DATASHEET
Part No. P522304 / 9000154
Product: Broadband FR4
Embedded Cellular Antenna
Broadband FR4 Embedded Cellular Antenna
850 / 900 / 1800 / 1900 / 2100 MHz
Supports: Broadband LTE (OCTA-BAND), LTE CAT-M, NB-IoT, SigFox, LoRa, Cellular LPWA, RPMA, Firstnet
KYOCERA AVX’s Broadband Embedded Cellular antenna utilizes Isolated
Magnetic Dipole™ (IMD) technology which address the challenges facing
today’s product designers. IMD’s high performance and isolation
characteristics offer better connectivity and minimal interference. Mirrored
version variant offered as 9000154.
Stays in Tune
*Mirrored version offered as 9000154
Cellular Antenna
Low Band 824 – 960 MHz
High Band 1710 - 2170 MHz
KEY BENEFITS
Reduced Costs and
Time-to-Market
Standard antenna eliminates
design fees and cycle time
associated with a custom solution;
getting products to market faster.
Greater Flexibility with
Unique Form Factors
KYOCERA AVX’s technology
helps you deliver more advanced
ergonomic designs without
adverse impact on product
performance. Reliability
Comply with latest RoHS
requirements
APPLICATIONS
Medical
applications
Home
automation
Smart
metering
M2M,
Industrial
devices
IoT
Firstnet
10/1/2019
Automotive
Healthcare
Point of Sale
Tracking
Cellular
3G Systems
IMD antenna technology provides superior RF field containment, resulting in
less interaction with surrounding components. KYOCERA AVX IMD
antennas resist detuning; providing a robust radio link regardless of the
usage position
KYOCERA AVX antennas use patented IMD technology in many antenna
configurations to provide high performance. IMD antennas requires a
smaller design keep-out area, carry lower program development risk which
yields a quicker time-to-market, without sacrificing RF performance.
Electrical Specifications
Typical Characteristics, on 50 x 110 mm PCB
Frequency
Efficiency
VSWR
Peak Gain
Polarization
Power Handling
Radiation Pattern
Feed Point Impedance
824 - 960 MHz
1710 - 2170 MHz
62%
55%
2.5:1 max
2.7:1 max
0 dBi
0.7 dBi
Linear
2 Watts CW
Omni-directional
50 ohms unbalanced
Mechanical Specifications & Ordering Part Number
Ordering Part #
P522304
Dimensions (mm)
35.0 x 9.0 x 3.2
Weight (grams)
2.1
Mounting
SMT (P&P)
Packaging
1,120 pcs/reel; 5,600 pcs/box
Demo Board
Proprietary
P522304-02
www.KYOCERA-AVX.com
DATASHEET | Part No. P522304
Cellular FR4 KYOCERA AVX’s Embedded Antenna Specifications.
KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs.
Antenna Dimensions
Typical antenna dimensions (mm)
Part Number
A (mm)
B (mm)
C (mm)
P522304
35.0 ± 0.3
9.0 ± 0.2
3.2 ± 0.3
A
B
Top View
C
Height
Pin #3
Pin #4
Pin Descriptions
Pin #2
Pin #1
Pin #5
Pin#
1
2
3
4
5
Description
Feed
Ground
Dummy Pad
Dummy Pad
Low Band Tuning
Bottom View
© KYOCERA AVX
tel +(1) 858.550.3820
email: eth.info@KYOCERA-AVX.com
50
110
Low Band VSWR
Low Band Efficiency
© KYOCERA AVX
P522304-02
VSWR and Efficiency Plots (Off-Ground)
Typical Performance on 50 x 110 mm PCB
High Band VSWR
High Band Efficiency
Measured at 1870 MHz
Measured at 910 MHz
Antenna Radiation Patterns
Measured @ 910, 1870 MHz
© KYOCERA AVX
Antenna Layout (On-Ground)
Typical layout dimensions (mm)
Pin #2
S2
S1
P1
P2
Pin #1
Pin #5
Pin #4
Pin #3
VIAs
* VIAS: Diam. 0.2mm, (no vias on transmission lines).
Via holes must be covered by solder mask
50Ω
Transmission
Line
Pin Descriptions
Pin# Description
Feed
1
Ground
2
Dummy Pad
3
Dummy Pad
4
Low Band Tuning
5
Matching & Tuning Component Values
Component
P1
S1
S2
P2
R1 – R7
Value
3.6nH
1.2pF
15nH
1.8pF
DNI
Tolerance
±0.05nH
±0.05pF
±0.3nH
±0.05pF
N/A
Antenna
Outline
Default Pi Matching Network values and (R1- R7) tuning
instructions can be found under Antenna Matching Structure..
R1
R7
© KYOCERA AVX
R6 R4 R3 R2
R5
Typical matching values on 50 x 110 mm PCB
Demo Board Back View
Demo Board Front View
Pin #2
Pin #5
Pin #1
Vias
Pin #4
Pin #3
Low Band Tuning
Antenna Matching
[ R1 ]
[ S1 ]
[ P2 ] [ P1 ]
[ S2 ]
Tune Low Band Lower
(Add 0Ω)
Tune Low Band Higher
(Cut Bridge Trace)
[ R2 ] [ R3 ] [ R4 ] [ R15 ] [ R6 ] [ R7 ]
(Antenna Matching):
pads are directly inline with
the antenna feed trace.
*Cut Trace between pads shifts resonant frequency
higher
*Bridging gaps with 0 ohm resistors shifts resonant
frequency lower
Pin Descriptions
Pin#
1
2
3
4
5
(Low Band Tuning)
Description
Feed
Ground
Dummy Pad
Dummy Pad
Low Band Tuning
R1
1
2
3
P1
Default Matching 3.6nH
Tolerance ±0.05nH
© KYOCERA AVX
S1
1.2pF
± 0.05pF
P1
S2
R3
R4
R5
R6
R7
5
4
P2
(Antenna Matching)
R2
S1
S2
15nH
±0.3nH
50ohm
P2
1.8pF
± 0.05pF
(R1 - R7)
DNI
N/A
Antenna Demo Board
Demo Board Front View/Back View
Part Number
A (mm)
B (mm)
C (mm)
P522304-02
110
50.0
15.0
C
Antenna
Outline
A
P522304-02
B
Front View
© KYOCERA AVX
Back View
Recommended Reflow Soldering Profile
The recommended method for soldering the antenna to the board is forced convection reflow soldering. The following
suggestions provide information on how to optimize the reflow process for the FR4 antenna:
*Adjust the reflow duration to create good solder joints without raising the antenna temperature
beyond the allowed maximum of 260° C.
© KYOCERA AVX
很抱歉,暂时无法提供与“P522304”相匹配的价格&库存,您可以联系我们找货
