CFast 2
CFast 2
Overview
Since CompactFlash Association released the specification of
CFast 2.0, Apacer takes the lead to roll out the first industrialgrade SATA 3.0 (6Gb/s) high-speed transmission interface CFast
2.0 memory card around the globe. Its sequential speed is up to
285/260 MB/sec and dimensions is 42.8mm x 36.4mm x
3.6mm with (7+17) pin connector. Besides featuring a 2-Channel
bidirectional structure, the CFast 2.0 adopts Toggle DDR 2.0
NAND Flash, which brings its performance to a higher level.
Support for DEVSLP (Device Sleep) power mode enables them to
switch into a low power state on standby mode so as to save
power for companies.
Feature
‧ Compliant with CFast 2.0 specifications
‧ Built-in ATA Secure Erase and S.M.A.R.T. Functions
‧ Advanced wear-leveling and Block Management
‧ Intelligent Power Failure Recovery
‧ DEVSLP Support (Optional)
‧ HW Write-Protect Switch (Optional)
Specifications
Model
CFast 2
Interface
SATA 3.0 (6Gb/s)
Connector
(7+17) pin male
Form Factor
NAND Flash Type
Capacity
External DRAM
CFast 3.0
SLC
4GB~64GB
NA
Sustained Read Performance (MB/sec)
Up to 285
Sustained Write Performance (MB/sec)
Up to 260
ECC Engine
Built-in 40-bit per 1K bytes BCH ECC
Standard Operating Temperature ( °C )
0 ~ + 70
Extended Operating Temperature ( °C )
-40 ~ + 85
Storage Temperature ( °C )
-40 ~ + 100
Shock
Vibration
Operating Voltage
Power Consumption
Dimension (L x W x H )
MTBF (hours)
Operating Shock: 50G, 11ms
Non-operating Shock: 1500G, 0.5ms)
Operating Vibration: 7.69 Grms, 20~2000 Hz/random
(compliant with MIL-STD-810G)
Non-operating Vibration: 15 Grms, 10~2000 Hz/sine
3.3 V ± 5%
Active mode: 500 mA & Idle mode: 90 mA
42.8 x 36.4 x 3.6 (mm)
>2,000,000
Mechanical Specification
Unit: mm
For more information, contact your Apacer representative
Global Presence
Taiwan (Headquarters)
Apacer Technology Inc.
Tel: +886-2-2267-8000
Fax: +886-2-2267-2261
Europe
Apacer Technology B.V.
Tel: +31-40-267-0000
Fax: +31-40-290-0686
Japan
Apacer Technology Corp.
Tel: +81-3-5419-2668
Fax: +81-3-5419-0018
India
Apacer Technologies Pvt. Ltd.
Tel: +91-80-41529061~3
Fax: +91-80-41700215
U.S.A.
Apacer Memory America, Inc.
Tel: +1-408-518-8699
Fax: 1-510-249-9551
China
Apacer Electronic(Shanghai)
Co., Ltd.
Tel: +86-21-6228-9939
DOC:20161130
很抱歉,暂时无法提供与“APCFA064GACAN-AT”相匹配的价格&库存,您可以联系我们找货
