W7EU002G1XC-SM0PB-02D.01
    WINTECINDUSTRIES
    模块
    MODULE FLASH NAND SLC 2GB
W7EU002G1XC-SM0PB-02D.01 数据手册
W7EU Series Embedded USB Specification Rev 1.10 Embedded USB W7EU Series INFORMATION IN THIS DOCUMENT IS PROVIDED IN RELATION TO WINTEC INDUSTRIES PRODUCTS, AND IS SUBJECT TO CHANGE WITHOUT NOTICE. NOTHING IN THIS DOCUMENT SHALL BE CONSTRUED AS GRANTING ANY LICENSE, EXPRESS OR IMPLIED. ALL INFORMATION IN THIS DOCUMENT IS PROVIDED ON AN “AS-IS” BASIS WITHOUT GUARANTEE OR WARRANTY OF ANY KIND. • Please contact your nearest Wintec representative for the latest updates or additional product information. 1 W7EU Series Embedded USB Specification Rev 1.10 Table of Contents Revision History ............................................................................................................. 3 Features ........................................................................................................................... 4 Description ...................................................................................................................... 4 1.0 Performance and Reliability: ................................................................................... 5 2.0 Functional Block Diagram ....................................................................................... 6 3.0 Physical Dimensions: .............................................................................................. 7 4.0 Mechanical Profile – Side View: ............................................................................. 7 5.0 Mechanical Profile – Bottom View (Standard): ...................................................... 8 6.0 Mechanical Profile – Top View (Vertical): ............................................................. 9 7.0 Pin Specifications and Signal Descriptions: .......................................................... 10 8.0 Pin / Signal Descriptions:....................................................................................... 11 9.0 Electrical Characteristics – DC Parameters: .......................................................... 11 10.0 Ordering Information ........................................................................................... 12 2 W7EU Series Embedded USB Specification Rev 1.10 Revision History Revision 1.00 1.01 Month October August Year 2008 2009 1.02 October 2009 1.03 October 2009 1.04 1.05 1.06 November December January 2009 2009 2010 1.07 June 2010 1.10 April 2011 3 History Initial Release (Preliminary) Add connector options and mounting heights Add Pin 10 NC configuration as option Add SM3252 controller as option Correct mounted connector height Correct Typo Update configuration options Add Vertical connector configuration Mechanical drawing Added pictures of various eUSB configurations Updated Block Diagram/Single voltage support Updated Storage temp spec/product image for standard connector Update the Naming guide W7EU Series Embedded USB Specification Rev 1.10 Features: GENERAL      Embedded USB 2.0 Device SLC NAND type flash 5V operational voltage Low profile RoHS Compliant PERFORMANCE     High performance SLC NAND Dual Channel - seq. RD/WR up to 32/27 MB/s Single channel version - seq. RD/WR up to 20/20 MB/s Low Power consumption RELIABILITY      No moving parts Capable of withstanding high impact and vibration shocks Built-in hardware engine 8/15 bits BCH ECC per 1K bytes Endurance up to 1,000,000 Write/Erase cycles 10 year typical data retention COMPATIBILITY    Fully compatible with USB 2.0 and backward compatible with USB 1.1 specification USB Mass Storage Class Specification 1.0 10 Pin 2x5 USB Socket with 2mm or 2.54mm pitch Description: The Wintec Embedded USB Flash Drive is a robust and reliable high performance storage and backup solution in a compact form factor. Fully USB 2.0 compatible with high data transfer rates. Superior reliability is achieved by using high quality SLC NAND and featuring extensive error correcting capabilities of 8/15 bits per 528 byte sector. Available in capacities from 512MB to 16GB (32GB capacities available using MLC NAND). Wintec’s W7EU series embedded USB flash drives are ideal for embedded applications demanding high performance and reliability. 4 W7EU Series Embedded USB Specification Rev 1.10 Performance and Reliability: Performance and Reliability Performance ECC Endurance Data Error Rate Data Retention Up to 32MB/s (dual); 20MB/s (single) SM3252 15 bit BCH ECC per 528 Bytes SM3255 13/24/48 bit BCH ECC per 1KB 1,000,000 Write / Erase cycles (SLC) 1 in 1015 bits read 10 years Table 1 – Performance and Reliability Data Environmental Characteristics Operating Temperature (ambient) Storage Temperature (Min) Storage Temperature (Max) Non-Operating Shock Non-Operating Vibration Operating Vibration ESD +70˚C Max -55˚C +150˚C 600G peak @ 2ms pulse 5G peak @ 5-500 Hz 1.5G peak @ 5-40Hz Withstand electrostatic discharge of +/- 4KV Table 2 – Environmental Characteristics 5 W7EU Series Embedded USB Specification Rev 1.10 Functional Block Diagram 5V to 3.3V Voltage Regulator VCC5A 5V U S B DD+ C O N N E C T O R GND 3.3V to 1.8V Voltage Regulator RAM Buffer USB Controller ECC uP8051 core Optional LED Figure 1 6 NAND FLASH (up to 4CE) Data RAM Mask ROM 12MHZ XTL NAND FLASH (up to 4CE) W7EU Series Embedded USB Specification Rev 1.10 Physical Dimensions: Wintec’s Embedded USB module has the following dimensions. eUSB Physical Specification Low Profile Standard Ultra High Right Angle PCB length 1.45in. (36.9mm) 1.45in. (36.9mm) 1.45in. (36.9mm) 1.45in. (36.9mm) PCB width 1.05in. (26.6mm) 1.05in. (26.6mm) 1.05in. (26.6mm) 1.05in. (26.6mm) Connector pitch Mounted connector height 0.08in. (2.00mm) 0.10in. (2.54mm) 0.10in. (2.54mm) 0.10in. (2.54mm) 0.110in. (2.80mm) 0.291in. (7.4mm) 0.385in. (9.78mm) 0.334in. (8.50mm) Table 3 – Physical Dimensions Low Profile Standard Ultra High Right Angle Mechanical Profile – Side View: 1.2 mm (0.048”) Flash Chip 1 ± 0.1 mm (0.04 ± 0.004”) PCB Conn Controller Chip 1.6 mm (0.064”) 3.68mm Note: PCB thickness is 40 mils ± 4 mils (1 ± 0.1”) Figure 2 7 W7EU Series Embedded USB Specification Rev 1.10 Mechanical Profile – Bottom View (Low Profile, Standard and Ultra High): Figure 3 Note: The above dimensions can be used for low profile, standard and ultra high connector configurations. Connector dimensions are listed in Table 3. 8 W7EU Series Embedded USB Specification Rev 1.10 Mechanical Profile – Top View (Vertical connector): 8.483 mm (0.334") 4.50 mm (0.178") 45.383 + 0.15 mm (1.786 + 0.006") 36.9 + 0.15 mm (1.452 + 0.006") 27.50 mm 1.082" 20.82 + 0.05 mm (0.82 + 0.005") 2mm / 2.54mm pitch 13.3 + 0.15 mm (0.52 + 0.006") Drill hole diameter 2.0 + 0.15 mm (0.084 + 0.006") 2.87 + 0.15 mm (0.113 + 0.006 “) 4.90 mm (0.193") 2.40 + 0.15 mm (0.0945 + 0.006 “) 20.7 + 0.15 mm (0.815 + 0.006 “) 26.6 + 0.15 mm (1.031 + 0.006 “) Figure 4 Note: The above dimensions can be used for vertical (right angle) connector configuration. Connector dimensions are listed in Table 3. 9 W7EU Series Embedded USB Specification Rev 1.10 Pin Specifications and Signal Descriptions: Pin Assignment (Bottom View) for 2x5 Connector: (Pin pitch of either 2.54mm (0.1”) or 2mm is available) 1 3 5 7 9 V B U S D- D+ G N D K E Y N C N C N C N C L E/N D C # 2 4 6 8 10 Ring is connected to internal GND Figure 4 10 W7EU Series Embedded USB Specification Rev 1.10 Pin / Signal Descriptions: PIN # Signal Name Signal Type Signal Description 1 VBUS Power 5V Power supply connection 2 NC Input No Connect 3 D- I/O Negative differential data pin 4 NC - No Connect 5 D+ I/O Positive differential data pin 6 NC - No Connect 7 GND Ground Ground Connection 8 NC - No Connect 9 KEY Power KEY 10 LED# (Optional) / NC LVTTL Output An Active low, up to 10mA pull-down (see note) to indicate a USB transaction is taking place. The signal enables the user to bring the LED control to external panel display. The pin can be left open if not used. Table 4 – Pin and Signal Descriptions Note: An LED indicator is built on module to enable users to visualize the embedded Flash module activities. The LVTTL output driver is capable of sinking 24mA. An optional on-board LED draws 1mA of current (±20%), if installed. If the on-board LED is installed, the maximum external LED# sink current is not to exceed 20mA. Electrical Characteristics – DC Parameters: Parameter Symbol Min Nom Max Unit Supply Voltage Input Leakage Current Output Leakage Current Peak Voltage on all Lines Output High Voltage (VOH) Output Low Voltage (VOL) Input High (VIH) Input Low (VIL) VBUS 4.2 -10 -10 -0.5 2.4 (at IOH = -2mA) 5.0 - 5.5 10 10 3.6 V μA μA V V V V V VOH VOL VIH VIL 2.0 -0.3 Table 5 – DC Parameters 11 0.4 0.8 W7EU Series Embedded USB Specification Rev 1.10 Ordering Guide: (t) Card Capacity Part Number 512 MB 1 GB 2 GB 4 GB 8 GB 16 GB W7EU512Mtuv(I)-ww0xx-yyy.zz W7EU001Gtuv(I)-ww0xx-yyy.zz W7EU002Gtuv(I)-ww0xx-yyy.zz W7EU004Gtuv(I)-ww0xx-yyy.zz W7EU008Gtuv(I)-ww0xx-yyy.zz W7EU016Gtuv(I)-ww0xx-yyy.zz Configuration Options 1 : Default (With LED) T : Pin 10 NC (u) Disk/Interface Options X : Removable Disk T : Fixed Disk (v) Form Factor Options C : Embedded 2mm pitch D : Embedded 2.54mm pitch E : Embedded 2.54mm pitch High profile F : Through-hole Right Angle Connector (ww) Controller Options SM : SM325 S2 : SM3252 S5 : SM3255 Contact Us (US & Int’l): Wintec Industries OEM Sales 675 Sycamore Drive Milpitas, CA 95035 Ph: 408-856-0500 (Main) Fax: 408-856-0518 oemsales@wintecind.com http://www.wintecind.com/oem 12 (xx) NAND Flash IC Mfg. & Die Revision P : Samsung A: A Die M : Micron B: B Die I : Intel C: C Die H : Hynix (yyy) Component Flash type 001: 1-Nand Flash chip 01D: 1-Nand, Dual Die, 1-CE 1D2: 1-Nand, Dual Die, 2-CE 1Q2: 1-Nand, Quad Die, 2-CE 002: 2-Nand Flash chips 02D: 2-Nand, Dual Die, 1-CE 2D2: 2-Nand, Dual Die, 2-CE 2Q2: 2-Nand, Quad Die, 2-CE Firmware Revision/Options (Optional) Please contact the factory for the latest firmware revisions and/or custom labeling and programming identification. W7EU Series Embedded USB Specification Rev 1.10 About Wintec Industries, Inc. Wintec, founded in 1988, is headquartered in Milpitas, California. Wintec, a leading third party memory module manufacturer, specializes in a variety of module design and manufacturing, such as memory module, flash module, Handspring module, modem module, game module, etc. Besides a complete line of DDR, SDR, and EDO/FPM legacy memory modules, Wintec also distribute CPU, motherboard, peripherals, PC software, and consumer Flash products (such as MMC, SD, SMC, Compact Flash, PC Card, etc.). With excellent design engineering and manufacturing capability, Wintec provides a wide range of design and manufacturing services for our valuable customers from concept design to final product delivery. Wintec is ISO9001- 2000 certified. Important Notice Wintec Industries, Inc. makes no representations or warranties with respect to the contents of this User Guide and specifically disclaims any implied warranties of any product design for any particular purpose. Wintec Industries, Inc. reserves the rights to revise this publication and to make changes from time to time in the content hereof without obligation of Wintec Industries, Inc. to notify any person or organization of such revisions or changes. 13
W7EU002G1XC-SM0PB-02D.01 价格&库存
很抱歉,暂时无法提供与“W7EU002G1XC-SM0PB-02D.01”相匹配的价格&库存,您可以联系我们找货
