AP-FM0512D3005S-T
AP-FM0512D3005S-T
    APACERMEMORYAMERICA(宇瞻科技)
    SSD 512MB SLC ATA 5V
AP-FM0512D3005S-T 数据手册
RoHS Recast Compliant ADM5S ADM5S 44P/270D Specifications January 19, 2015 Version 1.1 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 ATA Disk Module AP-FMxxxxD30XXS-XTX Features:  – – –  –  Standard ATA/IDE bus interface ATA command set compatible Compliant with ATA/ATAPI-8 ATA operating mode supports up to: PIO Mode up to 4 Multiword DMA Mode up to 2 Ultra DMA Mode up to 6  Connector type 44-pin female connector (2.00mm pitch)  Form Factor – ATA Disk Module – Dimension: 45.0 x 28.0 x 6.85, unit: mm  Flash management – Advanced wear-leveling algorithms – Built-in Hardware ECC – Flash block management – Power Failure Management  ATA Secure Erase  Shock & Vibration** – Shock: 1500 G – Vibration: 15 G  RoHS Recast compliant (2011/65/EU)  S.M.A.R.T. technology  Master/Slave switch (optional) Power consumption (typical)* – Supply voltage: 3.3V & 5V – Active mode: 265 mA – Idle mode: 5 mA – – Performance* Sustained read: Up to 75 MB/sec Sustained write: Up to 65 MB/sec – – Capacity 512 MB 1, 2, 4, 8, 16, 32, 64 GB    NAND Flash Type: SLC  MTBF > 1,000,000 hours Temperature ranges Operation: Standard: 0°C to 70°C Extended: -40 to 85°C – Storage: -40°C to 100°C – *Performance and power consumption addressed here are typical and may vary from flash configurations or platforms. **Non-operating 1 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Disk Module AP-FMxxxxD30XXS-XTX Table of Contents 1. General Description .............................................................................. 3 2. Functional Block ................................................................................... 3 3. Pin Assignments .................................................................................... 4 4. Product Specification ........................................................................... 5 4.1 Capacity ............................................................................................................................................... 5 4.2 Performance ........................................................................................................................................ 5 4.3 Environmental Specification ................................................................................................................ 5 5. Flash Management ................................................................................ 6 5.1 Advanced wear-leveling algorithms..................................................................................................... 6 5.2 Built-in Hardware ECC ........................................................................................................................ 6 5.3 Flash Block Management .................................................................................................................... 6 5.4 Power Failure Management ................................................................................................................ 6 5.5 Mean Time Between Failures (MTBF) ................................................................................................ 6 6. Software Interface ................................................................................ 7 6.1 Command Set ...................................................................................................................................... 7 6.2 S.M.A.R.T. ........................................................................................................................................... 8 6.3. ATA Secure Erase .............................................................................................................................. 8 7. Electrical Specification ........................................................................ 9 8. Mechanical Specifications ................................................................. 10 9. Product Ordering Information ............................................................. 11 9.1 Product Code Designations ............................................................................................................... 11 9.2 Valid Combinations ............................................................................................................................ 12 9.2.1 Standard ..................................................................................................................................... 12 9.2.2 Extended Temperature ............................................................................................................... 12 2 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Disk Module AP-FMxxxxD30XXS-XTX 1. General Description Apacer’s ATA Disk Module 5S (ADM5S) SSD delivers smooth performance and low power consumption. This device supports DMA mode up to UDMA 6 that offers advanced data transfer technology and internal memory efficiency, which effectively decreases the loading for the microprocessor. Compliant with ATA/ATAPI-8 standards, our ADM5S supports data transfer modes up to PIO 4, Multiword DMA 2, and Ultra DMA 6. Equipped with power Error Correction Coding (ECC) up to 72bit/1KB, the ADM5S can provide high data integrity. Aside from data efficiency, the ADM5S also comes with power management. The device can work at 3.3V or 5V power supply, with the output voltage automatically adjusted by the voltage regulator in the core. In addition, the built-in ECC engine can support multi-mode correction capability up to 72 bits and perform effective decoding throughput with high reliability. ADM is a cost-effective solution with standard ATA compliance deployable at all major operating systems such as Microsoft’s Windows series, Apple’s Mac OS family, and Unix variants. Featuring technologies as wear leveling, S.M.A.R.T, power failure management, and ATA Secure Erase, Apacer’s ADM is definitely the ideal and reliable system storage. 2. Functional Block The ATA-Disk Module (ADM) includes the ATA controller and flash media, as well as the ATA standard interface. Figure 2-1 shows the functional block diagram. Figure 2-1: Functional block diagram 3 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Disk Module AP-FMxxxxD30XXS-XTX 3. Pin Assignments Table 3-1 lists the pin assignments with respective signal names for the 44-pin configuration. A “#” suffix indicates the active low signal. The pin type can be input, output or input/output. Table 3-1: Pin assignments for the 44-pin configuration Pin No. Signal Name Pin Type I/O Type* Pin No. Signal Name Pin Type 1 RESET# I I2U 2 GND - Ground 3 D7 I/O I1Z, O2 4 D8 I/O I1Z, O2 5 D6 I/O I1Z, O2 6 D9 I/O I1Z, O2 7 D5 I/O I1Z, O2 8 D10 I/O I1Z, O2 9 D4 I/O I1Z, O2 10 D11 I/O I1Z, O2 11 D3 I/O I1Z, O2 12 D12 I/O I1Z, O2 13 D2 I/O I1Z, O2 14 D13 I/O I1Z, O2 15 D1 I/O I1Z, O2 16 D14 I/O I1Z, O2 17 D0 I/O I1Z, O2 18 D15 I/O I1Z, O2 19 GND - Ground 20 NC - - 21 DMARQ# O O1 22 GND I I2Z 24 GND - Ground I I2Z 26 GND - Ground O O1 28 NC/CSEL I I1U 23 IOWR# STOP I/O Type Ground IORD# 25 HDMARDY# HSTROBE# IORDY 27 DDMARDY# DSTROBE 29 DMACK# I I2U 30 NC/WP# 1 -/I -/I1U 31 INTRQ O O1 32 IOCS16# O O2 33 A1 I I1Z 34 PDIAG# I/O I1U, O1 35 A0 I I1Z 36 A2 I I1Z 37 CS1FX# I I2Z 38 CS3FX# I I2Z 39 DASP# I/O I1U, O6 40 GND - Ground 41 VDD - Power 42 VDD - Power 43 GND - Ground 44 NC - - *Pin 30 is selectable as NC or WP# through a zero ohm resistor jumper. Default is NC. Note that pin 30 is a GND pin on standard ATA interface. This pin could be redesigned for host to control the write protect function on ADM 4 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Disk Module AP-FMxxxxD30XXS-XTX 4. Product Specification 4.1 Capacity Capacity specification of the ATA-Disk Module (ADM) product family is available as shown in Table 4-1. Table 4-1: Capacity specifications (unformatted) Capacity Total bytes Cylinders Heads Sectors Max LBA 512 MB 512,483,328 993 16 63 1,000,944 1 GB 1,011,032,064 1959 16 63 1,974,672 2 GB 2,011,226,112 3897 16 63 3,928,176 4 GB 4,011,614,208 7773 16 63 7,835,184 8 GB 8,012,390,400 15525 16 63 15,649,200 16 GB 16,013,942,784 16383 16 63 31,277,232 32 GB 32,017,047,552 16383 16 63 62,533,296 64 GB 64,023,257,088 16383 16 63 125,045,424 *Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies **Notes: 1 GB = 1,000,000,000 bytes; 1 sector = 512 bytes. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 4.2 Performance Performances of the ATA-Disk Module are listed in below tables. Table 4-2: Capacity Performance specifications 512 MB 1 GB 2 GB 4 GB 8 GB 16 GB 32 GB 64 GB 31 31 35 65 70 75 75 75 20 20 28 50 60 65 65 65 Performance Sustained read (MB/s) Sustained write (MB/s) *Results may differ from various flash configurations and platforms. 4.3 Environmental Specification Environmental specification of the ATA-Disk Module (ADM) follows the MIL-STD-810F standard. Table 4-3: Environmental specifications Environment Temperature Specification Operation 0°C to 70°C / -40°C to 85°C Storage -40°C to 100°C Vibration (Non-Operating) Shock (Non-Operating) Sine wave: 10~2000Hz, 15G (X, Y, Z axes) Half sine wave, 1500 G, 11 ms (X, Y, Z ; All 6 axes) 5 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Disk Module AP-FMxxxxD30XXS-XTX 5. Flash Management 5.1 Advanced wear-leveling algorithms Flash memory devices differ from Hard Disk Drives (HDDs) in terms of how blocks are utilized. For HDDs, when a change is made to stored data, like erase or update, the controller mechanism on HDDs will perform overwrites on blocks. Unlike HDDs, flash blocks cannot be overwritten and each P/E cycle wears down the lifespan of blocks gradually. Repeatedly program/erase cycles performed on the same memory cells will eventually cause some blocks to age faster than others. This would bring flash storages to their end of service term sooner. Wear leveling is an important mechanism that level out the wearing of blocks so that the wearing-down of blocks can be almost evenly distributed. This will increase the lifespan of SSDs. Commonly used wear leveling types are Static and Dynamic. 5.2 Built-in Hardware ECC The properties of NAND flash memory make it ideal for applications that require high integrity while operating in challenging environments. The integrity of data to NAND flash memory is generally maintained through ECC algorithms. This ATA-Flash Drive is programmed with a hardware ECC engine which correct up to 72 bits per 1KB. 5.3 Flash Block Management Current production technology is unable to guarantee total reliability of NAND flash memory array. When a flash memory device leaves factory, it comes with a minimal number of initial bad blocks during production or out-of-factory as there is no currently known technology that produce flash chips free of bad blocks. In addition, bad blocks may develop during program/erase cycles. When host performs program/erase command on a block, bad block may appear in Status Register. Since bad blocks are inevitable, the solution is to keep them in control. Apacer flash devices are programmed with ECC, block mapping technique and S.M.A.R.T to reduce invalidity or error. Once bad blocks are detected, data in those blocks will be transferred to free blocks and error will be corrected by designated algorithms. 5.4 Power Failure Management Power Failure Management plays a crucial role when experiencing unstable power supply. Power disruption may occur when users are storing data into the SSD. In this urgent situation, the controller would run multiple write-to-flash cycles to store the metadata for later block rebuilding. This urgent operation requires about several milliseconds to get it done. At the next power up, the firmware will perform a status tracking to retrieve the mapping table and resume previously programmed NAND blocks to check if there is any incompleteness of transmission. 5.5 Mean Time Between Failures (MTBF) Mean Time Between Failures (MTBF) is predicted based on reliability data for the individual components in the drive. The prediction result for the drive is more than 1,000,000 hours. Notes about the MTBF: The MTBF is predicated and calculated based on “Telcordia Technologies Special Report, SR-332, Issue 2” method. 6 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Disk Module AP-FMxxxxD30XXS-XTX 6. Software Interface 6.1 Command Set This section defines the software requirements and the format of the commands the host sends to the ATA-Disk Module (ADM). Commands are issued to the ADM by loading the required registers in the command block with the supplied parameters, and then writing the command code to the Command register. The manner in which a command is accepted varies. Table 6-1: Command set (1 of 2) Command Code Check-Power-Mode E5H or 98H Execute-Drive-Diagnostic 90H Erase Sector(s) C0H Flush-Cache E7H Format Track 50H Identify-Drive ECH Idle E3H or 97H Idle-Immediate E1H or 95H Initialize-Drive-Parameters 91H NOP 00H Read-Buffer E4H Read-DMA C8H or C9H Read-Multiple C4H Read-Sector(s) 20H or 21H Read-Verify-Sector(s) 40H or 41H Recalibrate 1XH Request-Sense 03H Security-Disable-Password F6H Security-Erase-Prepare F3H Security-Erase-Unit F4H Security-Freeze-Lock F5H Security-Set-Password F1H Security-Unlock F2H Seek 7XH Set-Features EFH 7 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Disk Module AP-FMxxxxD30XXS-XTX Table 6-1: Command set (2 of 2) Command Code SMART B0H Set-Multiple-Mode C6H Set-Sleep-Mode E6H or 99H Standby E2H or 96H Standby-lmmediate E0H or 94H Translate-Sector 87H Write-Buffer E8H Write-DMA CAH or CBH Write-Multiple C5H Write-Multiple-Without-Erase CDH Write-Sector(s) 30H or 31H Write-Sector-Without-Erase 38H Write-Verify 3CH 6.2 S.M.A.R.T. S.M.A.R.T. is an acronym for Self-Monitoring, Analysis and Reporting Technology, an open standard allowing disk drives to automatically monitor their own health and report potential problems. It protects the user from unscheduled downtime by monitoring and storing critical drive performance and attributes parameters. Ideally, this should allow taking proactive actions to prevent impending drive failure. 6.3. ATA Secure Erase ATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 8 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Disk Module AP-FMxxxxD30XXS-XTX 7. Electrical Specification Table 7-1: Operating range 0°C to +70°C -40°C to 85°C 3.135-3.465V 4.75-5.25V Ambient Temperature Operating voltage Table 7-2: Capacity Power consumptions 512 MB 1 GB 2 GB 4 GB 8 GB 16 GB 32 GB 64 GB Active (mA) 125 125 130 190 220 240 245 265 Idle (mA) 5 5 5 5 5 5 5 5 Modes *Results were tested at 5.0V power supply and may differ from various flash configurations and platforms. 9 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Disk Module AP-FMxxxxD30XXS-XTX 8. Mechanical Specifications 10 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Disk Module AP-FMxxxxD30XXS-XTX 9. Product Ordering Information 9.1 Product Code Designations AP – FM xxxx D 3 0 X X S – X T X Temperature: Blank: Standard W: Wide Temp. Flash Type FW Version Environmental Spec Voltage: 3: 3.3V 5: 5.0V Speed: 0: Standard PCB Version Package Modifier: 44 pin / 270D Controller Version Capacity: 0512: 001G: 002G: 004G: 008G: 016G: 032G: 064G: 512MB 1GB 2GB 4GB 8GB 16GB 32GB 64GB Model Name Apacer Product Code 11 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Disk Module AP-FMxxxxD30XXS-XTX 9.2 Valid Combinations 9.2.1 Standard Capacity P/N (3.3V) P/N (5V) 512MB AP-FM0512D3003S-T AP-FM0512D3005S-T 1GB AP-FM001GD3003S-T AP-FM001GD3005S-T 2GB AP-FM002GD3003S-T AP-FM002GD3005S-T 4GB AP-FM004GD3003S-T AP-FM004GD3005S-T 8GB AP-FM008GD3003S-T AP-FM008GD3005S-T 16GB AP-FM016GD3003S-T AP-FM016GD3005S-T 32GB AP-FM032GD3003S-T AP-FM032GD3005S-T 64GB AP-FM064GD3003S-T AP-FM064GD3005S-T 9.2.2 Extended Temperature Capacity P/N (3.3V) P/N (5V) 512MB AP-FM0512D3003S-TW AP-FM0512D3005S-TW 1GB AP-FM001GD3003S-TW AP-FM001GD3005S-TW 2GB AP-FM002GD3003S-TW AP-FM002GD3005S-TW 4GB AP-FM004GD3003S-TW AP-FM004GD3005S-TW 8GB AP-FM008GD3003S-TW AP-FM008GD3005S-TW 16GB AP-FM016GD3003S-TW AP-FM016GD3005S-TW 32GB AP-FM032GD3003S-TW AP-FM032GD3005S-TW 64GB AP-FM064GD3003S-TW AP-FM064GD3005S-TW 12 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Disk Module AP-FMxxxxD30XXS-XTX Revision History Revision Date Description 1.0 12/09/2014 Official release 1.1 1/19/2015 Remark Capacity reorganized. 13 © 2015 Apacer Technology Inc. Rev. 1.1 ATA Disk Module AP-FMxxxxD30XXS-XTX Global Presence Taiwan (Headquarters) Apacer Technology Inc. Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-518-8699 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 services@apacer.com.cn India Apacer Technologies Pvt Ltd, # 535, 1st Floor, 8th cross, JP Nagar 3rd Phase, Bangalore – 560078, India Tel: 91-80-4152-9061 sales_india@apacer.com 14 © 2015 Apacer Technology Inc. Rev. 1.1
AP-FM0512D3005S-T 价格&库存
很抱歉,暂时无法提供与“AP-FM0512D3005S-T”相匹配的价格&库存,您可以联系我们找货
