A5839
A5839
    ANTENOVA(安诺亚)
    ANT_12.8X3.9MM_SM
    ANTENNA CHIP 2.4GHZ SMD LEFT FD
A5839 数据手册
Rufa 2.4 GHz SMD Antenna Part No. A5839 / A5887 gigaNOVA® Product Specification 1 Features • • • • • • • Designed for 2.4 GHz applications: Bluetooth®, Wi-Fi® (802.11b/g), ZigBee®, etc. Easy to integrate Low profile design for use with no ground beneath the antenna High efficiency Light weight Intended for SMD mounting Supplied in tape on reel 2 Description Rufa is intended for use with all 2.4 GHz applications. The antenna uses a ground plane in order to radiate efficiently, but this ground plane must not extend underneath the antenna itself. The antenna is available in two versions with the feed locations on the right or left hand side of the antenna. 3 Applications • Mobile phones • PDAs • PNDs • Headsets • PMPs / MP3s • Laptops • PC-Cards • Sensors Antennas for Wireless M2M Applications 1 Product Specification AE020157-P Rufa 2.4 GHz SMD Antenna Part No. A5839 / A5887 4 Part numbers Rufa Left: A5839 Rufa Right: A5887 5 General data Product name Rufa 2.4 GHz A5839 (Left) Part Number A5887 (Right) Frequency 2.4 – 2.5 GHz Polarization Linear Operating temperature -40 ºC to +140 ºC Environmental condition test ISO16750-4 5.1.1.1/5.1.2.1/5.3.2 Impedance with matching 50 Ω Weight 0.1 g Antenna type SMD Dimensions 12.8 x 3.9 x 1.1 [mm] 6 Electrical characteristics Typical performance Peak gain 2.1 dBi Average gain -1.2 dBi Average efficiency Maximum Return Loss Maximum VSWR 75% -11 dB Conditions All data measured on Antenova’s reference boards, part numbers A5839-U1 and A5887-U1 Data given for the 2.4 – 2.5 GHz frequency range 1.8:1 Antennas for Wireless M2M Applications 2 Product Specification AE020157-P 7 Electrical performance Rufa 2.4 GHz SMD Antenna Part No. A5839 / A5887 7-1 Return Loss 7-2 VSWR Antennas for Wireless M2M Applications 3 Product Specification AE020157-P Rufa 2.4 GHz SMD Antenna Part No. A5839 / A5887 7-3 Antenna patterns Z X XY plane ZY plane Y XZ plane Patterns show combined polarisations measured on reference board A5839-U1 Antennas for Wireless M2M Applications 4 Product Specification AE020157-P Rufa 2.4 GHz SMD Antenna Part No. A5839 / A5887 8 Antenna dimensions Rufa Left Rufa Right L W H Length Width Height 12.8 ± 0.2 3.9 ± 0.2 1.1 ± 0.2 Dimensions in mm 9 Antenna footprint * CAD files of the antenna footprint are available at www.antenova-m2m.com.. Rufa Left (Part No: A5839) Rufa Right (Part No: A5887) I S K J N L O 1.0 ± 0.1 2.0 ± 0.1 8.1 ± 0.1 3.7 ± 0.1 1.3 ± 0.1 2.4 ± 0.1 0.5 ± 0.1 Dimensions in mm Antennas for Wireless M2M Applications 5 Product Specification AE020157-P Rufa 2.4 GHz SMD Antenna Part No. A5839 / A5887 10 Electrical interface 10-1 Transmission lines • All transmission lines should be designed to have a characteristic impedance of 50 Ω • The length of the transmission lines should be kept to a minimum • Any other parts of the RF system like transceivers, power amplifiers, etc, should also be designed to have an impedance of 50 Ω Once the material for the PCB has been chosen (PCB thickness and dielectric constant), a coplanar transmission line can easily be designed using any of the commercial software packages for transmission line design. For the chosen PCB thickness, copper thickness and substrate dielectric constant, the program will calculate the appropriate transmission line width and gaps on either side of the track so the characteristic impedance of the coplanar transmission line is 50 Ω . 10-2 Matching circuit The antenna requires a matching circuit that must be optimized for each customer’s product. The matching circuit will require up to three components and the following pad layout should be designed into the device so the correct circuit can be installed: The antenna feed pad and the antenna ground pad are indicated in the drawing above. Additional pads are for mechanical attachment only and should not be grounded. Antennas for Wireless M2M Applications 6 Product Specification AE020157-P Rufa 2.4 GHz SMD Antenna Part No. A5839 / A5887 In addition to the matching circuit, a separate DC blocking capacitor will also be required between the radio and the antenna matching circuit. Note: The component values for the matching circuit will vary depending on the size of the PCB and surrounding components. The impedance of the antenna should be measured before selecting suitable matching components. Antenova M2M offers this service on request. Contact sales@antenova-m2m.com for further information. 10-3 Antenna placement Antenova M2M strongly recommends placing the antenna near the edge of the board. Maximum antenna performance is achieved by placing the antenna towards one of the corners of the PCB and with the feed point of the antenna as close to same corner of the PCB as possible. Additional ground and components near the antenna should be at a distance of at least 2 mm. Where possible the antenna should be clear of ground from both sides, although the antenna can work well with a minimum clearance of D ≥ 2 mm as shown in the drawing above. Antennas for Wireless M2M Applications 7 Product Specification AE020157-P Rufa 2.4 GHz SMD Antenna Part No. A5839 / A5887 10-4 Reference boards The reference boards have been designed for evaluation purposes of Rufa 2.4 GHz and they include a SMA female connector Rufa Left Rufa Right Dimensions in mm To order a reference board contact sales@antenova-m2m.com. Antennas for Wireless M2M Applications 8 Product Specification AE020157-P Rufa 2.4 GHz SMD Antenna Part No. A5839 / A5887 11 Soldering This antenna is suitable for lead free soldering. The reflow profile should be adjusted to suit the device, oven and solder paste, while observing the following conditions: - The maximum temperature should not exceed 240 ºC - However for lead free soldering, a maximum temperature of 255 ºC for no more than 20 seconds is permitted. - The antenna should not be exposed to temperatures exceeding 120 ºC more than 3 times during the soldering process. 12 Hazardous material regulation conformance The antenna has been tested to conform to RoHS requirements. A certificate of conformance is available from Antenova’s website. Antennas for Wireless M2M Applications 9 Product Specification AE020157-P Rufa 2.4 GHz SMD Antenna Part No. A5839 / A5887 13 Packaging 13-1 Optimal storage conditions for packaged reels Temperature -10ºC to 40ºC Humidity Less than 75% RH Shelf Life 18 Months Storage place Away from corrosive gas and direct sunlight Packaging Reels should be stored in unopened sealed manufacturer’s plastic packaging. Note: Storage of open reels of antennas is not recommended due to possible oxidization of pads on antennas. If short term storage is necessary, then it is highly recommended that the bag containing the antenna reel is re-sealed and stored in like storage conditions as in above table. Antennas for Wireless M2M Applications 10 Product Specification AE020157-P Rufa 2.4 GHz SMD Antenna Part No. A5839 / A5887 13-2 Tape characteristics Rufa Left [Part Number: A5839] W F E1 P0 P1 P2 A0 B0 K0 T D0 D1 24 ± 0.2 11.5 ± 0.1 1.75 ± 0.1 4 ± 0.1 8 ± 0.1 2 ± 0.1 4.3 ± 0.1 13.1 ± 0.1 1.4 ± 0.1 0.3 ± 0.05 Min 1.5 Min 1.5 Dimensions in mm Quantity Leading Space Trailing Space 1000 pcs / reel 50 blank antenna holders 37 blank antenna holders Antennas for Wireless M2M Applications 11 Product Specification AE020157-P Rufa 2.4 GHz SMD Antenna Part No. A5839 / A5887 Rufa Right [Part Number: A5887] W F E1 P0 P1 P2 A0 B0 K0 T D0 D1 24 ± 0.2 11.5 ± 0.1 1.75 ± 0.1 4 ± 0.1 8 ± 0.1 2 ± 0.1 4.3 ± 0.1 13.1 ± 0.1 1.4 ± 0.1 0.3 ± 0.05 Min 1.5 Min 1.5 Dimensions in mm Quantity Leading Space Trailing Space 1000 pcs / reel 50 blank antenna holders 37 blank antenna holders Antennas for Wireless M2M Applications 12 Product Specification AE020157-P Rufa 2.4 GHz SMD Antenna Part No. A5839 / A5887 13-3 Reel dimensions Width (W) Reel Diameter (D) Hub Diameter (H) Shaft Diameter (C) 24 mm 180 mm (7”) 60 mm (2”) 13 mm 13-4 Box dimensions Width (W) Breadth (B) Thickness (H) 203 mm 188 mm 40 mm 13-5 Bag properties Reels are supplied in protective plastic packaging 13-6 Reel label information Rufa Left Rufa Right Dimensions in mm Antennas for Wireless M2M Applications 13 Product Specification AE020157-P Rufa 2.4 GHz SMD Antenna Part No. A5839 / A5887 www.antenova-m2m.com Corporate Headquarters North America Headquarters Asia Headquarters Antenova Ltd. 2nd Floor, Titan Court 3 Bishop Square Hatfield AL10 9NA Antenova Ltd. 100 Brush Creek Road, Suite 103 Santa Rosa California, 95404 USA Antenova Asia Ltd. 4F, No. 324, Sec. 1, Nei-Hu Road Nei-Hu District Taipei 11493 Taiwan, ROC Tel: +44 1223 810600 Email: sales@antenova-m2m.com Tel: +1 707 890 5202 Email: sales@antenova-m2m.com Tel: +886 (0) 2 8797 8630 Fax: +886 (0) 2 8797 6890 Email: sales@antenova-m2m.com Copyright® Antenova Ltd. All Rights Reserved. Antenova®, Antenova M2M®, gigaNOVA®, the Antenova product family names, and the Antenova and Antenova M2M logos are trademarks and/or registered trademarks of Antenova Ltd. Any other names and/or trademarks belong to their respective companies. The materials provided herein are believed to be reliable and correct at the time of print. Antenova does not warrant the accuracy or completeness of the information, text, graphics or other items contained within these information. Antenova further assumes no responsibility for the use of this information, and all such information shall be entirely at the user’s risk. Antennas for Wireless M2M Applications 14 Product Specification AE020157-P Revised 18 January 2016
A5839 价格&库存
很抱歉,暂时无法提供与“A5839”相匹配的价格&库存,您可以联系我们找货
