1000418
    ETHERTRONICS
    WLAN ANTENNA EMB 802.11 A/B/G/N
1000418 数据手册
DATASHEET Part No. 1000418 Product: Wi-Fi / BT / WLAN / Zigbee Embedded Stamped Metal Antenna Part No. 1000418 WLAN BT Zigbee Embedded Stamped Metal Antenna 2.4 / 4.9 / 5.2 / 5.8 GHz (802.11 a/b/g/n/c + Japan) Supports: Wi-Fi applications, Agriculture, Automotive, Bluetooth, Zigbee, WLAN, Smart Home, Healthcare, Digital Signage Wi-Fi Dual Band Stamp Metal Embedded Antenna 2.4 GHz; 5 GHz KEY BENEFITS Stay-in-Tune KYOCERA AVX antenna technology provides superior RF field containment, resulting in less interaction with surrounding components. Quicker Time-to-Market By optimizing antenna size, performance and emissions, customer and regulatory specifications are more easily met. Reliability Products are the latest RoHS version compliant APPLICATIONS • • • • Embedded design Cellular, Headsets, Tablets Gateway, Access Point Handheld 9/27/2021 • • • • • • Telematics Tracking Healthcare M2M, Industrial devices Smart Grid OBD-II KYOCERA AVX WLAN antennas use specific technology in a trace configuration to provide high performance. This antenna has unique features enabling limited range RF tuning. KYOCERA AVX antennas requires a smaller design keep-out area, carry lower program development risk which yields a quicker time-tomarket, without sacrificing RF performance. Electrical Specifications Typical Characteristics in Free Space Frequency 2400 – 2485 MHz 5150 – 5825 MHz Peak Gain 4.0 dBi 4.2 dBi 70% 70% Average Efficiency VSWR Match Feed Point Impedance Polarization Power Handling 2:1 max 50 ohms unbalanced Linear 0.5 Watt CW Mechanical Specifications & Ordering Part Number Ordering Part Number Size (mm) Weight (grams) Mounting 1000418 45.0 x 11.3 x 5.1 1.6 (Apply with Plastic Screw) Non-Metallic Surface: Mount antenna directly Metallic Surface: > 12 mm air gap Connectors U.Fl compatible receptacle on the PCB Cable Length Cables sold separately, please contact KYOCERA AVX Proprietary www.KYOCERA-AVX.com DATASHEET | Part No. 1000418 2.4 / 5 GHz KYOCERA AVX Embedded Antenna Specifications KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. VSWR and Efficiency Plots Typical Performance in Free-space 5 GHz VSWR VSWR VSWR 2.4 GHz VSWR Frequency (MHz) Frequency (MHz) 5 GHz Efficiency Efficiency (%) Efficiency (%) 2.4 GHz Efficiency Frequency (MHz) © 2021 KYOCERA AVX Frequency (MHz) tel +(1) 858.550.3820 email: eth.info@KYOCERA-AVX.com DATASHEET | Part No. 1000418 2.4 / 5 GHz KYOCERA AVX Embedded Antenna Specifications KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Antenna Radiation Patterns Typical Performance in Free-space Measured @ 2450, 5000 MHz Y Z 2450 MHz X Y Y X X Z 5000 MHz Z Y X Z © 2021 KYOCERA AVX Y Z X tel +(1) 858.550.3820 email: eth.info@KYOCERA-AVX.com DATASHEET | Part No. 1000418 2.4 / 5 GHz KYOCERA AVX Embedded Antenna Specifications KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Mechanical Dimensions Typical antenna dimensions measured in mm. Dimensions in () parenthesis are Reference Only. Part Number A B C 1000418 (45.0) (11.3) (5.1) A Top View C Side View B Bottom View © 2021 KYOCERA AVX tel +(1) 858.550.3820 email: eth.info@KYOCERA-AVX.com DATASHEET | Part No. 1000418 2.4 / 5 GHz KYOCERA AVX Embedded Antenna Specifications KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Mounting Recommendations (On-Ground) Typical antenna dimensions (mm) spacer > 12mm *Recommended minimum spacing when the 1000418 antenna is installed over a ground plane © 2021 KYOCERA AVX tel +(1) 858.550.3820 email: eth.info@KYOCERA-AVX.com
1000418 价格&库存
很抱歉,暂时无法提供与“1000418”相匹配的价格&库存,您可以联系我们找货
