2102
    ADAFRUIT
    LAMP INCAND 5MM WIRE TERM 18V
2102 数据手册
IDC Breakout Helper - 2x5 (10 pin) PRODUCT ID: 2102  Description This little 2x5 (10 pin - 0.1 spaced) IDC Breadboard Helper is great in conjunction with any of our 10pin IDC cables. It comes in two parts, a 'pin-through' socket and a male header. The socket straddles the center of a breadboard or Perma-Proto and then header plugs into the top of the socket. Since IDC cables are so standard, but a royal pain to use with breadboards, this is a good and cheap hack for prototyping. Works best when soldered in place. We have used these to prototype on a solderless breadboard but some customers report their breadboards don't play nice with the shorter pins so your mileage may vary Each order comes with one socket and one header. Breadboard, Perma Proto and IDC cable not included! We also have helpers for: o o o o o 2x20 Pins 2x16 Pins 2x13 Pins 2x8 Pins 2x3 Pins  Technical Details o o o o Dimensions (assembled): 13mm x 8mm x 16.5mm / 0.5" x 0.3" x 0.65" Dimensions (header): 12.5mm x 5mm x 12mm / 0.5" x 0.2" x 0.5" Dimensions (socket): 13mm x 8mm x 8mm / 0.5" x 0.3" x 0.3" Weight (assembled): 1g        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“2102”相匹配的价格&库存,您可以联系我们找货
