TM
INDUSTRIAL GRADE CompactFlash Disk
W7CFxxxA-H Series ROHS 6/6 Compliant
32MB – 16-GB
CompactFlashTM Disk
INDUSTRIAL GRADE
W7CFxxxA-H Series
INFORMATION IN THIS DOCUMENT IS PROVIDED IN RELATION TO
WINTEC INDUSTRIES PRODUCTS, AND IS SUBJECT TO CHANGE
WITHOUT NOTICE.
NOTHING IN THIS DOCUMENT SHALL BE CONTRUED AS GRANTING
ANY LICENSE, EXPRESS OR IMPLIED.
ALL INFORMATION IN THIS DOCUMENT IS PROVIDED ON AN “AS-IS”
BASIS WITHOUT GUARANTEE OR WARRANTY OF ANY KIND.
Please contact your nearest Wintec representative for the latest updates or additional product
information.
WintecCF-W7CF-H_v2.10 ROHS
January 2011 Wintec Industries, Inc.
1
TM
32MB – 16-GB
Revision History
Revision
Month
Year
2.0
February
2006
2.1
June
2006
2.2
June
2006
2.3
December
2006
2.4
May
2007
2.5
2.6
2.7
2.8
March
May
October
November
2008
2008
2008
2008
2.9
January
2009
2.10
January
2010
History
-ROHS Spec Release
-Add Title Page & Revision History
-Update Table 28: Identify Drive Information
-Update Table 37: Attribute Memory Read AC Characteristics
-Update Table 38: Attribute Memory Write AC Characteristics
-Update Tables 37~42
-Update Table 43: True IDE Mode I/O Read/Write Timing
-Update Table 44: True IDE DMA Mode I/O Read/Write Timing
-Update Figures 14~19
-Update Figure 20: True IDE Mode I/O Timing Diagram
-Update Figure 21: True IDE DMA Mode I/O Timing Diagram
-Update Table 37 Attribute Memory Read Timing
-Update Table 38 Attribute Memory Write Timing
-Update Table 39 I/O Access Read Timing
-Update Table 41 Common Memory Access Read Timing
-Update DMA pins‟ description, Pin 43 DMARQ and 44 DMACK
-Update Table 7 Layout
-Update new naming scheme for the CF card
-Update Table 48 Ordering Information and naming guide
-Add section 4.1 Labeling and Marking
-Add 16GB capacity to the specification
-Update table 48 with 8GB Real Capacity
-Update table 48 key with firmware options
-Update the ordering information with firmware options
2
TM
32MB – 16-GB
CompactFlashTM Card
INDUSTRIAL GRADE
WxCFxxxA-H Series ROHS 6/6 Compliant
Features
GENERAL
Type I Density up to 16-GB
32-bit RISC/DSP Controller
Solid State Data Storage
Dual 3.3V / 5V Interface
Industry Standard Compatibility
Specialized for High-Reliability
ROHS 6/6 Compliant
PERFORMANCE
True IDE Mode Capable
– PIO Mode 0-4
– DMA Mode 0-2 (Optional)
High Performance 16.7 MB/s Burst
Low Power Consumption
ATA-2 Compliant (w/DMA Enable)
RELIABILITY
> 2,000,000 Program/Erase Cycles
Industrial Wear Leveling
- Includes Static Block Management
Spares & Bad Block Management
On-Board ECC
– Corrects up to 6-bytes/Sector
High Environmental Tolerance
10-Year Data Retention
Unlimited Reads
Wintec Type I CompactFlashTM Card
(PHOTO)
Configuration Options
Industrial Temperature
Fixed / Removable Disk
DMA Mode Enable
Data Programming Service
Custom Labeling
NOTE:
1. See Section 5.0 for Configuration & Ordering Guide
COMPATIBILITY
CFA Spec, Revision 4.1, Feb 2007
PCMCIA PC Card Standard, 7.0, February 1999
PCMCIA PC Card ATA Spec, 7.0, Feb 1999
DESCRIPTION
The Wintec Industries W7CFxxxA-H series of ROHS Compliant Industrial Grade CompactFlashTM Memory Cards are
constructed with Samsung NAND-type single-level-cell (SLC) flash memory devices paired to a powerful 32-bit RISC/DSPbased system controller for virtual-to-physical address mapping and other flash management functions.
Wintec Industrial CompactFlashTM Cards employ a variety of sophisticated error checking and flash management utilities
allowing for maximum levels of data reliability and card endurance. Patented wear-leveling methods ensure even wear of flash
blocks across the entire card capacity. Background operations track erase counts, prioritize new writes to blocks with lower
wear, and relocate static data to blocks with higher wear. Bad-block Management routines replace worn blocks with spare blocks
reserved by the controller on card initialization. Reed-Solomon based ECC algorithms capable of detecting and correcting up to
6 bytes per 512 byte sector are implemented on the fly without performance degradation to ensure data reliability through user
data transfers and background wear-leveling operations. Additional information regarding the specifics of wear leveling, ECC
methods, and application-specific card life calculations are available upon request and under NDA.
Industrial grade reliability, industry standard compatibility, and the ability to emulate IDE hard disk drives make Wintec
CompactFlashTM Cards ideal for industrial, military, and other high endurance applications.
13
TM
32MB – 16-GB
Table of Contents
1.0 General Product Specifications
3
2.0 Card Function Explanation
12
2.1
2.2
Attribute Access
Task File Register Access
2.2.1
2.2.2
2.2.3
2.3
Configuration Register
2.3.1
2.3.2
2.3.3
2.3.4
2.4
Configuration Option Register
Configuration and Status Register
Pin Replacement Register
Socket and Copy Register
Task File Register Specification
2.4.1
2.4.2
2.4.3
2.4.4
2.4.5
2.4.6
2.4.7
2.4.8
2.4.9
2.4.10
2.4.11
2.4.12
2.4.13
2.5
I/O Address Map
Memory Access Map
True IDE Mode
Data Register
Error Register
Feature Register
Sector Count Register
Sector Number Register
Cylinder Low Register
Cylinder High Register
Drive Head Register
Status Register
Alternate Status Register
Command Register
Device Control Register
Drive Address Register
ATA Command Specification
2.5.1
2.5.2
ATA Command Set Description
Sector Transfer Protocol
3.0 Electrical Specification
3.1
3.2
General
DC Characteristics
3.2.1
3.3
3.3.1
3.4
3.5
Current Waveform
AC Characteristics
General
Reset Characteristics
User Notes
13
13
14
15
16
16
17
17
18
18
21
21
22
22
23
23
24
25
26
29
29
32
32
34
34
45
46
4.0 Physical Specifications
47
5.0 Product Guide & Ordering Information
48
2
TM
32MB – 16-GB
For all the following specifications, values are defined at ambient temperature and nominal supply voltage unless otherwise
stated.
Table 1: Performance Specifications
Parameter
Spec
16.6 MB/s
20.0 MB/s
8.0 MB/s
6.0 MB/s
Programmable
50.0 ms
2.5 ms
20 ms
50.0 ms
400.0 ms
Burst Transfer Rate To/From Host
Burst Transfer Rate To/From Flash
Sustained Read (Typical)
Sustained Write (Typical)
Active-to-Sleep Delay
Command-to-DRQ (Max.)
Sleep-to-Write (Max.)
Sleep-to-Read (Max.)
Reset-to-Ready (Typical)
Reset-to-Ready (Max.)
Startup Times
NOTE:
1. All performance figures are based on testing done in True IDE PIO Mode 4.
Table 2: Card Endurance
Parameter
Read Cycles
Data Retention
MTBF
Table 3: Card Data Reliability
Spec
> 2,000,000 Cycles
Unlimited
10 Years (Min.)
> 4,000,000 Hours
Parameter
Non-Recoverable Errors
Erroneous Correction
ECC Correctability
ECC Detectability
Spec
< 1 in 1014 Bytes Read
< 1 in 1020 Bytes Read
6 Bytes/Sector
6 Bytes/Sector
Table 4: Environmental Specifications
Temperature
Parameters
Standard Temp.
Industrial Temp.
Humidity
Vibration
Altitude
Shock
Acoustic
Operating
0C to 70C
-40C to 85C
8% to 95%
(Non-Condensing)
16.3 G rms
80,000 ft. (Max.)
2,000 G (Max.)
0 db
Non-Operating
-55C to 95C
-55C to 95C
8% to 95%
(Non-Condensing)
N/A
Table 5: Power Consumption
Capacity
Sleep (Max)
300
300
300
300
450
450
600
600
600
32MB
64MB
128MB
256MB
512MB
1-GB
2-GB
4-GB
8-GB
Read/Write
(Typical)
40 mA
40 mA
40 mA
40 mA
45.02mA
45.02mA
45.06mA
45.06mA
45.06mA
Read/Write
(Max)
50 mA
50 mA
50 mA
50 mA
60.10mA
60.10mA
60.30mA
60.30mA
60.30mA
NOTE:
1. Input voltage 3.3V (5%) or 5V (10%) with a maximum ripple of 100mV peak-to-peak.
2. All values listed are at 25C and nominal supply voltage.
3. Stated figures are based on primary configurations and may vary as larger density component NAND flashes are released.
3
TM
32MB – 16-GB
Figure 1: Card Block Diagram
NOTE: -CE1, -CE2, -OE, -WE –IORD, -IOWR, -REG, -RESET, -CSEL, -PDIAG, -DASP pins are pulled up in card. –CE1, -CE2, -OE, -WE, -IORD, -IOWR, -REG
pins are Schmitt trigger type input buffer.
4
TM
32MB – 16-GB
Table 6: Card Pin Assignment
PC Card Memory Mode
Pin
Signal
Type
GND
Ground
1
D03
I/O
2
D04
I/O
3
D05
I/O
4
D06
I/O
5
D07
I/O
6
-CE1
I
7
A10
I
8
-OE
I
9
A09
I
10
A08
I
11
A07
I
12
VCC
Power
13
A06
I
14
A05
I
15
A04
I
16
A03
I
17
A02
I
18
A01
I
19
A00
I
D00
I/O
21
D01
I/O
22
D02
I/O
23
WP
O
24
-CD2
O
25
-CD1
O
26
D111
I/O
27
D121
I/O
28
D131
I/O
29
D141
I/O
30
D151
I/O
31
-CE21
I
32
-VS1
O
33
-IORD
I
34
-IOWR
I
35
-WE
I
36
RDY/BSY
O
37
VCC
Power
38
-CSEL
I
39
-VS2
O
40
RESET
I
41
-WAIT
O
42
-INPACK
O
43
-REG
I
44
BVD2
I/O
45
BVD1
I/O
46
D081
I/O
47
D091
I/O
48
D101
I/O
49
GND
Ground
50
NOTE:
1.
2.
3.
Pin
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
PC Card I/O Mode
Signal
Type
GND
Ground
D03
I/O
D04
I/O
D05
I/O
D06
I/O
D07
I/O
-CE1
I
A10
I
-OE
I
A09
I
A08
I
A07
I
VCC
Power
A06
I
A05
I
A04
I
A03
I
A02
I
A01
I
A00
I
D00
I/O
D01
I/O
D02
I/O
-IOIS16
O
-CD2
O
-CD1
O
D111
I/O
D121
I/O
D131
I/O
D141
I/O
D151
I/O
-CE21
I
-VS1
O
-IORD
I
-IOWR
I
-WE
I
IREQ
O
VCC
Power
-CSEL
I
-VS2
O
RESET
I
-WAIT
O
-INPACK
O
-REG
I
-SPKR
I/O
-STSCHG
I/O
D081
I/O
D091
I/O
D101
I/O
GND
Ground
Pin
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
True IDE Mode
Signal
Type
GND
Ground
D03
I/O
D04
I/O
D05
I/O
D06
I/O
D07
I/O
-CS0
I
A102
I
-ATA SEL
I
A092
I
A082
I
A072
I
VCC
Power
A062
I
A052
I
A042
I
A032
I
A02
I
A01
I
A00
I
D00
I/O
D01
I/O
D02
I/O
-IOCS16
O
-CD2
O
-CD1
O
D111
I/O
D121
I/O
D131
I/O
D141
I/O
D151
I/O
-CS11
I
-VS1
O
-IORD
I
-IOWR
I
-WE3
I
INTRQ
O
VCC
Power
-CSEL
I
-VS2
O
RESET
I
IORDY
O
DMARQ
O
-DMACK
I
-DASP
I/O
-PDIAG
I/O
D081
I/O
D091
I/O
D101
I/O
GND
Ground
These signals are required only for 16-bit access and not required when installed in 8-bit systems. For lowest power dissipation, leave these signals open.
Should be grounded by the host.
Should be tied to VCC by the host.
5
TM
32MB – 16-GB
Table 7: Card Pin Explanation
Signal Name
Type
Pin #
A10 - A0
(PC Card Memory Mode)
8, 10, 11, 12, 14 -20
A10 - A0
(PC Card I/O Mode)
Description
These address lines along with the –REG signal are used to
select the following: The I/O port address registers within the
Compact Flash Card, the memory mapped port address
registers within the card, a byte in the card‟s information
structure and its configuration control and status registers.
This signal is the same as the PC Card Memory Mode signal.
I
A2 - A0
(True IDE Mode)
In True IDE Mode only A[2:0] is used to select the one of
eight registers in the Task File.
18, 19, 20
A10 - A3
(True IDE Mode)
In True IDE Mode these remaining address lines should be
BVD1
This signal is asserted high as the BVD1 signal since a
battery is not used with this product.
-STSCHG
(PC Card I/O Mode)
Status Changed
This signal is asserted low to alert the host to changes in the
RDY/ -BSY and Write Protect states, while the I/O interface
is configured. Its use is controlled by the Card Config and
Status Register.
I/O
46
-PDIAG
(True IDE Mode)
In the True IDE Mode, this input/output is the Pass
Diagnostic signal in the Master/Slave handshake protocol.
BVD2
This output line is always driven to a high state in Memory
Mode since a battery is not required for this product.
-SPKR
(PC Card I/O Mode)
I/O
45
This output line is always driven to a high state in I/O Mode
since this product does not support the audio function.
-DASP
(True IDE Mode)
In the True IDE Mode, this input/output is the Disk
Active/Slave Present signal in the Master/Slave handshake
protocol.
-CD1, -CD2
These Card Detect pins are connected to ground on the
Compact Flash Card. They are used by the host to determine
if the card is fully inserted into its socket.
-CD1, -CD2
(PC Card I/O Mode)
O
-CD1, -CD2
(True IDE Mode)
25, 26
This signal is the same for all modes.
6
TM
32MB – 16-GB
Table 7: Card Pin Explanation Cont.
Signal Name
Type
Pin #
I
7, 32
-CE1, -CE2
Card Enable
-CE1, -CE2
(PC Card I/O Mode)
Card Enable
Description
These input signals are used both to select the card and to
indicate to the card whether a byte or a word operation is
being performed. –CE2 always accesses the odd byte of the
word. –CE1 accesses the even byte or the Odd byte of the
word depending on A0 and –CE2. A multiplexing scheme
based on A0, -CE1, -CE2 allows 8 bit hosts to access all
data on D0 -D7.
-CS0, -CS1
(True IDE Mode)
In the True IDE Mode –CS0 is the chip select for the task file
registers while –CS1 is used to select the Alternate Status
Register and the Device Control Register.
-CSEL
This signal is not used for this mode.
-CSEL
(PC Card I/O Mode)
I
39
-CSEL
(True IDE Mode)
This internally pulled up signal is used to configure this
device as a Master or a Slave when configured in the True
IDE Mode. When this pin is grounded, this device is
configured as a Master. When this pin is open, this device is
configured as a Slave.
D15 - D00
These lines carry the Data, Commands and Status
information between the host and the controller. D00 is the
LSB of the Even Byte of the Word. D08 is the LSB of the
Odd Byte of the Word.
D15 - D00
(PC Card I/O Mode)
I/O
2-6, 21, 22, 23,
27-31, 47, 48, 49
These signals are the same as the PC Card Memory Mode
signal.
D15 - D00
(True IDE Mode)
In True IDE Mode all Task File operations occur in byte
mode on the low order bus D00 -D07 while all data transfers
are 16 bits using D00 -D15.
GND
Ground.
GND
(PC Card I/O Mode)
GND
(True IDE Mode)
1, 50
7
TM
32MB – 16-GB
-INPACK
This signal is not used in this mode.
-INPACK
(PC Card I/O Mode)
Input Acknowledge
The Input Acknowledge signal is asserted by the Compact
Flash Card when the card is selected and responding to an I/O
read cycle at the address that is on the address bus. This
signal is used by the host to control the enable of any input
data buffers between the card and the CPU.
This signal is a DMA Request that is used for DMA data
transfers between host and device. It shall be asserted by the
device when it is ready to transfer data to or from the host.
For Multiword DMA transfers, the direction of data transfer
is controlled by DIOR- and DIOW-.This signal is used in a
handshake manner with DMACK- before negating
DMAREQ, and reasserting DMAREQ if there is more data to
transfer.
O
43
DMAREQ shall not be driven when the device is not
selected.
While a DMA operation is in progress, -CS0 and –CS1 shall
be held negated and the width of the transfers shall be 16 bits.
DMARQ
(True IDE Mode)
If there is no hardware support for DMA mode in the host,
this output signal is not used and should not be connected at
the host .In this case, the BIOS must report that DMA mode
is not supported by the host so that the device driver will not
attempt DMA mode.
A host that does not support DMA mode and implements
both PCMCIA and true-IDE modes of operation need not
alter the PCMICIA mode connections while in True-IED
mode as long as this does not prevent proper operation in any
mode.
-IORD
-IORD
(PC Card I/O Mode)
I
-IORD
(True IDE Mode)
34
This is an I/O Read strobe generated by the host. This signal
gates I/O data onto the bus from the Compact Flash Card
when the card is configured to use the I/O interface.
In True IDE Mode, this signal has the same function as in PC
Card I/O Mode.
8
TM
32MB – 16-GB
Signal Name
Type
Pin #
Description
-IOWR
- IOWR
(PC Card I/O Mode)
The I/O Write strobe pulse is used to clock I/O data on the
Card Data bus into the Compact Flash controller registers
The clocking will occur on the negative to positive edge of
the signal (trailing edge).
I
35
- IOWR
(True IDE Mode)
Card I/O Mode.
-OE
This is an Output Enable strobe generated by the host
interface. It is used to read data from the Compact Flash Card
in Memory Mode and to read the CIS and configuration
registers.
-OE
(PC Card I/O Mode)
I
9
-ATA SEL
(True IDE Mode)
In PC Card I/O Mode, this signal is used to read the CIS and
configuration registers.
To enable True IDE Mode this input should be grounded by
the host.
In Memory Mode this signal is set high when the Compact
Flash Card is ready to accept a new data transfer operation
and held low when the card is busy. The host memory card
socket must provide a pull-up resistor.
RDY/-BSY
O
- IREQ
(PC Card I/O Mode)
-INTRQ
(True IDE Mode)
37
At power up and at Reset, the RDY/-BSY signal is held low
(busy) until the Compact Flash Card has completed its power
up or reset function. The RDY/-BSY signal is held high
(disabled from being busy) whenever the following condition
is true: The Compact Flash Card has been powered up with
+RESET continuously disconnected or asserted.
I/O Operation – After the Compact Flash Card has been
configured for I/O operation, this signal is used as – Interrupt
Request. This line is strobed low to generate a pulse mode
interrupt or held low for a level mode interrupt.
In True IDE Mode, this signal is the active high Interrupt
Request to the host.
9
TM
32MB – 16-GB
Signal Name
Type
Pin #
-REG
Attribute Memory Select
Description
This signal is used during Memory Cycles to distinguish
between Common Memory and Register (Attribute) Memory
accesses. High for Common Memory, Low for Attribute
Memory.
The signal must also be active (low) during I/O Cycles when
the I/O address is on the Bus.
-REG
(PC Card I/O Mode)
This is a DMA Acknowledge signal that is asserted by the
host in response to DMAREQ to initiate DMA transfers.
I
44
While DMA operations are not active, the card shall ignore
the –DMACK signal, including a floating condition.
If DAM operation is not supported by a True-IDE Mode only
host, this signal should be driven high or connected to VCC
by the host.
-DMACK
(True IDE Mode)
both PCMCIA and True-IDE modes of operation need not
alter the PCMCIA mode connections while in True-IDE
mode as long as this does not prevent proper operation all
modes.
-RESET
I
41
-RESET
(PC Card I/O Mode)
In the True IDE Mode this input pin is the active low
hardware reset from the host.
-RESET
(True IDE Mode)
VCC
VCC
(PC Card I/O Mode)
When the pin is high, this signal resets the Compact Flash
Card. The card is Reset only at power up if this pin is left
high or open from power-up. The card is also reset when the
Soft Reset bit in the Card Configuration Option Register is
set.
+5, +3.3V power.
13, 38
VCC
(True IDE Mode)
-VS1, -VS2
Voltage Sense Signals. –VS1 is grounded so that the
Compact Flash Card CIS can be read at 3.3 volts and –VS2 is
open and reserved by PCMCIA for a secondary voltage.
-VS1, -VS2
(PC Card I/O Mode)
O
-VS1, -VS2
(True IDE Mode)
33, 40
10
TM
32MB – 16-GB
Signal Name
Type
Pin #
-WAIT
-WAIT
(PC Card I/O Mode)
Description
This signal is not asserted for all modes.
O
42
-IORDY
(True IDE Mode)
-WE
This is a signal driven by the host and used for strobing
memory write data to the registers of the Compact Flash Card
when the card is configured in the memory interface mode. It
is also used for writing the configuration registers.
-WE
(PC Card I/O Mode)
I
36
In PC Card I/O Mode, this signal is used for writing the
-WE
(True IDE Mode)
In True IDE Mode this input signal is not used and should be
connected to VCC by the host.
-WP
Memory Mode – The Compact Flash Card does not have a
write protect switch. This signal is held low after the
completion of the reset initialization sequence.
-IOIS16
(PC Card I/O Mode)
I/O Operation – When the Compact Flash Card is configured
for I/O Operation, Pin 24 is used for the –I/O Selected is 16
Bit Port (-IOIS16) function. A Low signal indicates that a 16
bit or odd byte only operation can be performed at the
addressed port.
O
-IOCS16
(True IDE Mode)
24
In True IDE Mode this output signal is asserted low when
this device is expecting a word data transfer cycle.
11
TM
32MB – 16-GB
2.1
Attribute Access Specifications
When CIS-ROM region or Configuration register region is accessed, read and write operations are executed under the condition
of –REG = “L” as follows. That region can be accessed by Byte/Word/Odd-byte modes, which are defined by PC card standard
specifications.
Table 8: Attribute Read Access Mode
Mode
Standby mode
Byte access (8-bit)
Word access (16-bit)
Odd byte access (8-bit)
-REG
L
L
L
L
-CE2
H
H
H
L
L
-CE1
A0
-OE
-WE
L
L
L
H
L
H
L
L
L
L
H
H
H
H
-CE2
H
H
H
L
L
-CE1
A0
-OE
-WE
L
L
L
H
L
H
H
H
H
H
L
L
L
L
D8 -D15
High-Z
High-Z
High-Z
Invalid
Invalid
D0 -D7
High-Z
Even byte
Invalid
Even byte
High-Z
D8 -D15
Don‟t care
Don‟t care
Don‟t care
Don‟t care
Don‟t care
D0 -D7
Don‟t care
Even byte
Don‟t care
Even byte
Don‟t care
Table 9: Attribute Write Access Mode
Mode
Standby mode
Byte access (8-bit)
-REG
L
L
L
L
Figure 2: Attribute Access Timing Example
12
TM
32MB – 16-GB
2.2
Task File Register Access Specifications
There are two cases of Task File register mapping, one is mapped I/O address area, and the other is mapped Memory address
area. Each case of Task File register read and write operations are executed under the condition as follows. That area can be
accessed by Byte/Word/Odd Byte modes, which are defined by PC card standard specifications.
2.2.1 I/O Address Map
Table 10: Task File Register Read Access Mode (i)
Mode
Standby mode
Byte access (8-bit)
-REG -CE2 -CE1
H
L
H
L
L
H
L
L
L
L
L
L
H
A0
L
H
-IORD -IOWR
L
L
L
L
H
H
H
H
-OE -WE
H
H
H
H
H
H
H
H
D8 -D15
High-Z
High-Z
High-Z
Odd byte
Odd byte
D0 -D7
High-Z
Even byte
Odd byte
Even byte
High-Z
D8 -D15
Don‟t care
Don‟t care
Don‟t care
Odd byte
Odd byte
D0 -D7
Don‟t care
Even byte
Odd byte
Even byte
Don‟t care
Table 11: Task File Register Write Access Mode (i)
Mode
Standby mode
Byte access (8-bit)
-REG -CE2 -CE1
H
L
H
L
L
H
L
L
L
L
L
L
H
A0
L
H
-IORD -IOWR
H
H
H
H
L
L
L
L
-OE -WE
H
H
H
H
H
H
H
H
Figure 3: Task File Register Access Timing Example (i)
13
TM
32MB – 16-GB
2.2.2 Memory Address Map
Task File Register Read Access Mode (ii)
Mode
Standby mode
Byte access (8-bit)
-REG -CE2 -CE1
H
H
H
L
H
H
L
H
L
L
H
L
H
A0
L
H
-IORD -IOWR
L
L
L
L
H
H
H
H
-OE -WE
H
H
H
H
H
H
H
H
D8 -D15
High-Z
High-Z
High-Z
Odd byte
Odd byte
D0 -D7
High-Z
Even byte
Odd byte
Even byte
High-Z
D8 -D15
Don‟t care
Don‟t care
Don‟t care
Odd byte
Odd byte
D0 -D7
Don‟t care
Even byte
Odd byte
Even byte
Don‟t care
Table 13: Task File Register Write Access Mode (ii)
Mode
Standby mode
Byte access (8-bit)
-REG -CE2 -CE1
H
H
H
L
H
H
L
H
L
L
H
L
H
A0
L
H
-IORD -IOWR
H
H
H
H
L
L
L
L
-OE -WE
H
H
H
H
H
H
H
H
Figure 4: Task File Register Access Timing Example (ii)
14
TM
32MB – 16-GB
2.2.3 True IDE Mode
The card can be configured in a True IDE Mode of operation. This card is configured in this mode only when the –OE input
signal is asserted GND by the host. In this True IDE Mode Attribute Registers are not accessible from the host. Only I/O
operation to the task files and data registers are allowed. If this card is configured during power on sequence, data registers are
accessed in word (16-bit). The card permits 8-bit accesses if the user issues a Set Feature Command to put the device in 8-bit
mode.
Table 14: True IDE Mode Read I/O Function
Mode
Invalid mode
Standby mode
Data register access
Alternate status access
Other task file access
-CE2
L
H
H
L
H
-CE1
L
H
L
H
L
A0 -A2
-IORD
-IOWR
6H
1-7H
L
L
L
H
H
H
A0 -A2
-IORD
-IOWR
6H
1-7H
L
L
L
H
H
H
D8 -D15
High-Z
High-Z
Odd byte
High-Z
High-Z
D0 -D7
High-Z
High-Z
Even byte
Status out
Data
D8 -D15
Don‟t care
Don‟t care
Odd byte
Don‟t care
Don‟t care
D0 -D7
Don‟t care
Don‟t care
Even byte
Control in
Data
Table 15: True IDE Mode Write I/O Function
Mode
Invalid mode
Standby mode
-CE2
L
H
H
L
H
-CE1
L
H
L
H
L
Figure 5: True IDE Mode I/O Access Timing Example
15
TM
32MB – 16-GB
2.3
Configuration Register Specification
This card supports four configuration registers for the purpose of the configuration and observation of this card. These registers
can be used in memory card mode and I/O card mode. In True IDE mode, these registers cannot be used.
2.3.1 Configuration Option register (Address 200H)
This register is used for setting the card configuration status and for issuing soft reset to the card.
bit 7
SRESET
NOTE:
1.
bit 6
LevlREQ
bit 5
INDEX
bit 4
bit 3
bit 2
bit 1
bit 0
Initial value: 00H
Table 17: Option Register Function
Name
R/W
Function
Setting this bit to “1”, places the card in the reset state (Card Hard Reset). This
operation is equal to Hard Reset, except this bit is not cleared. Then this bit set to
“0”, places the card in the reset state of Hard Reset (This bit is set to “0” by Hard
Reset). Card configuration status is reset and the card internal initialized operation
starts when Card hard Reset is executed, so next access to the card should be the
same sequence as the power on sequence.
SRESET (HOST->)
R/W
LevlREQ (HOST->)
R/W
This bit sets to “0” when pulse mode interrupt is selected, and “1” when level mode
interrupt is selected.
INDEX (HOST->)
R/W
This bit is used for select operation mode of the card as follows. When Power on,
Card Hard Reset and Soft Reset, this data is “000000” for the purpose of Memory
card interface recognition.
Table 18: INDEX bit assignment
5
INDEX Bit
3
2
1
Task File register address
Mapping mode
0H to FH, 400H to 7FFH
xx0H to xxFH
1F0H to 1F7H, 3F6H to 3F7H
170H to 177H, 376H to 377H
Memory Mapped
Contiguous I/O Mapped
Primary I/O Mapped
Secondary I/O Mapped
16
TM
32MB – 16-GB
2.3.2 Configuration and Status Register (Address 202H)
This register is used for observing the card state.
bit 7
CHGED
bit 6
SIGCHG
bit 5
IOIS8
bit 4
bit 3
bit 2
PWD
bit 1
INTR
bit 0
NOTE:
1. 1nitial value: 00H
Table 19: Configuration and Status Register Function
Name
R/W
CHGED (HOST->)
R
SIGCHG (HOST->)
R/W
IOIS8 (HOST->)
R/W
PWD (HOST->)
R/W
INTR (HOST->)
R
Function
This bit indicates that CRDY/-BSY bit on Pin Replacement register is set to “1”.
When CHGED bit is set to “1”, -STSCHG pin is held “L” at the condition of
SIGCHG bit set to “1” and the card configured for the I/O interface.
This bit is set or reset by the host for enabling and disabling the status-change signal
(-STSCHG pin). When the card is configured I/O card interface and this bit is set to
“1”, -STSCHG pin is controlled by CHGED bit. If this bit is set to “0”, -STSCHG
pin is kept “H”.
The host sets this field to “1” when it can provide I/O cycles only with one 8-bit
data bus (D7 to D0).
When this bit is set to “1”, the card enters sleep stat (Power Down mode). When
this bit is reset to “0”, the card transfers to idle state (active mode). RRDY/-BSY bit
on Pin Replacement Register becomes BUSY when this bit is changed. RRDY/BSY will not become Ready until the power state requested has been entered. This
card automatically powers down when it is idle, and powers back up when it
receives a command.
This bit indicates the internal state of the interrupt request. This bit state is available
whether I/O card interface has been configured or not. This signal remains true until
the condition which caused the interrupt request has been serviced. If interrupts are
disabled by the –IEN bit in the Device Control Register, this bit is a zero.
2.3.3 Pin Replacement Register (Address 204H)
This register is used for providing the signal state of –IREQ signal when the card configured I/O card interface.
bit 7
bit 6
bit 5
CRDY/-BSY
bit 4
bit 3
1
bit 2
1
bit 1
RRDY/-BSY
bit 0
NOTE:
1. Initial value 0CH
Table 20: Pin Replacement Register Function
Name
R/W
CRDY/-BSY (HOST->)
R/W
RRDY/-BSY (HOST->)
R/W
Function
This bit is set to “1” when the RRDY/-BSY bit changes state. This bit may also be
written by the host
When read, this bit indicates +READY pin states. When written, this bit is used for
CRDY/-BSY bit masking
17
TM
32MB – 16-GB
2.3.4 Socket and Copy Register (Address 206H)
This register is used for identification of the card from the other cards. Host can read and write this register. This register should
be set by host before Configuration Option register is set.
bit 7
bit 6
bit 5
bit 4
DRV#
bit 3
bit 2
bit 1
bit 0
NOTE:
1. Initial value: 00H
Table 21: Socket and Copy Register Function
Name
R/W
DRV# (HOST->)
2.4
Function
This field are used for the configuration of the plural cards. When host configures
the plural cards, written the card‟s copy number in this field. In this way, host can
perform the card‟s master/slave organization.
R/W
These registers are used for reading and writing the storage data in the card. These registers are mapped five types by the
configuration of INDEX in Configuration Option register. The decoded addresses are shown as follows.
Table 22: Memory map (INDEX=0)
-REG
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
A10
1
A9 -A4
A3
1
1
1
1
1
A2
1
1
1
1
1
A1
1
1
1
1
1
A0
1
Offset
0H
1H
2H
3H
4H
5H
6H
7H
8H
9H
DH
EH
FH
8H
9H
-OE=L
Data register
Error register
Sector count register
Sector number register
Cylinder low register
Cylinder high register
Drive head register
Status register
Dup. even data register
Dup. odd data register
Dup. error register
Alt. status register
Drive address register
Even data register
Odd data register
-WE=L
Data register
Feature register
Drive head register
Command register
Dup. feature register
Device control register
Reserved
Even data register
Odd data register
Table 23: Contiguous I/O map (INDEX=1)
-REG
A10 -A4
A3
1
1
1
1
A2
1
1
1
1
1
A1
1
1
1
A0
1
Offset
0H
1H
2H
3H
4H
5H
6H
7H
8H
9H
DH
EH
FH
-IORD=L
Data register
Error register
Drive head register
Status register
Dup. error register
-IOWR=L
Data register
Feature register
Drive head register
Command register
Reserved
18
TM
32MB – 16-GB
Table 24: Primary I/O Map (INDEX=2)
-REG
A10
A9 -A4
1FH
1FH
1FH
1FH
1FH
1FH
1FH
1FH
3FH
3FH
A3
A2
1
1
1
1
1
A1
1
1
1
1
A0
-IORD=L
Data register
Error register
Drive head register
Status register
-IOWR=L
Data register
Feature register
Drive head register
Command register
Reserved
A2
1
1
1
1
1
A1
1
1
1
1
A0
-IORD=L
Data register
Error register
Drive head register
Status register
-IOWR=L
Data register
Feature register
Drive head register
Command register
Reserved
Table 25: Secondary I/O Map (INDEX=3)
-REG
A10
A9 -A4
17H
17H
17H
17H
17H
17H
17H
17H
37H
37H
A3
Table 26: True IDE Mode I/O Map
-CE2
1
1
1
1
1
1
1
1
-CE1
1
A2
1
1
1
1
1
A1
1
1
1
1
A0
-IORD=L
Data register
Error register
Drive head register
Status register
-IOWR=L
Data register
Feature register
Drive head register
Command register
Reserved
19
TM
32MB – 16-GB
2.4.1 Data Register
This register is a 16-bit register that has read/write ability, and it is used for transferring 1 sector data between the card and the
host. This register can be accessed in word mode and byte mode. This register overlaps the Error and Feature register.
bit 15 bit 14 bit 13 bit 12 bit 11 bit 10
bit 9
bit 8 bit 7
D0 to D15
bit 6
bit 5
bit 4
bit 3
bit 2
bit 1
bit 0
2.4.2 Error Register
This register is a read only register, and is used for analyzing the error content during card accessing. This register is valid when
the BSY bit in Status Register and Alternate Status Register are set to “0” (Ready).
bit 7
BBK
bit
7
6
4
2
bit 6
UNC
bit 5
“0”
Name
BBK (Bad BlocK detected)
UNC (Data ECC error)
IDNF (ID Not Found)
ABRT (AboRTed command)
AMNF (Address Mark Not Found)
bit 4
IDNF
bit 3
“0”
bit 2
ABRT
bit 1
„0‟
bit 0
AMNF
Function
This bit is set when a Bad Block is detected in requested ID field.
This bit is set when Uncorrectable error is occurred at reading the card.
The requested sector ID is in error or cannot be found.
This bit is set if the command has been aborted because of the card
status condition. (Not ready, Write fault, Invalid command, etc.)
This bit is set in case of a general error.
2.4.3 Feature Register
This register is a write only register, and provides information regarding features of the drive, which the host wishes to utilize.
bit 7
bit 6
bit 5
bit 4
bit 3
Feature byte
bit 2
bit 1
bit 0
2.4.4 Sector Count Register
This register contains the numbers of sectors of data requested to be transferred on a read or write operation between the host and
the card. If the value of this register is zero, a count of 256 sectors is specified. In plural sector transfer, if not successfully
completed, the register contains the number of sectors, which need to be transferred in order to complete, the request. This
register‟s initial value is “01H”.
bit 7
bit 6
bit 5
bit 4
bit 3
Sector count byte
bit 2
bit 1
bit 0
2.4.5 Sector Number Register
This register contains the starting sector number, which is started by following sector transfer command.
bit 7
bit 6
bit 5
bit 4
bit 3
Sector number byte
bit 2
bit 1
bit 0
2.4.6 Cylinder Low Register
This register contains the low 8-bit of the starting cylinder address, which is started by following sector transfer command.
bit 7
bit 6
bit 5
bit 4
bit 3
Cylinder low byte
bit 2
bit 1
bit 0
TM
32MB – 16-GB
2.4.7 Cylinder High Register
This register contains the high 8-bit of the starting cylinder address, which is started by following sector transfer command.
bit 7
bit 6
bit 5
bit 4
bit 3
Cylinder high byte
bit 2
bit 1
bit 0
bit 1
bit 0
2.4.8 Drive Head Register
This register is used for selecting the Drive number and head number for the following command.
bit 7
1
bit 6
LBA
bit 5
1
bit 4
DRV
bit 3
Head #
bit 2
NOTE:
1. DRV: Drive number
bit
7
Name
1
6
LBA
5
1
4
DRV (DRiVe select)
3 -0
Head number
Function
This bit is set to “1”.
LBA is a flag to select either Cylinder / Head / Sector (CHS) or Logical Block
Address (LBA) mode. When LBA = 0, CHS mode is selected. When LBA = 1, LBA
mode is selected. In LBA mode, the Logical Block Address is interrupted as follows:
LBA07 - LBA00: Sector Number Register D7 - D0.
LBA15 - LBA08: Cylinder Low Register D7 - D0.
LBA23 - LBA16: Cylinder High Register D7 - D0.
LBA27 - LBA24: Drive / Head Register bits HS3 - HS0.
This bit is used for selecting the Master (Card 0) and Slave (Card 1) in Master/Slave
organization. The card is set to be Card 0 or 1 by using DRV# of the Socket and Copy
register.
This bit is used for selecting the Head number for the following command. Bit 3 is
MSB.
2.4.9 Status Register
This register is read only register, and it indicates the card status of command execution. When this register is read in configured
I/O card mode (INDEX = 1, 2, 3) and level interrupt mode, -IREQ is negated. This register should be accessed in byte mode. In
word mode, it is recommended that Alternate status register may be used as this register.
bit 7
BSY
bit
bit 6
DRDY
bit 5
DWF
Name
7
BSY (BuSY)
6
DRDY (Drive ReaDY)
5
4
DWF (Drive Write Full)
DSC (Drive Seek Complete)
3
DRQ (Data ReQuest)
2
CORR (CORRected data)
1
IDX (InDeX)
ERR (ERRor)
bit 4
DSC
bit 3
DRQ
bit 2
CORR
bit 1
IDX
bit 0
ERR
Function
This bit is set when the card internal operation is executing. When this bit is set
to “1”, other bits in this register are invalid.
If this bit and DSC bit are set to “1”, the card is capable of receiving the read
or write or seek requests. If this bit is set to “0”, the card prohibits these
requests.
This bit is set if this card indicates the write fault status.
This bit is set when the drive seek complete.
This bit is set when the information can be transferred between the host and
Data register. This bit is cleared when the card receives the other command.
This bit is set when a correctable data error has been occurred and the data has
been corrected.
This bit is always set to “0”.
This bit is set when the previous command has ended in some type of error.
The error information is set in the other Status register or Error register. This
bit is cleared by the next command.
21
TM
32MB – 16-GB
2.4.10 Alternate Status Register
This register is the same as Status register in physically, so the it assignment refers to previous item of Status register. But this
register is different from Status register that –IREQ is not negated when data read.
2.4.11 Command Register
This register is write only register, and it is used for writing the command at executing the drive operation. The command code
written in the command register, after the parameter is written in the Task File during the card is Ready state.
Command
Command Code
Check power mode
Execute drive diagnostic
Erase sector
Format track
Identify Drive
Idle
Idle immediate
Initialize drive parameters
Read buffer
Read multiple
Read long sector
Read sector
Read verify sector
Recalibrate
Request sense
Seek
Set features
Set multiple mode
Set sleep mode
Stand by
Stand by immediate
Translate sector
Wear level
Write buffer
Write long sector
Write multiple
Write multiple w/o erase
Write sector
Write sector w/o erase
Write verify
E5H or 98H
90H
C0H
50H
ECH
E3H or 97H
E1H or 95H
91H
E4H
C4H
22H or 23H
20H or 21H
40H or 41H
1XH
03H
7XH
EFH
C6H
E6H or 99H
E2H or 96H
E0H or 94H
87H
F5H
E8H
32H or 33H
C5H
CDH
30H or 31H
38H
3CH
FR
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
N
Y
N
N
N
N
N
N
N
N
N
N
N
N
N
SC
N
N
Y
Y
N
Y
N
Y
N
Y
N
Y
Y
N
N
N
N
Y
N
N
N
Y
N
N
N
Y
Y
Y
Y
Y
SN
N
N
Y
N
N
N
N
N
N
Y
Y
Y
Y
N
N
Y
N
N
N
N
N
Y
N
N
Y
Y
Y
Y
Y
Y
Used Parameter
CY
DR
HD
N
Y
N
N
Y
N
Y
Y
Y
Y
Y
Y
N
Y
N
N
Y
N
N
Y
N
N
Y
Y
N
Y
N
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
N
Y
N
N
Y
N
Y
Y
Y
N
Y
N
N
Y
N
N
Y
N
N
Y
N
N
Y
N
Y
Y
Y
N
Y
Y
N
Y
N
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
LBA
N
N
Y
Y
N
N
N
N
N
Y
Y
Y
Y
N
N
Y
N
N
N
N
N
Y
N
N
Y
Y
Y
Y
Y
Y
NOTE:
FR: Feature register
SC: Sector Count register
SN: Sector Number register
CY: Cylinder register
DR: DRV bit of Drive Head register
HD: Head Number of Drive Head register
LBA: Logical Block Address Mode Supported
Y: The register contains a valid parameter for this command
N: The register does not contain a valid parameter for this command.
22
TM
32MB – 16-GB
2.4.12 Device Control Register
This register is write only register, and it is used for controlling the card interrupt request and issuing an ATA soft reset to the
card.
bit7
bit6
bit5
bit
7 -4
3
Name
2
SRST (Software ReSeT)
1
nIEN (Interrupt ENable)
bit4
bit3
1
bit2
SRST
bit1
nIEN
bit0
Function
Don‟t care
This bit is set to “1” in order to force the card to perform Task File Reset operation.
This does not change the Card Configuration registers as a Hardware Reset does. The
card remains in Reset until this bit is reset to “0”.
This bit is used for enabling –IREQ. When this bit is set to “0”, –IREQ is enabled.
When this bit is set to “1”, –IREQ is disabled.
This bit is set to “0”.
2.4.13 Drive Address Register
This register is read only register, and it is used for confirming the drive status. This register is provided for compatibility with
the AT disk drive interface. It is recommended that this register be not mapped into the host‟s I/O space because of potential
conflicts on bit7.
bit 7
bit
7
6
5 -2
1
bit 6
nWTG
bit 5
nHS3
Name
nWTG (WriTing Gate)
nHS3 -0(Head Select3 0)
nDS1 (Idrive Select1)
nDS0 (Idrive Select0)
bit 4
nHS2
bit 3
nHS1
bit 2
nHS0
bit 1
nDS1
bit 0
nDS0
Function
This bit is unknown.
These bits are the negative value of Head Select bits (bit 3 to 0) in Drive/Head
register.
23
TM
32MB – 16-GB
2.5
This table summarizes the ATA command set with the paragraphs. Following shows the support commands and command codes,
which are written in, command registers.
Table 27: ATA Command Set
No.
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
Command
Check power mode
Erase sector
Format track
Identify Drive
Idle
Idle immediate
Read buffer
Read multiple
Read long sector
Read sector
Read verify sector
Recalibrate
Request sense
Seek
Set features
Set multiple mode
Set sleep mode
Stand by
Stand by immediate
Translate sector
Wear level
Write buffer
Write long sector
Write multiple
Write sector
Write verify
Command Code
E5H or 98H
90H
C0H
50H
ECH
E3H or 97H
E1H or 95H
91H
E4H
C4H
22H, 23H
20H, 21H
40H, 41H
1XH
03H
7XH
EFH
C6H
E6H or 99H
E2H or 96H
E0H or 94H
87H
F5H
E8H
32H or 33H
C5H
CDH
30H or 31H
38H
3CH
FR
Y
SC
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
SN
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
CY
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
DR
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
HD
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
LBA
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
Y
NOTE:
SC: Sector Count register (00H to FFH)
SN: Sector Number register (01H to 20H)
CY: Cylinder register (to)
HD: Head No. (0 to 3) of Drive Head register
NH: No. of Heads
Y: Set up
- : Not Set up
24
TM
32MB – 16-GB
2.5.1 ATA Command Set Description
1.
2.
3.
4.
5.
Check Power Mode (code: E5H or 98H): This command checks the power mode.
Execute Drive Diagnostic (code: 90H): This command performs the internal diagnostic tests implemented by the Card.
Erase Sector(s) (code: C0H): This command is used to erase data sectors.
Format Track (code: 50H): This command writes the desired head and cylinder of the selected drive. But selected sector data
is not exchanged. This card accepts a sector buffer of data from the host to follow the command with same protocol as the
Write Sector command.
Identify Drive (code: ECH): This command enables the host to receive parameter information from the Card.
Word
Address
Default
Value
Total Bytes
848Ah
2
1
2
3
4
5
6
7 -8
9
10 -19
22
23 -26
27-46
47
48
XXXX
0000h
00XXh
0000h
XXXX
XXXX
XXXX
0000h
aaaa
0002h
0002h
0004h
aaaa
aaaa
0001h
0000h
2
2
2
2
2
2
4
2
2
2
8
40
2
2
49
0200h
2
50
51
52
53
54
55
56
57-58
59
60 -61
62
0000h
0200h
0000h
0003h
XXXXh
XXXXh
XXXXh
XXXXh
010Xh
XXXX
0000h
2
2
2
2
2
2
2
4
2
4
2
63
0000h
2
64
65
0003h
0000h
2
2
Data Field Type Information
General Configuration:
848Ah: Removable Disk (Default)
044Ah: Fixed Disk (Option)
Number of cylinders
Reserved
Number of heads
Number of unformatted bytes per track
Number of unformatted bytes per sector
Number of sectors per track
Number of sectors per card (Word 7 = MSW, Word 8 = LSW)
Reserved
Serial Number in ASCII (Right Justified)
Buffer type: Dual ported multi-sector
Buffer size in 512 byte increments
# of ECC bytes passed on Read/Write Long Commands
Firmware revision in ASCII. Big Endian Byte Order in Word
Model number in ASCII (Left Justified) Big Endian Byte Order in Word
Maximum of 1 sector on Read/Write Multiple command
Double Word not supported
Capabilities:
Bit 9: LBA Supported
Reserved
PIO data transfer cycle timing mode 2
DMA data transfer cycle timing mode (Not Supported)
Field validity
Current number of cylinders
Current number of heads
Current sectors per track
Current capacity in sectors (LBAs) (Word 57 = LSW, Word 58 = MSW)
Multiple Sector Setting is valid
Total number of sectors addressable in LBA Mode
Reserved
Multiword DMA Transfer:
0000h: Not Supported
Advanced PIO Modes supported
Minimum DMA transfer cycle time per word
25
TM
32MB – 16-GB
66
67
68
69-127
128-159
160-255
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
0000h
0078h
0078h
XXXXh
0000h
0000h
2
2
2
130
64
192
Recommended DMA transfer cycle time.
Minimum PIO transfer cycle time without flow control
Minimum PIO transfer cycle time with IORDY flow control
Reserved
Reserved Vendor Unique Bytes
Reserved
Idle (code: E3H or 97H): This command causes the PC Card to set BSY, enter the Idle mode, clear BSY and generate an
interrupt. If sector count is non-zero, the automatic power down mode is enabled. If the sector count is zero, the automatic
power down mode is disabled.
Idle Immediate (code: E1H or 95H): This command causes the Card to set BSY, enter the Idle (Read) mode, clear BSY and
generate an interrupt.
Initialize Drive Parameters (code: 91H): This command enables the host to set the number of sectors per track and the
number of heads per cylinder.
Read Buffer (code: E4H): This command enables the host to read the current contents of the PC card‟s sector buffer.
Read Multiple (code: C4H): This command performs similarly to the Read Sectors command. Interrupts are not generated
on each sector, but on the transfer of a block, which contains the number of sectors defined by a Set Multiple command.
Read Long Sector (code: 22H, 23H): This command performs similarly to the Read Sector(s) command except that it returns
516 bytes of data instead of 512 bytes.
Read Sector(s) (code: 20H, 21H): This command reads from 1 to 256 sectors as specified in the Sector Count register. A
sector count of 0 requests 256 sectors. The transfer begins at the sector specified in the Sector Number register.
Read Verify Sector(s) (code: 40H, 41H): This command is identical to the Read Sectors command, except that DRQ is never
set and no data is transferred to the host.
Recalibrate (code: 1XH): This command is effectively a NOP command to the Card and is provided for compatibility
purposes.
Request Sense (code: 03H): This command requests an extended error code after command ends with an error.
Seek (code: 7XH): This command is effectively a NOP command to the Card although it does perform a range check.
Set Features (code: EFH): This command is used by the host to establish or select certain features.
Feature
01H
55H
66H
81H
BBH
CCH
Operation
Enable 8-bit data transfers.
Disable Read Look Ahead.
Disable Power on Reset (POR) establishment of defaults at Soft Reset.
Disable 8-bit data transfer.
4 bytes of data apply on Read/Write Long commands.
Enable Power on Reset (POR) establishment of defaults at Soft Reset.
18. Set Multiple Mode (code: C6H): This command enables the Card to perform Read and Write Multiple operations and
establishes the block count for these commands.
19. Set Sleep Mode (code: E6H or 99H): This command causes the Card to set BSY, enter the Sleep mode, clear BSY and
20. Stand By (code: E2H or 96H): This command causes the Card to set BSY, enter the Sleep mode (which corresponds to the
ATA “Standby” Mode), clear BSY and return the interrupt immediately.
21. Stand By Immediate (code: E0H or 94H): This command causes the Card to set BSY, enter the Sleep mode (which
corresponds to the ATA “Standby” Mode), clear BSY and return the interrupt immediately.
22. Translate Sector (code: 87H): This command allows the host a method of determining the exact number of times a user
sector has been erased and programmed.
23. Wear level (code: F5H): This command is effectively a NOP command and only implemented for backward compatibility.
The Sector Count Register will always be returned with a 00H indicating Wear Level is not needed.
26
TM
32MB – 16-GB
24. Write Buffer (code: E8H): This command enables the host to overwrite contents of the Card‟s sector buffer with any data
pattern desired.
25. Write Long Sector (code: 32H or 33H): This command is provided for compatibility purposes and is similar to the Write
Sector(s) command except that it writes 516 bytes instead of 512 bytes.
26. Write Multiple (code: C5H): This command is similar to the Write Sector command. Interrupts are not presented on each
sector, but on the transfer of a block, which contains the number of sectors defined by Set Multiple command.
27. Write Multiple without Erase (code: CDH): This command is similar to the Write Multiple command with the exception that
an implied erase before write operation is not performed.
28. Write Sector(s) (code: 30H or 31H): This command writes from 1 to 256 sectors as specified in the Sector Count register. A
sector count of zero requests 256 sectors. The transfer begins at the sector specified in the Sector Number register.
29. Write Sector(s) without Erase (code: 38H): This command is similar to the Write Sector(s) command with the exception that
30. Write Verify (code: 3CH): This command is similar to the Write Sector(s) command, except each sector is verified
immediately after being written.
27
TM
32MB – 16-GB
2.5.2 Sector Transfer Protocol
Figure 6: Sector Read
NOTE: 1 sector read procedure after the card configured I/O interface is shown as follows.
28
TM
32MB – 16-GB
Figure 7: Sector Write
NOTE: 1 sector write procedure after the card configured I/O interface is shown as follows.
29
TM
32MB – 16-GB
3.1
General
Table 29: Absolute Maximum Ratings (VCC=3.3V 5% or VCC=5V 10%)
Symbol
VCC
VIN / VOUT
TA
TA
TS
V*
Parameter
VCC With Respect to GND
All Input/Output Voltages1
Operating Temperature (Standard Temp)
Operating Temperature (Industrial Temp)
Storage Temperature
Voltage on any Pin Except VCC with Respect to GND
Min
-0.3
-0.3
-55
-0.5
Max
6.5
VCC + 0.3
70
85
125
0.5
MIN
-1
50k
50k
MAX
1
500k
500k
Units
V
V
C
C
C
V
NOTE:
1. VIN / VOUT Min. = -2.0V for Pulse Width 0.20ns
Table 30: Input Leakage Control
Symbol
IL
RPU1
RPD1
Parameter
Input Leakage Current
Pull Up Resistor
Pull Down Resistor
Type
IxZ
IxU
IxD
Conditions
Vih = Vcc/Vil = Gnd
Vcc = 5.0V
Vcc = 5.0V
Units
A
Ohm
Ohm
NOTE: The minimum pull-up resistor leakage current meets the PCMCIA specification of 10k ohms but is intentionally higher in the Compact Flash Memory Card
to reduce power use.
Table 31: Input Characteristics
Type
Parameter
1
Input Voltage CMOS
2
Input Voltage CMOS
3
Input Voltage CMOS
Schmitt Trigger
Symbol
Vih
Vil
Vih
Vil
Vih
Vil
MIN
2.4
Vcc = 3.3 V
TYP
MAX
MIN
2.4
Vcc = 5.0 V
TYP
MAX
0.6
1.5
0.8
2.0
0.6
1.8
1.0
0.8
2.8
2.0
Units
V
V
V
Table 32: Output Drive Type
Type
OTx
OZx
OPx
ONx
Output Type
Totempole
Tri-State N-P Channel
P-Channel Only
N-Channel Only
Valid Conditions
Ioh & Iol
Ioh & Iol
Ioh only
Iol only
30
TM
32MB – 16-GB
Table 33: Output Drive Characteristics
Type
Parameter
1
Output Voltage
2
Output Voltage
3
Output Voltage
X
Tri-State Leakage
Current
Symbol
Voh
Conditions
Ioh = -4 mA
Vol
Iol = 4 mA
Voh
Ioh = -8 mA
Vol
Iol = 8 mA
Voh
Ioh = -8 mA
Vol
Iol = 8 mA
Ioz
Vol = Gnd
Voh = Vcc
MIN
Vcc
-0.8V
TYP
MAX
GND
+0.4V
Vcc
-0.8V
GND
+0.4V
Vcc
-0.8V
GND
+0.4V
10
-10
Units
V
V
V
A
Table 34: Capacitance (Ta = 25C, f = 1MHz)
Parameter
Input capacitance
Output capacitance
Symbol
Cin
Cout
Condition
Vin = 0V
Vout = 0V
Min
Max
35
35
Unit
pF
pF
Table 35: Power-up/Power-down Timing
The timing specification was defined to retain data in the Flash Card during power-up or power-down cycles and to permit
peripheral cards to perform power-up initialization.
Item
CE signal level1
CE Setup Time
CE Recover Time
Vcc Rising Time2
Reset Width
NOTE:
1.
2.
Symbol
Condition
Vi (CE)
0V < Vcc < 2.0V
2.0V < Vcc < VIH
< VIH < Vcc
Tsu (Vcc)
Tsu (RESET)
Trec (Vcc)
tpr
tpf
Tw (RESET)
Th (Hi-z Reset)
Ts (Hi-z Reset)
10% 90% of (Vcc + 5%)
90% of (Vcc – 5%) 10%
Min
