SPECIFICATION
Part No.
Product Name :
AP.25M.07.0080A
25mm One Stage GPS/GALILEO Active Patch
Antenna Module with front-end Saw Filter
Features
Industry leading GPS/GALILEO antenna performance
25*25*6mm
80mm Ø1.13 I-PEX MHFI (U.FL)
15dB LNA
Wide Input Voltage 1.8V to 5.5V
Low Power Consumption
RoHS Compliant
SPE-12-8-001/D/SS
Page 1 of 9
1. Introduction
The AP.25M is a one stage 25mm active patch antenna that has been designed specifically
for embedded (inside device) integration with GPS/GALILEO receiver modules.
The AP.25M combines a 25*25*2mm advanced low profile ceramic patch antenna with a
one stage LNA and a front-end SAW filter with ultra thin coaxial cable. It comes with it’s
own integrated ground-plane. The front end SAW filter reduces the risks where there is a
cellular transmitter nearby of interference from out of band frequencies which can cause
LNA burn-out, saturation, or radiated spurious emissions.
The antenna can work on a wide input voltage from 1.8V to 5.5V with best in class power
consumption figures.
If further tuning and optimization specific to a customer device is required Taoglas offers
a custom tuned and optimized part service. Contact sales@taoglas.com for more
information. Cables and connectors can be customized according to request.
This antenna system consists of two functional blocks, the LNA portion and the patch
antenna.
SPE-12-8-001/D/SS
Page 2 of 9
2. Specification
2.1. Patch Antenna
Parameter
Specification
Frequency
1575.42 ± 1.023MHz
Gain @ Zenith
+2.0 dBic Typ. @ Zenith
Polarization
RHCP
Axial Ratio
3.0dB max. @Zenith
Patch Dimension
25*25*2mm
2.2 LNA
Parameter
Specification
Frequency
1575.42 ± 1.023MHz
F0=1575.42MHz
Outer Band Attenuation
F0±30MHz
3dB min.
F0±50MHz
15dB min.
F0±100MHz
23dB min.
Output Impedance
50Ω
Output VSWR
2.0 Max
Typ. -2dBm
Pout at 1dB Gain Compression point
Min. -6dBm
LNA Gain, Power Consumption and Noise Figure
Voltage
LNA Gain (Typ)
Power Consumption (Typ)
Noise Figure (Typ)
Min. 1.8V
13dB
2mA
2.5dB
Typ. 3.0V
15dB
4mA
2.5dB
Max. 5.5V
16dB
9mA
2.6dB
SPE-12-8-001/D/SS
Page 3 of 9
2.3 Cable* & Connector
Parameter
Specification
RF Cable
Coaxial Cable Ø1.13 ± 0.1mm, length 80 ± 2.5mm
Connector
IPEX MHFI (U.FL)
2.2. Total Specification (Through Antenna, LNA, Cable and
Connector)
Parameter
Specification
Frequency
1575.42 ± 1.023MHz
Gain
At 3V: 17 3dBic(At 90)
Output Impedance
50Ω
Polarization
RHCP
Output VSWR
Max 2.0
Operation Temperature
-40°C to + 85°C
Storage Temperature
-40°C to + 85°C
Relative Humidity
40% to 95%
Input Voltage
Min:1.8V Typ. 3.0V Max:5V
Antenna
25*25*6mm
SPE-12-8-001/D/SS
Page 4 of 9
3. LNA Gain and Out Band Rejection @3.0V
4. LNA Noise Figure @3.0V
SPE-12-8-001/D/SS
Page 5 of 9
5. Technical Drawing
SPE-12-8-001/D/SS
Page 6 of 9
6. Radiation Patterns
XY Plane
XZ Plane
YZ Plane
SPE-12-8-001/D/SS
Page 7 of 9
7. Plugs Usage Precautions
7.1. Mating / unmating
(1) To disconnect connectors, insert the end portion of I-PEX under the connector flanges
and pull off vertically, in the direction of the connector mating axis.
(2) To mate the connectors, the mating axes of both connectors must be aligned and the
connectors can be mated. The "click" will confirm fully mated connection. Do not attempt
to insert on an extreme angle.
7.2. Pull forces on the cable after connectors are mated
After the connectors are mated, do not apply a load to the cable in excess of the values
indicated in the diagram below.
SPE-12-8-001/D/SS
Page 8 of 9
8. Packaging
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves the rights to this document and the information contained herein. Reproduction, use or
disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-12-8-001/D/SS
Page 9 of 9
很抱歉,暂时无法提供与“AP.25M.07.0080A”相匹配的价格&库存,您可以联系我们找货
