KIT-CSR2010FT
KIT-CSR2010FT
    SEI
    RESISTOR KIT 0.001-0.75 525PCS
KIT-CSR2010FT 数据手册
Stackpole Electronics, Inc. Engineering Kits Resistive Product Solutions RMCF – Thick Film Chip Resistors Features: • • • • • • • 20 pieces of each standard value for sizes 0603 and larger 30 pieces of each standard value for sizes 0201 and 0402 96 values (1 decade) in each 1% tolerance kit 48 values (2 decades) in each 5% tolerance kit Packaged in cut tape RoHS compliant, REACH compliant and halogen free RMCF data specification link Kit-RMCF Description Part Number Tolerance KIT-RMCF0201FT-02 1% Number of Values 96 Quantity Per Value 30 Total Quantity 2880 KIT-RMCF0201FT-03 KIT-RMCF0201FT-04 1% 1% 96 96 30 30 2880 2880 Each E96 value from 100-976 ohm Each E96 value from 1K-9.76K ohm KIT-RMCF0201FT-05 KIT-RMCF0201FT-06 1% 1% 96 96 30 30 2880 2880 Each E96 value from 10K-97.6K ohm Each E96 value from 100K-976K ohm KIT-RMCF0402FT-02 1% 96 30 2880 Each E96 value from 10-97.6 ohm KIT-RMCF0402FT-03 KIT-RMCF0402FT-04 1% 1% 96 96 30 30 2880 2880 Each E96 value from 100-976 ohm Each E96 value from 1K-9.76K ohm KIT-RMCF0402FT-05 KIT-RMCF0402FT-06 1% 1% 96 96 30 30 2880 2880 Each E96 value from 10K-97.6K ohm Each E96 value from 100K-976K ohm KIT-RMCF0402JT-12 KIT-RMCF0402JT-13 5% 5% 48 48 30 30 1440 1440 Each E24 value from 10-910 ohm Each E24 value from 1K-91K ohm KIT-RMCF0603FT-02 KIT-RMCF0603FT-03 1% 1% 96 96 20 20 1920 1920 Each E96 value from 10-97.6 ohm Each E96 value from 100-976 ohm KIT-RMCF0603FT-04 KIT-RMCF0603FT-05 1% 1% 96 96 20 20 1920 1920 Each E96 value from 1K-9.76K ohm Each E96 value from 10K-97.6K ohm KIT-RMCF0603FT-06 KIT-RMCF0603JT-12 1% 5% 96 48 20 20 1920 960 Each E96 value from 100K-976K ohm Each E24 value from 10-910 ohm KIT-RMCF0603JT-13 KIT-RMCF0603JT-14 5% 5% 48 48 20 20 960 960 KIT-RMCF0805FT-02 1% 96 20 1920 Each E96 value from 10-97.6 ohm KIT-RMCF0805FT-03 KIT-RMCF0805FT-04 1% 1% 96 96 20 20 1920 1920 Each E96 value from 100-976 ohm Each E96 value from 1K-9.76K ohm KIT-RMCF0805FT-05 KIT-RMCF0805FT-06 1% 1% 96 96 20 20 1920 1920 Each E96 value from 10K-97.6K ohm Each E96 value from 100K-976K ohm KIT-RMCF0805JT-12 KIT-RMCF0805JT-13 5% 5% 48 48 20 20 960 960 KIT-RMCF0805JT-14 KIT-RMCF1206FT-02 5% 1% 48 96 20 20 960 1920 Each E24 value from 100K-10M ohm (excluding 9.1M) Each E96 value from 10-97.6 ohm KIT-RMCF1206FT-03 KIT-RMCF1206FT-04 1% 1% 96 96 20 20 1920 1920 Each E96 value from 100-976 ohm Each E96 value from 1K-9.76K ohm KIT-RMCF1206FT-05 1% 96 20 1920 Each E96 value from 10K-97.6K ohm KIT-RMCF1206FT-06 1% 96 20 1920 Each E96 value from 100K-976K ohm KIT-RMCF1206JT-12 KIT-RMCF1206JT-13 5% 5% 48 48 20 20 960 960 Each E24 value from 10-910 ohm Each E24 value from 1K-91K ohm KIT-RMCF1206JT-14 5% 48 20 960 Each E24 value from 100K-10M ohm (excluding 9.1M) Rev Date: 12/17/2018 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 Included Values Each E96 value from 10-97.6 ohm Each E24 value from 1K-91K ohm Each E24 value from 100K-10M ohm (excluding 9.1M) Each E24 value from 10-910 ohm Each E24 value from 1K-91K ohm www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. Engineering Kits Resistive Product Solutions CSR, CSRN, CSRF, CSNL – Current Sensing Resistors Features: • • • • • • • • For 1206 size, 25 pieces each of 21 common resistance values For 2010 size, 25 pieces each of 21 common resistance values For 2512 size, 25 pieces each of 27 common resistance values Packaged in cut tape RoHS compliant, REACH compliant and halogen free CSR/CSRN data specification link CSRF data specification link CSNL data specification link Kit-CSR Description Part Number KIT-CSR1206FT KIT-CSR2010FT KIT-CSR2512FT Size 1206 2010 2512 Tolerance 1% 1% 1% Number of Values 21 21 27 Qty per Value 25 25 25 Total Qty 525 525 675 Kit-CSR Included Values KIT-CSR1206FT CSNL1206FT1L00 CSNL1206FT2L00 CSNL1206FT3L00 CSRF1206FT5L00 CSRF1206FT10L0 CSR1206FK10L0 CSR1206FK12L0 CSR1206FK15L0 CSR1206FK20L0 CSR1206FK25L0 CSR1206FK30L0 CSR1206FK50L0 CSR1206FK75L0 CSR1206FKR100 CSR1206FKR150 CSR1206FKR200 CSR1206FKR250 CSR1206FKR300 CSR1206FKR500 CSR1206FKR750 CSR1206FK1R00 Rev Date: 12/17/2018 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. KIT-CSR2010FT CSNL2010FT1L00 CSNL2010FT2L00 CSNL2010FT3L00 CSNL2010FT5L00 CSRN2010FK10L0 CSRN2010FK15L0 CSRN2010FK20L0 CSRN2010FK25L0 CSRN2010FK30L0 CSRN2010FK40L0 CSRN2010FK50L0 CSRN2010FK60L0 CSRN2010FK75L0 CSRN2010FKR100 CSRN2010FKR150 CSRN2010FKR200 CSRN2010FKR250 CSRN2010FKR300 CSRN2010FKR400 CSRN2010FKR500 CSRN2010FKR750 2 KIT-CSR2512FT CSNL2512FTL500 CSNL2512FT1L00 CSNL2512FT2L00 CSNL2512FT3L00 CSRF2512FT5L00 CSNL2512FT7L00 CSRF2512FT10L0 CSRN2512FK10L0 CSRN2512FK15L0 CSRN2512FK20L0 CSRN2512FK25L0 CSRN2512FK30L0 CSRN2512FK40L0 CSRN2512FK50L0 CSRN2512FK68L0 CSRN2512FK75L0 CSRN2512FKR100 CSRN2512FKR150 CSRN2512FKR200 CSRN2512FKR250 CSRN2512FKR300 CSRN2512FKR330 CSRN2512FKR400 CSRN2512FKR470 CSRN2512FKR500 CSRN2512FKR680 CSRN2512FKR750 www.seielect.com marketing@seielect.com Stackpole Electronics, Inc. Engineering Kits Resistive Product Solutions RNCS – Moisture Resistant Precision Thin Film Chip Resistors Features: • • • • • For 0603 size, 20 pieces each of 45 common resistance values For 0805 size, 20 pieces each of 47 common resistance values Packaged in cut tape RoHS compliant, REACH compliant and halogen free RNCS data specification link Kit-RNCS Description Part Number KIT-RNCS0603BKE KIT-RNCS0805BKE Size 0603 0805 Tolerance 0.1% 0.1% TCR (ppm/ºC) 25 25 Number of Values 45 47 Qty per Value 20 20 Total Qty 900 940 Kit-RNCS Included Values KIT-RNCS0603BKE RNCS0603BKE49R9 RNCS0603BKE4K99 RNCS0603BKE75R0 RNCS0603BKE6K81 RNCS0603BKE100R RNCS0603BKE7K50 RNCS0603BKE121R RNCS0603BKE8K25 RNCS0603BKE150R RNCS0603BKE10K0 RNCS0603BKE200R RNCS0603BKE12K1 RNCS0603BKE221R RNCS0603BKE15K0 RNCS0603BKE249R RNCS0603BKE20K0 RNCS0603BKE301R RNCS0603BKE22K1 RNCS0603BKE332R RNCS0603BKE24K9 RNCS0603BKE475R RNCS0603BKE27K4 RNCS0603BKE499R RNCS0603BKE30K1 RNCS0603BKE681R RNCS0603BKE33K2 RNCS0603BKE750R RNCS0603BKE47K5 RNCS0603BKE825R RNCS0603BKE49K9 RNCS0603BKE1K00 RNCS0603BKE68K1 RNCS0603BKE1K50 RNCS0603BKE75K0 RNCS0603BKE2K00 RNCS0603BKE100K RNCS0603BKE2K21 RNCS0603BKE150K RNCS0603BKE2K49 RNCS0603BKE200K RNCS0603BKE2K74 RNCS0603BKE249K RNCS0603BKE3K01 RNCS0603BKE3K32 RNCS0603BKE4K75 Rev Date: 12/17/2018 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 KIT-RNCS0805BKE RNCS0805BKE10R0 RNCS0805BKE4K75 RNCS0805BKE49R9 RNCS0805BKE4K99 RNCS0805BKE75R0 RNCS0805BKE6K81 RNCS0805BKE100R RNCS0805BKE7K50 RNCS0805BKE121R RNCS0805BKE8K25 RNCS0805BKE150R RNCS0805BKE10K0 RNCS0805BKE200R RNCS0805BKE12K1 RNCS0805BKE221R RNCS0805BKE15K0 RNCS0805BKE249R RNCS0805BKE20K0 RNCS0805BKE301R RNCS0805BKE22K1 RNCS0805BKE332R RNCS0805BKE24K9 RNCS0805BKE475R RNCS0805BKE27K4 RNCS0805BKE499R RNCS0805BKE30K1 RNCS0805BKE681R RNCS0805BKE33K2 RNCS0805BKE750R RNCS0805BKE47K5 RNCS0805BKE825R RNCS0805BKE49K9 RNCS0805BKE1K50 RNCS0805BKE68K1 RNCS0805BKE1K00 RNCS0805BKE75K0 RNCS0805BKE2K00 RNCS0805BKE100K RNCS0805BKE2K21 RNCS0805BKE150K RNCS0805BKE2K49 RNCS0805BKE200K RNCS0805BKE2K74 RNCS0805BKE249K RNCS0805BKE3K01 RNCS0805BKE499K RNCS0805BKE3K32 www.seielect.com marketing@seielect.com
KIT-CSR2010FT 价格&库存
很抱歉,暂时无法提供与“KIT-CSR2010FT”相匹配的价格&库存,您可以联系我们找货
