SFCA064GH1AD4TO-I-GS-216-STD 数据手册
Product Fact Sheet
Industrial
CFastTM Card
F-50 Series
SATA Gen3 - 6.0 Gbit/s, MLC
Commercial and Industrial
Temperature Grade
Date :
Re vi si o n:
N ove m be r 23 , 2 0 21
1 .0 7
Product Fact Sheet
F-50 Series
Product Summary
Capacities: 8 GBytes, 16 GBytes, 32 GBytes, 64 GBytes, 128 GBytes, 256 GBytes
Form Factor: CFastTM 2.0 (36.4 mm x 42.8 mm x 3.6 mm)
Compliance: SATA Gen3 - 6 Gbit/s (Gen2 - 3 Gbit/s and Gen1 - 1.5 Gbit/s backward compatible)
Command Sets: Supports ATA/ATAPI-8 and ACS-2
Performance:
o Read Performance: Sequential Read up to 500 MBytes/s, Random Read 4K up to 53,500 IOPS
o Write Performance: Sequential Write up to 330 MBytes/s, Random Write 4K up to 74,000 IOPS
Operating Temperature Range1:
o Commercial: 0 °C to 70 °C
o Industrial: -40 °C to 85 °C
Storage Temperature Range: -40 °C to 85 °C
Operating Voltage: 3.3 V ± 5%
Power (Max Capacity): Read (Active): 1.2 W; Write (Active): 2.0 W; Idle: 248 mW; Slumber: 17 mW
Data Retention: 10 Years @ Life Begin / 1 Year @ Life End
Endurance in TeraBytes Written (TBW) Max Capacity2: Client ≥ 165; Enterprise ≥ 8
Shock/Vibration: 500 g / 20 g
Hardware BCH Code ECC: up to 66 bit correction per 1 KByte page
NAND Flash Technology: Multi-Level Cell (MLC)
Mean Time Between Failure (MTBF): > 2,000,000 hours
Data Reliability: < 1 non-recoverable error per 1016 bits read
Product Features
Dynamic and Static Wear Leveling
Subpage Mode Flash Translation Layer (FTL)
Active Data Care Management: Read Refresh
Lifetime Enhancements
o Dynamic Bad Block Remapping
o Write Amplification Reduction
On-Board Power Fail Protection
AHCI, TRIM, and NCQ Support
ATA Security Feature Set Support
DEVSLP Compatible
In-Field Firmware Update
Enterprise-Grade Self-Monitoring, Analysis, and Reporting Technology (S.M.A.R.T.)
Controlled “Locked” BOM
30 µinch Gold-Plated Connector (on request)
Conformal coating (on request)
Swissbit Life Time Monitoring (SBLTM) Tool and SDK for SBLTM (on request)
Why Swissbit?
Swissbit is focused on the design, development, manufacture, and support of leading edge memory and
storage solutions for the worldwide OEM/ODM marketplace. As a global supplier, Swissbit recognizes and
addresses the higher level of application requirements of today’s industrial, Netcom, and automotive
customers by providing best-in-class products and services, with uncompromised attention to driving overall
value and quality.
1
Adequate airflow is required to ensure the temperature, as reported in the S.M.A.R.T. data, does not exceed 120°C (industrial
temperature drive) and 105°C (commercial temperature drive) respectively.
2
According to JEDEC (JESD47I), the time to write the full TBW is a minimum of 18 months. Higher average daily data volume reduces the
specified TBW. The values listed are estimates and are subject to change without notice.
Swissbit AG
Revision: 1.07
Industriestrasse 4
TLP: Swissbit public
Template: Doc-4991
CH-9552 Bronschhofen
File: F-50_fact_sheet_Rev107
Switzerland
www.swissbit.com/contact
Page 2 of 2
SFCA064GH1AD4TO-I-GS-216-STD 价格&库存
很抱歉,暂时无法提供与“SFCA064GH1AD4TO-I-GS-216-STD”相匹配的价格&库存,您可以联系我们找货
