APHA008GAK0EG-3TM
APHA008GAK0EG-3TM
    APACERMEMORYAMERICA(宇瞻科技)
    USBFLASH
APHA008GAK0EG-3TM 数据手册
RoHS Compliant USB Flash Drive EH353 Product Specifications (Toshiba 15nm) March 31, 2016 Version 1.6 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 USB Disk Module APHAxxxXAX0XG-XTX FEATURES: x x USB3.0 Super Speed compatible, and backward compatible with USB2.0 & USB1.1 interfaces – USB3.0 max. transfer rate: 5.0 Gbps – Backward compatible with 480Mbps & 12 Mbps x Capacity – SLC: 256, 512 MB 1, 2, 4, 8, 16, 32 GB – MLC: 8, 16, 32, 64, 128 GB x Performance* SLC – Sustained read: up to 80 MB/s – Sustained write: up to 70 MB/s MLC – Sustained read: up to 205 MB/s – Sustained write: up to 95 MB/s x – – – – Temperature Range Operating: Standard: 0°C to 70°C Extended: -40°C to 85°C – Storage: -40°C to 85°C – x Power Consumption* – Operating voltage: 5V SLC – Active mode: 225 mA – Idle mode: 65 mA MLC – Active mode: 275 mA – Idle mode: 80 mA x – – – Flash Management Flash bad-block management Built-in hardware ECC Power saving implemented Wear-leveling algorithms OS Support Windows: WinXP/7 or later Mac: 10.2.8 or later Linux: 2.4.10 or later x RoHS Compliant x USB Bus-Powered Capability x NAND Flash Type: SLC/MLC x Dimensions: 59.0 x 18.4 x 9.1, unit: ᓔ *Varies from capacities. Performance and power consumption addressed here are typical and may vary from configurations and platforms. 1 ©2016 Apacer Technology, Inc. Rev. 1.6 USB Disk Module APHAxxxXAX0XG-XTX Table of Contents 1. General Description............................................................. 3 1.1 Performance-Optimized USB Controller ............................................................................................. 3 1.1.1 Power Saving Implemented .......................................................................................................... 3 1.1.2 Program RAM Architect ................................................................................................................ 3 1.1.3 Error Correction Code (ECC) ........................................................................................................ 3 1.1.4 Flash Block Management ............................................................................................................. 3 1.1.5 Wear-Leveling Algorithms ............................................................................................................. 3 2. General Specifications ........................................................ 4 2.1 SLC ...................................................................................................................................................... 4 2.2 MLC ..................................................................................................................................................... 4 3. Absolute Maximum Rating .................................................. 5 4. Physical Dimensions ........................................................... 6 5. Product Ordering Information ............................................. 7 5.1 Product Code Designations ................................................................................................................. 7 5.2 Valid Combinations .............................................................................................................................. 8 2 ©2016 Apacer Technology, Inc. Rev. 1.6 USB Disk Module APHAxxxXAX0XG-XTX 1. General Description Apacer USB3.0 Handy FLASH Drive EH353 is a ultra high-performance flash disk drive designed offering portable storage solutions or external memory expansion. This new generation USB flash drive is compatible with the latest USB specification – USB3.0 Super Speed, with a maximum transfer rate of 5.0 Gbps. The connector is backward employable with USB2.0 and USB1.1 interfaces as well. With compliance with USB3.0 specification, this USB drive can deliver up to 205 MB/s outstanding performance. Reliability wise, the USB comes with various implementations including powerful hardware ECC engine, power saving modes, wear leveling and flash block management. This product is well suited for portable flash storage applications while operating at minimal power consumption. 1.1 Performance-Optimized USB Controller 1.1.1 Power Saving Implemented The internal controller of the USB model is designed with power saving implementations, allowing the device to operate at low power consumption. 1.1.2 Program RAM Architect The internal Program RAM implementation allows the host to upgrade firmware codes anytime when needed. 1.1.3 Error Correction Code (ECC) The UFD utilizes 1-bit Error Detection Code (EDC) and Error Correction Code (ECC). 1.1.4 Flash Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. When host performs program/erase command on a block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC and block mapping technique to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 1.1.5 Wear-Leveling Algorithms Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Wear leveling is an important mechanism that level out the wearing of blocks so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of flash drives. Commonly used wear leveling types are Static and Dynamic. 3 ©2016 Apacer Technology, Inc. Rev. 1.6 USB Disk Module APHAxxxXAX0XG-XTX 2. General Specifications 2.1 SLC Interface Super-speed USB3.0 compliant; backward compatible with USB2.0 and USB1.1 Performance* (MB/s) Read Write Temperature -40°C to 85°C Power consumption* Active: 225 mA Idle: 65 mA MTBF 1,000,000 hours 256MB 512MB 1GB 2GB 4GB 8GB 16GB 32GB 60 10 60 21 65 40 65 40 65 50 80 65 80 70 80 70 *Results may vary from flash configurations or host system settings. 2.2 MLC Interface Super-speed USB3.0 compliant; backward compatible with USB2.0 and USB1.1 Performance* Read Write -40°C to 85°C Temperature Power consumption* MTBF Active Idle 8GB 16GB 32GB 64GB 128GB 205 20 190 55 190 45 185 95 190 95 8GB 165 75 16GB 270 85 32GB 265 80 64GB 275 80 128GB 265 55 1,000,000 hours *Results may vary from flash configurations or host system settings. 4 ©2016 Apacer Technology, Inc. Rev. 1.6 USB Disk Module APHAxxxXAX0XG-XTX 3. Absolute Maximum Rating Caution: Absolute Maximum Stress Ratings – Applied conditions greater than those listed under “Absolute Maximum Stress Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these conditions or conditions greater than those defined in the operational sections of this data sheet is not implied. Exposure to absolute maximum stress rating conditions may affect device reliability. Table 3-1 Absolute Stress Rating Parameters Conditions Required power supply 4.5-5.5V Operating temperature 0ഒ to 70ഒ (Standard) -40°C to 85°C (Extended) Storage temperature -40ഒ to 85ഒ 5 ©2016 Apacer Technology, Inc. Rev. 1.6 USB Disk Module APHAxxxXAX0XG-XTX 4. Physical Dimensions Unit: mm 6 ©2016 Apacer Technology, Inc. Rev. 1.6 USB Disk Module APHAxxxXAX0XG-XTX 5. Product Ordering Information 5.1 Product Code Designations AP HA xxxX A X 0 X G – X TX Flash Type T: Toshiba SLC TM: Toshiba MLC Version Control G: RoHS Compliant Temperature C: Commercial Temperature E: Extended Temperature PCB version Model Name G = EH353 Orange Housing K = EH353 Black Housing Solution Version Capacity 256M = 256MB 512M = 512MB 001G = 1GB 002G = 2GB 004G = 4GB 008G = 8GB 016G = 16GB 032G = 32GB 064G = 64GB 128G = 128GB USB Flash Drive Apacer Product Code 7 ©2016 Apacer Technology, Inc. Rev. 1.6 USB Disk Module APHAxxxXAX0XG-XTX 5.2 Valid Combinations 5.2.1 EH353 (SLC) z z Orange Housing Capacity Standard Extended 256MB 512MB APHA256MAG0CG-2T APHA512MAG0CG-2T APHA256MAG0EG-2T APHA512MAG0EG-2T 1GB 2GB APHA001GAG0CG-2T APHA002GAG0CG-2T APHA001GAG0EG-2T APHA002GAG0EG-2T 4GB 8GB 16GB 32GB APHA004GAG0CG-2T APHA008GAG0CG-2T APHA016GAG0CG-2T APHA032GAG0CG-2T APHA004GAG0EG-2T APHA008GAG0EG-2T APHA016GAG0EG-2T APHA032GAG0EG-2T Capacity Standard Extended 256MB 512MB 1GB 2GB 4GB 8GB 16GB 32GB APHA256MAK0CG-2T APHA512MAK0CG-2T APHA001GAK0CG-2T APHA002GAK0CG-2T APHA004GAK0CG-2T APHA008GAK0CG-2T APHA016GAK0CG-2T APHA032GAK0CG-2T APHA256MAK0EG-2T APHA512MAK0EG-2T APHA001GAK0EG-2T APHA002GAK0EG-2T APHA004GAK0EG-2T APHA008GAK0EG-2T APHA016GAK0EG-2T APHA032GAK0EG-2T Black Housing 8 ©2016 Apacer Technology, Inc. Rev. 1.6 USB Disk Module APHAxxxXAX0XG-XTX 5.2.2 EH353 (MLC) z z Orange Housing Capacity Standard Extended 8GB 16GB APHA008GAG0CG-3TM APHA016GAG0CG-3TM APHA008GAG0EG-3TM APHA016GAG0EG-3TM 32GB 64GB APHA032GAG0CG-3TM APHA064GAG0CG-3TM APHA032GAG0EG-3TM APHA064GAG0EG-3TM 128GB APHA128GAG0CG-3TM APHA128GAG0EG-3TM Capacity Standard Extended 8GB 16GB 32GB 64GB 128GB APHA008GAK0CG-3TM APHA016GAK0CG-3TM APHA032GAK0CG-3TM APHA064GAK0CG-3TM APHA128GAK0CG-3TM APHA008GAK0EG-3TM APHA016GAK0EG-3TM APHA032GAK0EG-3TM APHA064GAK0EG-3TM APHA128GAK0EG-3TM Black Housing 9 ©2016 Apacer Technology, Inc. Rev. 1.6 USB Disk Module APHAxxxXAX0XG-XTX Revision History Revision Description 1.0 Official release Date 07/24/2015 z Modified performance and power consumption data for MLC models. z Updated valid combinations for SLC and MLC models. 1.1 09/17/2015 1.2 Revised product ordering information. 10/14/2015 1.3 Revised mechanical specifications 12/21/2015 z Added 128GB support 1.4 z Added OS support and flash management implementations on Features page 1.5 Revised performance for MLC series (8GB-64GB) 2/26/2016 1.6 Revised read performance for MLC 16GB 3/31/2016 2/19/2016 10 ©2016 Apacer Technology, Inc. Rev. 1.6 USB Disk Module APHAxxxXAX0XG-XTX Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 46732 Lakeview Blvd., Fremont, CA 94538 Tel: 1-408-518-8699 Fax: 1-510-249-9568 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd Room D, 22/FL, No.2, Lane 600, JieyunPlaza, Tianshan RD, Shanghai, 200051, China Tel: 86-21-6228-9939 Fax: 86-21-6228-9936 sales@apacer.com.cn India Apacer Technologies Pvt Ltd, th Unit No.201, “Brigade Corner”, 7 Block Jayanagar, Yediyur Circle, Bangalore – 560082, India Tel: 91-80-4152-9061 Fax: 91-80-4170-0215 sales_india@apacer.com 11 ©2016 Apacer Technology, Inc. Rev. 1.6
APHA008GAK0EG-3TM 价格&库存
很抱歉,暂时无法提供与“APHA008GAK0EG-3TM”相匹配的价格&库存,您可以联系我们找货
