Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
1650WA
HI-FI AUDIO OUTPUT MULTIPLE SECONDARY TRANSFORMER
NEW & improved version of our 1608-1650 Series multiple secondary output transformers
(Re-designed secondaries for easy hook-up of secondary loads).
Designed for push-pull tube output circuits.
Units are designed to provide ample "headroom" at bass frequencies
(Note the weight of each transformer).
Enclosed (shielded), 4 slot, above chassis Type "X" mounting.
Manufactured with plastic coil forms for coil support and insulation.
Frequency response 30Hz. to 30Khz. at full rated power (+/- 1db max. - ref. 1Khz) minimum.
Insulated flexible leads 8" min.
Included 40% screen taps for Ultra-Linear operation (if desired).
Typical applications - Push-Pull: triode, Ultra-Linear pentode, pentode and tetrode connected audio output.
Suggested tube types: 6L6GC, 5881, EL34, 6550B, KT88
ELECTRICAL SPECIFICATIONS
Characteristic
Input Impedance
Output Impedance
Output Power
Typical
1900 Ohms
4, 8 & 16 Ohms
280 Watts
DCR
Primary Blue-Red
Primary Red-Brown
Secondary Black-Green
Secondary Black-Yellow
Secondary Black-White
15.65 Ohms
17.19 Ohms
0.135 Ohm
0.176 Ohm
0.203 Ohm
Inductance |
Impedance
Primary Brown-Red
@ 60Hz, 10.0V OC
156H
76KOhm
Leakage Inductance
Primary Brown-Red
@ 60Hz, 10.0V SC
3.66mH
Dielectric Strength
Temperature Range
3535VDC
-40 To 105C
1650WA
Made In Canada
DATE
Note: The above examples of possible combinations are to help you narrow down the choices of transformers for your favorite tube types. How
you operate the tubes (push-pull, push-pull parallel, ultra-linear, class, B+, bias, operating points, etc.) will change optimum plate to plate load
impedance. Only a few of the most popular tubes are shown. As more tubes become available we will add them to the list. A tube manual or tube
manufacturer's technical data sheets should be consulted first, before making a decision on a proper output transformer.
www.hammondmfg.com
DIMENSIONAL DETAILS:
YEL
GRN/YEL
BLK/YEL
GRN
BLK
BLU
BLU/YEL
RED
BRN/YEL
BRN
3.500in
±0.063
Ø0.275 x 0.615
4.375in
±0.063
7.500in
±0.125
5.875in
±0.063
5.300in
±0.063
TEST CONDITIONS
Measurement Instruments:
dScope Series III Audio Analyzer
Wayne Kerr 3255B with a 3265B Inductance Analyzer
HP 4192a LF Impedance Analyzer
Keithley 2010 DVM
* All graphs input level 27dBu @1.0KHz reference.
**The results are typical and are subject to normal manufacturing and
electrical tolerances.
TYPICAL TEST CIRCUIT
PRIMARY
R S/
SECONDARY
2
RL
R S/
OUT
2
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of
Hammond Manufacturing. Data subject to change without notice.
www.hammondmfg.com
很抱歉,暂时无法提供与“1650WA”相匹配的价格&库存,您可以联系我们找货
