SFSA16GBV1BR4TO-C-QT-236-STD 数据手册
Product fact sheet
Industrial
SLIM SATA SSD
MO-297A
X-200s Series
SATA II - 3.0Gb/s
up to UDMA6 / MDMA2 / PIO4
BU:
Swissbit Grou p
Da t e:
15 Febru a ry 2011
Rev ision : 0.8 0 preli mina ry
X- 200s_fa ct _sheet _SA - VxBR_Rev 08 0.doc
Swissbit AG
Industriestrasse 4
CH-9552 Bronschhofen
Switzerland
Swissbit reserves the right to change products or specifications without notice.
www.swissbit.com
info@swissbit.com
Revision: 0.80
X-200s_fact_sheet_SA-VxBR_Rev080.doc
Page 1 of 4
X-200s Solid State Drive
Industrial SLIM SATA SSD (MO-297A)
2GByte up to 32GByte
Feature summary
Form factor:
o Jedec MO-297A sized Solid State Drive (SSD)
o 54mm x 39mm x 4mm
Interface:
o SATA Rev 2.6 - 3Gbit/s (1.5Gbit/s compatible)
o 7+15pin (SATA+power)
o standard 2.5” SATA-connector
Highly-integrated memory controller
o
max. UDMA6 supported
o
max. PIO mode 4, MDMA2 supported
o
SLC Nand Flash
o
Hardware BCH-code ECC (8 Bit correction per sector for SLC)
o
fix drive configuration
Low-power CMOS technology
5V ± 10% power supply
optional 3.3V± 5% power supply
Low Power, less than 500mA
No mechanical noise
Activity LED output (P11) (optional can be NC on the module)
Wear Leveling: active wear leveling of static and dynamic data
The wear leveling assures that dynamic data as well as static data is balanced evenly across the
memory. With that the maximum write endurance of the device is guaranteed.
Write endurance: Due to intelligent wear leveling an even use of the entire flash is guaranteed,
regardless how much “static” (OS) data is stored.
Example: If the average file size is 10MByte and the total capacity is 8GByte, 80Mio write cycles can be
performed.
Data Retention: 10 years @ 10% life time
High reliability
o
MTBF > 2,500,000 hours
o
Data reliability: < 1 non-recoverable error per 1014 bits read
High performance
o
Up to 300MB/s burst transfer rate in SATA II - 3.0Gb/sec
o
Sustained Write performance: up to 90MB/s
o
Sustained Read Performance: up to 105MB/s
Available densities
o
4GByte up to 32GByte (SLC NAND Flash)
Temperature ranges
o Commercial Temperature range
0 … +70°C
o Industrial Temperature range
-40 … +85°C
Controlled BOM
RoHS compatible
Swissbit AG
Industriestrasse 4
Switzerland
www.swissbit.com
info@swissbit.com
Revision: 0.80
Page 2 of 4
Pinout
The SLIM SATA connector is a standard SATA 7+15pin connector.
Pin
S1
S2
S3
S4
S5
S6
S7
Assignment
GND
A+
AGND
BB+
GND
Description
Signal ground
+ SATA differential receive signal
- SATA differential receive signal
Signal ground
- SATA differential transmit signal
+ SATA differential transmit signal
Signal ground
P1-P3
P4-P6
P7-P9
P10
P11
P12
P13-P15
+3.3V
GND
+5V
GND
DA
GND
+12V
Optional 3.3V power supply *)
Power Ground
Standard 5V power supply *)
Power Ground
Device activity / LED (optional) **)
Power Ground
No Connect
*) Standard modules have only 5V power supply
optional the modules can be ordered with 3.3V supply
**) Device Activity Pin is low in idle mode and high (flickering) during data transfer.
It can be optional disconnected on the module on request.
Swissbit AG
Industriestrasse 4
Switzerland
www.swissbit.com
info@swissbit.com
Revision: 0.80
Page 3 of 4
Table 1: System Performance
System Performance
Data transfer Rate (sATA burst)
Sustained Read (max. measured)
Sustained Write (max. measured)
1.
2.
4GB
3.0 (1.5)
115
45
8…32GB
3.0 (1.5)
110
90
Unit
Gbit/s
MB/s
All values refer to modules with 4x Toshiba Flash in UDMA mode 5, SATA 3.0Gbit/s, write/read data sequential
256 Sectors/Transfer command.
Sustained speed depends on flash type and number, file size, and burst speed
Table 2: Current consumption(1) at 5V ± 10%
Current Consumption
Write (UDMA6)
Read (UDMA6)
Standby
1.
typical
350
250
125
max
400
350
140
Unit
mA
All values are typical at 25° C and nominal supply voltage and refer to 16GByte SSD module.
Table 3: Environmental Specifications
Temperature (commercial)
Temperature (industrial)
Humidity (non-condensing)
Vibration (peak -to-peak)
Shock
Operating
Non Operating
0 to 70°C
-40 to 85°C
-40 to 85°C
-50 to 95°C
85% RH, at 85°C
max. 95% RH, at 85°C
20G Peak, 10…2000Hz
1500G, 0.5ms duration, half sine wave
Table 4: Physical Dimensions
Physical Dimensions
Unit
Width
Height
Thickness max.
Weight (typ.)
54.0
39.8 (with connector)
4 (connector)
10
mm
g
Table 5: SSD capacity specification
Capacity
Default_cylinders
Default_heads
4GB
8GB
16GB
32GB
7,814
15,628
16,383*)
16,383*)
16
16
16
16
Default_sectors
_track
63
63
63
63
Sectors_drive
7,876,512
15,753,024
31,506,432
62,586,880
Total addressable capacity
(Byte)
4,032,774,144
8,065,548,288
16,131,293,184
32,044,482,560
*) The CHS addressing is limited to about 8GB. Larger drives should be used in LBA mode.
Table 6: System Reliability and Maintenance
MTBF (at 25°C)
Data Reliability
> 2,500,000 hours
14
< 1 Non-Recoverable Error per 10 bits Read
(1) Dependent on final system qualification data.
For more information on MO-297A mechanical standard, please visit JEDEC at www.jedec.org.
For more information on Serial ATA Revision 2.6, please visit Serial ATA International Organization at
www.serialata.org
Why Swissbit?
Swissbit strives to create innovative technologies for future market opportunities utilizing a highly skilled
in-house product research and development team. Swissbit maintains a marketing edge by continuing to
manufacture world-class high quality memory products and providing customers with both high value and
low cost of ownership achieved through efficient processes and procedures.
Swissbit AG
Industriestrasse 4
Switzerland
www.swissbit.com
info@swissbit.com
Revision: 0.80
Page 4 of 4
SFSA16GBV1BR4TO-C-QT-236-STD 价格&库存
很抱歉,暂时无法提供与“SFSA16GBV1BR4TO-C-QT-236-STD”相匹配的价格&库存,您可以联系我们找货
