similar to original factory units (where possible). Material used & design specifications were kept as close as possible to the original part to preserve the stock "tone". Open style with minimum 21" long primary and secondary leads Frequency response 70Hz - 15KHz (0/-1dB reference @ 1KHz) Distortion is less than 1% @ 70Hz BRN 4000 CT Ohm GRN WHT BLU 8 Ohm 16 Ohm 70Hz-15kHz 30 WATT B ELECTRICAL SPECIFICATIONS Characteristics Input Impedance Output Impedance Output Power Typical 4000 Ohms 8 & 16 Ohms 30 W DCR Primary Red-Brown Primary Brown-White Secondary Black-Blue 54.00 Ohms 60.00 Ohms 0.520 Ohm Inductance Impedance Primary Red-White Secondary Black-Green Secondary Black-Blue @ 1.0 kHz, 1.0 V OC 15.2H 102K Ohm 37.45mH 336.1 Ohm 70.66mH 604.2 Ohm Leakage Inductance Primary Red-White @ 1.0 kHz, 1.0 V SC 4.61 mH Dielectric Strength Temperature Range 2000VRMS -40 to 105 degC T z 50 5kH 170Hz - 1: 4000 CT Ω 16 Ω U: 7 BL T TE DA TS WH 8 Ω AT N - RN: A D W R 30 NA - B M, G A D O C RE K: C IN DE BL MA BLU GRN C BLK RED E D A BRN G WHT NOTE: ALL LEADS 21" OUT MIN Dimensions TEST CONDITIONS Measurement instruments: D scope series iii audio analyzer Wayne Kerr 3255B with a 3265B A 3.125” ±0.063 C 3.800” ±0.063 E 2.438” ±0.063 B 3.300” ±0.125 D 2.500” ±0.063 G 0.188” X 0.406” ±0.015 TYPICAL TEST CIRCUIT PRIMARY Keithley 2010 DVM Hp4192a impedance analyzer R S/ SECONDARY 2 RL * All graphs input level 27dBu @1.0KHz reference. **The results are typical and are subject to normal manufacturing and electrical tolerances. R S/ OUT 2 1 DISCLAIMER: Hammond Mfg. is not affiliated with Fender Musical Instruments Corp., Marshall Amplification, Yorkville/Traynor, AMPEG or VOX Amplification companies. Amplifier model names are trademarks of the amplifier companies and are just listed here for reference purpose only. www.hammondmfg.com This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of Hammond Manufacturing. Data subject to change without notice. www.hammondmfg.com
1750T 价格&库存
很抱歉,暂时无法提供与“1750T”相匹配的价格&库存,您可以联系我们找货
