APP064G2DA-ATM
APP064G2DA-ATM
    APACERMEMORYAMERICA(宇瞻科技)
    Solid State Drive (SSD) 64GB FLASH - NAND (MLC) PCIe 2.0 3.3V
APP064G2DA-ATM 数据手册
RoHS Compliant Mini PCIe Disk Module Plus mPDM+ Product Specifications June 9, 2015 Version 1.1 Apacer Technology Inc. 1F, No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City, Taiwan, R.O.C Tel: +886-2-2267-8000 www.apacer.com Fax: +886-2-2267-2261 PCI-Express SSD APPXXXXXXA-AXX Features:  Standard PCI Express bus interface PCI Express Specification Rev.2.0* PCI Express Card Electromechanical Rev. 2.0 – Supports ECRC (end-to-end CRC) and advanced error reporting – Supports Spread Spectrum Clocking (SSC)  –    – – Temperature ranges 0 to 70°C for ambient temperature -40°C to 85°C for storage temperature – Supply voltage 3.3 V +/- 5% – – Power consumption** Active mode: 1,110 mA Idle mode: 440 mA – – Form Factor PCI Express Full-Mini Card Type Dimensions: 50.80 x 29.85 x 4.20, unit: mm – Connector type One lane mini PCI Express  – –   Capacity 8, 16, 32, 64, 128 GB  Performance** – Sustain Read Speed up to 390 MB/s – Sustain Write Speed up to 320 MB/s Flash Management – Supports ECC up to 72 bit correction per 1K Byte data – Wear leveling – Flash bad-block management – S.M.A.R.T. – Power Failure Management – ATA Secure Erase   RoHS compliant  Supports NCQ (Native Command Queue) commands  Supports AHCI 1.3 NAND Flash: MLC *The mPDM+ is not backward compatible. Operational instability or inefficiency will occur if this device is applied on a PCIe 1.0 socket. **The performance and power consumption values addressed here are typical and may vary from platforms. © 2015 Apacer Technology Inc. 1 Rev. 1.1 PCI-Express SSD APPXXXXXXA-AXX Table of Contents 1. GENERAL DESCRIPTION .................................................................................................... 3 1.1 ERROR CORRECTION/DETECTION .........................................................................................................................3 1.2 FLASH BLOCK MANAGEMENT .............................................................................................................................. 3 1.3 WEAR LEVELING ..................................................................................................................................................3 1.4 POWER FAILURE MANAGEMENT........................................................................................................................... 3 1.5 ATA SECURE ERASE ............................................................................................................................................4 1.6 S.M.A.R.T............................................................................................................................................................ 4 2. BLOCK DIAGRAM ................................................................................................................. 5 3. PIN ASSIGNMENTS ............................................................................................................... 6 4. PRODUCT SPECIFICATION ................................................................................................ 7 4.1 CAPACITY ............................................................................................................................................................. 7 4.2 PERFORMANCE .....................................................................................................................................................7 4.3 ENVIRONMENTAL SPECIFICATION.........................................................................................................................7 5. ELECTRICAL SPECIFICATION ........................................................................................ 8 6. MECHANICAL SPECIFICATIONS .................................................................................... 9 7. PRODUCT ORDERING INFORMATION ........................................................................ 10 7.1 PRODUCT CODE DESIGNATIONS ......................................................................................................................... 10 7.2 VALID COMBINATIONS ....................................................................................................................................... 11 © 2015 Apacer Technology Inc. 2 Rev. 1.1 PCI-Express SSD APPXXXXXXA-AXX 1. General Description Apacer’s mPDM+ (mini PCIe Disk Module Plus) SSD offers a breakthrough in non-volatile memory storage. Formed as a mini PCI-Express card, this mPDM+ can fit in various types of embedded platforms, such as workstation, thin computing devices and high-end heavy duty servers where spaces are concerned. Regarding data transfer rate, mPDM+ delivers ideal data read/write performance. Apacer mPDM+ provides one-lane PCI-Express 2.0 host interface, and is compatible with 5.0 Gbps maximum transfer rate. Compatibility wise, this mini PCIe SSD is not only fully compliant with PCI Express Specification Rev.2.0 and Electromechanical Rev.2.0, but also supports NCQ commands and IDE/AHCI operational modes. 1.1 Error Correction/Detection The ECC engine in this device can detect and correct up to 72 bits error in 1K bytes. 1.2 Flash Block Management Bad blocks are blocks that include one or more invalid bits, and their reliability is not guaranteed. Blocks that are identified and marked as bad by the manufacturer are referred to as “Initial Bad Blocks”. Bad blocks that are developed during the lifespan of the flash are named “Later Bad Blocks”. Thus, this device implements an efficient bad block management algorithm to detect the factory-produced bad blocks and manages any bad blocks that appear with use. This practice further prevents data being stored into bad blocks and improves the data reliability. 1.3 Wear Leveling NAND Flash devices can only undergo a limited number of program/erase cycles, and in most cases, the flash media are not used evenly. If some area get updated more frequently than others, the lifetime of the device would be reduced significantly. Thus, Wear Leveling technique is applied to extend the lifespan of NAND Flash by evenly distributing write and erase cycles across the media. Apacer provides advanced Wear Leveling algorithm, which can efficiently spread out the flash usage through the whole flash media area. Moreover, by implementing both dynamic and static Wear Leveling algorithms, the life expectancy of the NAND Flash is greatly improved. 1.4 Power Failure Management Power Loss Protection is a mechanism to prevent data loss during unexpected power failure. DRAM is a volatile memory and frequently used as temporary cache or buffer between the controller and the NAND flash to improve the SSD performance. However, one major concern of the DRAM is that it is not able to keep data during power failure. Accordingly, the module applies the flushing mechanism which requests the controller to transfer data to the cache. For this flash module, SDR performs as a cache, and its sizes include 8MB or 32MB. Only when the data is fully committed to the NAND flash will the controller send acknowledgement to the host. Such implementation can prevent false-positive performance and the risk of power cycling issues. Additionally, it is critical for a controller to shorten the time the in-flight data stays in the cache. Thus, the module applies an algorithm to reduce the amount of data resides in the cache to provide a better © 2015 Apacer Technology Inc. 3 Rev. 1.1 PCI-Express SSD APPXXXXXXA-AXX performance by allowing incoming data to only have a “pit stop” in the cache and then move to the NAND flash at once. If the flash is jammed due to particular file sizes (random 4K), the cache will be treated as an “organizer”, consolidating incoming data into groups before written into the flash to improve write amplification. In sum, with this power failure management, this module proves to provide the reliability required by consumer, industrial, and enterprise-level application. 1.5 ATA Secure Erase AATA Secure Erase is an ATA disk purging command currently embedded in most of the storage drives. Defined in ATA specifications, (ATA) Secure Erase is part of Security Feature Set that allows storage drives to erase all user data areas. The erase process usually runs on the firmware level as most of the ATA-based storage media currently in the market are built-in with this command. ATA Secure Erase can securely wipe out the user data in the drive and protects it from malicious attack. 1.6 S.M.A.R.T. SMART, an acronym for Self-Monitoring, Analysis and Reporting Technology, is an open standard that allows a hard disk drive to automatically detect its health and report potential failures. When a failure is recorded by SMART, users can choose to replace the drive to prevent unexpected outage or data loss. Moreover, SMART can inform users of impending failures while there is still time to perform proactive actions, such as copy data to another device. © 2015 Apacer Technology Inc. 4 Rev. 1.1 PCI-Express SSD APPXXXXXXA-AXX 2. Block Diagram © 2015 Apacer Technology Inc. 5 Rev. 1.1 PCI-Express SSD APPXXXXXXA-AXX 3. Pin Assignments Pin 51 Pin 1 Pin Signal Pin Signal 51 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1 Reserved Reserved Reserved Reserved GND 3.3V 3.3V GND 52 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 +3.3V GND GND PETp0 PETn0 GND GND PERp0 PERn0 GND Reserved Reserved GND REFCLK+ REFCLKGND CLKREQ# NC NC Reserved © 2015 Apacer Technology Inc. 6 Reserved Reserved Reserved Reserved Reserved NC NC GND Reserved Reserved NC GND +3.3Vaux PERST# Reserved GND NC NC NC NC NC NC GND 3.3V Rev. 1.1 PCI-Express SSD APPXXXXXXA-AXX 4. Product Specification 4.1 Capacity Table 4-1: Capacity specifications Capacity Total bytes* Cylinders Heads Sectors Max LBA 8 GB 8,012,390,400 15,525 16 63 15,649,200 16 GB 16,013,942,784 16,383 16 63 31,277,232 32 GB 32,017,047,552 16,383 16 63 62,533,296 64 GB 64,023,257,088 16,383 16 63 125,045,424 128 GB 128,035,676,160 16,383 16 63 250,069,680 *Display of total bytes varies from file systems. **Cylinders, heads or sectors are not applicable for these capacities. Only LBA addressing applies. LBA count addressed in the table above indicates total user storage capacity and will remain the same throughout the lifespan of the device. However, the total usable capacity of the mPDM+ SSD is most likely to be less than the total physical capacity because a small portion of the capacity is reserved for device maintenance usages. 4.2 Performance Performances and random read/write specifications of the mPDM+ are listed in following tables. Table 4-2: Performance Capacity 8 GB 16 GB 32 GB 64 GB 128 GB Sustained read (MB/s) 160 315 390 390 390 Sustained write (MB/s) 80 155 175 185 320 Performance Note: Results may differ from various flash configurations or host system settings. 4.3 Environmental Specification Environmental specification of mPDM+ product family follows the MIL-STD-810F standard. Table 4-3: Environmental specifications Environment Temperature Specification Operation 0 to 70°C Storage -40°C to 85°C Humidity Vibration (Non-Operating) Shock (Non-Operating) © 2015 Apacer Technology Inc. 5% to 95% RH (Non-condensing) Sine wave : 10~2000Hz, 15G (X, Y, Z axes) Half sine wave, 1500 G (X, Y, Z ; All 6 axes) 7 Rev. 1.1 PCI-Express SSD APPXXXXXXA-AXX 5. Electrical Specification Caution: Absolute Maximum Stress Ratings – Applied conditions greater than those listed under “Absolute Maximum Stress Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these conditions or conditions greater than those defined in the operational sections of this data sheet is not implied. Exposure to absolute maximum stress rating conditions may affect device reliability. Table 5-1: Absolute maximum stress ratings Parameter Power supply Min. 3.13 Typical 3.3 Max. 3.46 Operating temperature 0 70 Storage temperature -40 85 Units V °C °C Table 5-2: Power consumption (typical) Capacity 8 GB 16 GB 32 GB 64 GB 128 GB Active (mA) 515 600 630 700 1,110 Idle (mA) 340 340 340 345 440 State *Results may differ from various flash configurations and platforms. © 2015 Apacer Technology Inc. 8 Rev. 1.1 PCI-Express SSD APPXXXXXXA-AXX 6. Mechanical Specifications Unit: mm Tolerance: ± 0.25 © 2015 Apacer Technology Inc. 9 Rev. 1.1 PCI-Express SSD APPXXXXXXA-AXX 7. Product Ordering Information 7.1 Product Code Designations A P P XXXX X X A – A XX Flash Type FW Version uSDC Version Solution Type 2:mPDM Plus Capacities: 008G: 016G: 032G: 064G: 128G: 8GB 16GB 32GB 64GB 128GB PCIE Apacer Product Code © 2015 Apacer Technology Inc. 10 Rev. 1.1 PCI-Express SSD APPXXXXXXA-AXX 7.2 Valid Combinations Capacity Standard 8GB 16GB 32GB 64GB 128GB APP008G2DA-ATM APP016G2DA-ATM APP032G2DA-ATM APP064G2DA-ATM APP128G2EA-ATM For availabilities, please consult with Apacer sales representatives © 2015 Apacer Technology Inc. 11 Rev. 1.1 PCI-Express SSD APPXXXXXXA-AXX Revision History Revision Date Description 1.0 10/24/2014 Official release 1.1 06/09/2015 Added block diagram © 2015 Apacer Technology Inc. 12 Remark Rev. 1.1 PCI-Express SSD APPXXXXXXA-AXX Global Presence Taiwan (Headquarters) Apacer Technology Inc. 1F., No.32, Zhongcheng Rd., Tucheng Dist., New Taipei City 236, Taiwan R.O.C. Tel: 886-2-2267-8000 Fax: 886-2-2267-2261 amtsales@apacer.com U.S.A. Apacer Memory America, Inc. 386 Fairview Way, Suite102, Milpitas, CA 95035 Tel: 1-408-586-1291 Fax: 1-408-935-9611 sa@apacerus.com Japan Apacer Technology Corp. 5F, Matsura Bldg., Shiba, Minato-Ku Tokyo, 105-0014, Japan Tel: 81-3-5419-2668 Fax: 81-3-5419-0018 jpservices@apacer.com Europe Apacer Technology B.V. Science Park Eindhoven 5051 5692 EB Son, The Netherlands Tel: 31-40-267-0000 Fax: 31-40-267-0000#6199 sales@apacer.nl China Apacer Electronic (Shanghai) Co., Ltd 1301, No.251,Xiaomuqiao Road, Shanghai, 200032, China Tel: 86-21-5529-0222 Fax: 86-21-5206-6939 sales@apacer.com.cn India Apacer Technologies Pvt. Ltd. # 535, 1st Floor, 8th cross, JP Nagar 3rd Phase, Bangalore – 560078, India Tel: 91-80-4152-9061 sales_india@apacer.com © 2015 Apacer Technology Inc. 13 Rev. 1.1
APP064G2DA-ATM 价格&库存
很抱歉,暂时无法提供与“APP064G2DA-ATM”相匹配的价格&库存,您可以联系我们找货
