1000146
    ETHERTRONICS
    WLAN ANTENNA EMB 802.11 A/B/G/N
1000146 数据手册
DATASHEET Part No. 1000146 Product: Wi-Fi 6 & Wi-Fi 6E or CBRS/n78 Stamped Metal Embedded Antenna Part No. 1000146 Wi-Fi 6 & Wi-Fi 6E or CBRS/n78 Stamped Metal Embedded Antenna 2.4 / 5 GHz or 3.3 – 3.8 GHz Supports: Wi-Fi applications, Agriculture, Bluetooth, Zigbee, WLAN, Smart Home, Healthcare, Digital Signage *CBRS/n78 layout offered in Appendix 1 Wi-Fi 6 & Wi-Fi 6E or CBRS/n78 Stamped Metal Embedded Antenna 2.400 GHz – 2.485 GHz; 3.300 - 3.800 GHz; 5.150 GHz – 5.825 GHz; 5.975 GHz – 7.125 GHz KYOCERA AVX Stamped Metal series of Isolated Magnetic Dipole™ (IMD) antennas deliver on the key needs of device designers for higher functionality and performance in smaller/thinner designs. These innovative antennas provide compelling advantages for full WIFI 6 and WiFi 6E handheld devices, media players and other mobile devices. 1000146 Automotive A-series version offered. Greater Flexibility KYOCERA AVX first-in-class IMD technology enables you to develop concept designs that are more advanced and that deliver superior performance in reception critical applications. The 1000146 can also achieve CBRS/n78 performance with proper tuning and layout shown on Appendix 1. Electrical Specifications Typical Characteristics, on 125 x 45 mm PCB KEY BENEFITS Frequency (GHz) 2.400 – 2.485 5150 – 5.825 5925 - 7125 Peak Gain 1.7 dBi 4.1 dBi 3.8 dBi Average Efficiency 81% 68% 64% 3.300– 3.800 VSWR Match 2.0:1 max 2.0:1 max 2.2:1 max Stay-in-Tune KYOCERA AVX antenna Feed Point technology provides superior RF 50 ohms unbalanced Impedance field containment, resulting in less interaction with surrounding Polarization Linear components. Power Handling 0.5 Watt CW Quicker Time-to-Market By optimizing antenna size, Mechanical Specifications & Ordering Part Number performance and emissions, customer and regulatory Ordering Part Number 1000146 specifications are more easily met. Size (mm) 17.85 x 6.9 x 4.3 Reliability Products are the latest RoHS Mounting SMT version compliant Weight (grams) 0.35 APPLICATIONS Tape & Reel, Packaging • Embedded • Telematics 1000146 – 1,200 pieces per reel • • • design Cellular, Headsets, Tablets Gateway, Access Point Handheld 8/25/2022 • • • • • Tracking Healthcare M2M, Industrial devices Smart Grid OBD-II TDS-ANT-0074 | Rev. 1 Demo Board Proprietary 1005456 (WIFi/WiFi6E) 1000146-03 (n78/CBRS) www.KYOCERA-AVX.com DATASHEET | Part No. 1000146 Wi-Fi 6 & Wi-Fi 6E KYOCERA AVX Stamped Metal Embedded Antenna. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Antenna Dimensions Typical antenna dimensions (mm) Part Number A B C 1000146 17.85 ± 0.3 6.9 ± 0.3 4.3 ± 0.4 A B Top View C Height Height Pin 1 2 3 Description Feed Ground Dummy Pad Pin #2 Pin #3 © 2022 KYOCERA AVX Pin #1 Bottom View TDS-ANT-0074 | Rev. 1 tel +(1) 858.550.3820 email: antenna.info@kyocera-avx.com 1 Avx Blvd, Fountain Inn, SC 29644 DATASHEET | Part No. 1000146 Wi-Fi 6 & Wi-Fi 6E KYOCERA AVX Stamped Metal Embedded Antenna. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Test Setup (1005456) Typical Performance on 125 x 45 mm PCB 1000146 (Antenna) *Mounted using 1005456 demo board 45 mm 125 mm © 2022 KYOCERA AVX TDS-ANT-0074 | Rev. 1 tel +(1) 858.550.3820 email: antenna.info@kyocera-avx.com 1 Avx Blvd, Fountain Inn, SC 29644 DATASHEET | Part No. 1000146 Wi-Fi 6 & Wi-Fi 6E KYOCERA AVX Stamped Metal Embedded Antenna. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. VSWR, Efficiency, and Peak Gain Plots Typical Performance on 125 x 45 mm PCB VSWR (2.400 – 2.490) GHz VSWR (:1) VSWR (:1) VSWR (5.100 – 7.200) GHz Frequency (MHz) Efficiency (2.400 – 2.490) GHz Efficiency (5.100 – 7.200) GHz Efficiency (%) Efficiency (%) Frequency (MHz) Frequency (MHz) Peak Gain (2.400 – 2.490) GHz Peak Gain (5.100 – 7.200) GHz Peak Gain (dBi) Peak Gain (dBi) Frequency (MHz) Frequency (MHz) © 2022 KYOCERA AVX Frequency (MHz) TDS-ANT-0074 | Rev. 1 tel +(1) 858.550.3820 email: antenna.info@kyocera-avx.com 1 Avx Blvd, Fountain Inn, SC 29644 DATASHEET | Part No. 1000146 Wi-Fi 6 & Wi-Fi 6E KYOCERA AVX Stamped Metal Embedded Antenna. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Antenna Radiation Patterns Typical Performance on 125 x 45 mm PCB Measured @ 2.440 GHz © 2022 KYOCERA AVX TDS-ANT-0074 | Rev. 1 tel +(1) 858.550.3820 email: antenna.info@kyocera-avx.com 1 Avx Blvd, Fountain Inn, SC 29644 DATASHEET | Part No. 1000146 Wi-Fi 6 & Wi-Fi 6E KYOCERA AVX Stamped Metal Embedded Antenna. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Antenna Radiation Patterns Typical Performance on 125 x 45 mm PCB Measured @ 5.550 GHz © 2022 KYOCERA AVX TDS-ANT-0074 | Rev. 1 tel +(1) 858.550.3820 email: antenna.info@kyocera-avx.com 1 Avx Blvd, Fountain Inn, SC 29644 DATASHEET | Part No. 1000146 Wi-Fi 6 & Wi-Fi 6E KYOCERA AVX Stamped Metal Embedded Antenna. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Antenna Radiation Patterns Typical Performance on 125 x 45 mm PCB Measured @ 6.425 GHz © 2022 KYOCERA AVX TDS-ANT-0074 | Rev. 1 tel +(1) 858.550.3820 email: antenna.info@kyocera-avx.com 1 Avx Blvd, Fountain Inn, SC 29644 DATASHEET | Part No. 1000146 Wi-Fi 6 & Wi-Fi 6E KYOCERA AVX Stamped Metal Embedded Antenna. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Antenna Layout (Minor Tuning Layout) Typical layout dimensions (mm) R1 R3 R6 R5 R4 Antenna Outline R2 P2 S1 P1 Note: Layout has minor tuning capabilities to allow for small antenna footprint. Pin Descriptions Pin# 1 2 3 Pin #3 Description Feed Ground Dummy Pad 1 2 R5 R6 3 R1 (Antenna Matching) P2 Pin #1 50Ω Transmission line R4 PIN Pin #2 R2 R3 Antenna Outline S1 50ohm P1 Antenna Matching & Tuning Component Values Default Values Component Tolerance P1 DNI N/A © 2022 KYOCERA AVX S1 0Ω N/A P2 DNI N/A R1 – R3 DNI N/A TDS-ANT-0074 | Rev. 1 R4 – R6 DNI N/A tel +(1) 858.550.3820 email: antenna.info@kyocera-avx.com 1 Avx Blvd, Fountain Inn, SC 29644 DATASHEET | Part No. 1000146 Wi-Fi 6 & Wi-Fi 6E KYOCERA AVX Stamped Metal Embedded Antenna. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Antenna Layout (Major Tuning Layout) Typical layout dimensions (mm) Antenna Outline Note: Layout has Major tuning capabilities to allow for robust tuning after board spin, instructions on Antenna Matching Structure page. Pin Descriptions Pin# 1 2 3 Description Feed Ground Dummy Pad Pin #3 Pin #2 Pin #1 50Ω Transmission line Antenna Antenna Outline Outline © 2022 KYOCERA AVX TDS-ANT-0074 | Rev. 1 tel +(1) 858.550.3820 email: antenna.info@kyocera-avx.com 1 Avx Blvd, Fountain Inn, SC 29644 DATASHEET | Part No. 1000146 Wi-Fi 6 & Wi-Fi 6E KYOCERA AVX Stamped Metal Embedded Antenna. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Antenna Matching Structure (Major Tuning Structure) Typical matching values on 125 x 45 mm PCB Pin #3 Pin #1 Pin #2 Low Band Tuning (Add to Shift Low) [P2] [R7] [R8] [R9] [R10] [R11] [R12] [R13] [R14] [P1] Pin Descriptions Pin# Description 1 2 3 (Low Band Tuning) Feed Ground R4 Dummy Pad PIN 1 2 3 R6 R5 (Low Band Tuning) R2 R1 R3 (Antenna Matching) P2 S1 P1 R7 R8 R9 R10 R16 R11 R15 50ohm Tolerance © 2022 KYOCERA AVX R17 R12 R13 R18 Default Values [R17] [R20] [R16] [R19] [R15] [R18] [S1] [R1] [R2] [R3] [R6] [R5] [R4] High Band Tuning (Add to Shift High, DNI to Shift Low) Antenna Matching Low Band Tuning (Add to Shift High) R19 R14 R20 *Extend ground towards antenna feed with 0Ω component(s). R7- R20 can improve high band bandwidth/ performance with ground coupling. P1 S1 P2 R1 – R3 DNI 0Ω DNI DNI DNI DNI DNI N/A N/A N/A N/A N/A N/A N/A TDS-ANT-0074 | Rev. 1 R4 – R6 R7 – R14 R15 - R20 tel +(1) 858.550.3820 email: antenna.info@kyocera-avx.com 1 Avx Blvd, Fountain Inn, SC 29644 DATASHEET | Part No. 1000146 Appendix 1 CBRS/n78 KYOCERA AVX Stamped Metal Embedded Antenna. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Appendix 1 Appendix 1 gives instructions on how to achieve CBRS/n78 performances through layout and impedance matching network. (3.300 – 3.800 GHz) Frequency (GHz) 3.300 – 3.800 Peak Gain 4.21 dBi Average Efficiency VSWR Match Feed Point Impedance 76% 2.0:1 max 50 ohms unbalanced Polarization Power Handling Linear 0.5 Watt CW *Data shown above has Appendix 1 matching applied on (1000146-03) 100 x 50 mm pcb. © 2022 KYOCERA AVX TDS-ANT-0074 | Rev. 1 tel +(1) 858.550.3820 email: antenna.info@kyocera-avx.com 1 Avx Blvd, Fountain Inn, SC 29644 DATASHEET | Part No. 1000146 Appendix 1 CBRS/n78 KYOCERA AVX Stamped Metal Embedded Antenna. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Appendix 1 (1000146-03) Typical Performance on 100 x 50 mm PCB 1000146 (Antenna) *Mounted using 1000146-03 demo board 50 mm 100 mm © 2022 KYOCERA AVX TDS-ANT-0074 | Rev. 1 tel +(1) 858.550.3820 email: antenna.info@kyocera-avx.com 1 Avx Blvd, Fountain Inn, SC 29644 DATASHEET | Part No. 1000146 Appendix 1 CBRS/n78 KYOCERA AVX Stamped Metal Embedded Antenna. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Appendix 1 VSWR and Efficiency Plots Typical Performance on 100 x 50 mm PCB VSWR Efficiency Peak Gain © 2022 KYOCERA AVX TDS-ANT-0074 | Rev. 1 tel +(1) 858.550.3820 email: antenna.info@kyocera-avx.com 1 Avx Blvd, Fountain Inn, SC 29644 DATASHEET | Part No. 1000146 Appendix 1 CBRS/n78 KYOCERA AVX Stamped Metal Embedded Antenna. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Measured at 3500 MHz Appendix 1 Antenna Radiation Patterns Typical Performance on 100 x 50 mm PCB Measured @ 3500 MHz © 2022 KYOCERA AVX TDS-ANT-0074 | Rev. 1 tel +(1) 858.550.3820 email: antenna.info@kyocera-avx.com 1 Avx Blvd, Fountain Inn, SC 29644 DATASHEET | Part No. 1000146 Appendix 1 CBRS/n78 KYOCERA AVX Stamped Metal Embedded Antenna. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Antenna Layout (CBRS/n78 performances) Typical layout dimensions (mm) R1 R3 Antenna Outline R2 P2 S1 P1 Note: Layout has minor tuning capabilities to allow for small antenna footprint. Pin Descriptions Pin# 1 2 3 Pin #3 Description Feed Ground Dummy Pad PIN 1 Pin #2 Pin #1 50Ω Transmission line 2 3 R1 (Antenna Matching) P2 R2 R3 S1 P1 Antenna Outline 50ohm Antenna Matching & Tuning Component Values Default Values Component Tolerance P1 DNI N/A © 2022 KYOCERA AVX S1 1.5 nH (+/-0.05) P2 0.8 pF (+/-0.05) R1 – R3 DNI N/A TDS-ANT-0074 | Rev. 1 tel +(1) 858.550.3820 email: antenna.info@kyocera-avx.com 1 Avx Blvd, Fountain Inn, SC 29644 DATASHEET | Part No. 1000146 Appendix 1 CBRS/n78 KYOCERA AVX Stamped Metal Embedded Antenna. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Antenna Matching Structure Typical matching values on 100 x 50 mm PCB Pin #3 Pin #2 DNI Antenna Tuning (Cut to Tune High) Pin #1 Antenna Matching [P2] [S1] [P1] Pin Descriptions Pin# Description 1 Feed 2 3 Dummy Pad Ground PIN 1 2 3 R1 (Antenna Matching) P2 R2 S1 P1 R3 50ohm Antenna Matching & Tuning Component Values Default Values Component Tolerance P1 DNI N/A © 2022 KYOCERA AVX S1 1.5 nH (+/-0.05) P2 0.8 pF (+/-0.05) R1 – R3 DNI N/A TDS-ANT-0074 | Rev. 1 tel +(1) 858.550.3820 email: antenna.info@kyocera-avx.com 1 Avx Blvd, Fountain Inn, SC 29644
1000146 价格&库存
很抱歉,暂时无法提供与“1000146”相匹配的价格&库存,您可以联系我们找货
