Meteor
Part No:
FW.90.SMA.M
Description:
Cellular 2G/3G/4G Flexible Whip Monopole Antenna
Features:
Covers most Worldwide 4G/3G Cellular bands from 698-3500MHz
Also Covers CAT-M/NB-IoT Bands
Robust Inner Steel Core
SMA Male Connector
IP65 Rated Waterproof
RoHS & Reach Compliant
SPE-11-8-142-K
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
6
4.
Radiation Patterns
8
5.
Mechanical Drawing
14
6.
Packaging
15
Changelog
16
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-11-8-142-K
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
The FW.90 is a flexible cellular whip antenna with IP65 housing. It has a wide response and high peak gain.
Ideal for outdoor environments which require high gain, on both lower and upper bands. It's unique
characteristic is it has stable peak gain on across common cellular bands used worldwide.
1.
Typical Applications include:
Smart Metering
Remote Pipeline Monitoring
Transportation
1.
1.
Introduction
Introduction
Introduction
The FW.90 can be used with a Wall Mounting Bracket, and we have designed an L Shaped Bracket for use
with the Whip Antenna, the part number for this option is WM.90.A.305111. Testing of the whip antenna on
the bracket, in free-space, and on a reference ground-plane has been done to show the benefit of the Lbracket.
Introduction
This antenna delivers wider coverage areas and more reliable connections for professional customers in the
automotive, industrial industries. The whip is made up of a flexible inner steel core covered by TPU so
extremely resistant to collisions and maintaining its original shape and RF performance. The whip and the
connection internally to the bracket is IP65 waterproof.
The FW.90’s connector can be customized subject to NRE, for further information please contact your
regional Taoglas customer support team.
SPE-11-8-142-K
www.taoglas.com
3
2.
Specifications
3.
Antenna Characteristics2.
Frequency (MHz)
698~896
Specifications
Electrical
880~960
1710~1880 1850~1990
1710~2170
2570~2690
3300~3500
Peak Gain (dBi)
3.
4.
Antenna
Free Space Characteristics
-1.7
-0.3
2.5
3.4
2.8
3.5
2.1
With Ground plane(30x30cm)
-1.7
2
4.7
5.1
4.6
4.7
4.3
L - Bracket
0.7
1.8
1.8
2.2
2.2
1.8
0.5
Average Gain (dB)
Antenna Radiation Patterns3.
Antenna
Free Space
-5.8
-4.6
Characteristics2.
With Ground plane(30x30cm) Specifications
-5.2
-3
L - Bracket
-4
-2.4
-1.9
-1.5
-1.7
-2.1
-3.4
-1.7
-1.4
-1.7
-1.8
-1.4
-2.7
-3
-2.8
-2.9
-5.7
65.4
70.8
67.3
Specifications
61.6
46
Efficiency
3.
3.
4.
Free Space Characteristics2.
26.4
35.1
Antenna
30.8
50.3
67.3
71.8
67.9
65.5
67.2
L - Bracket
43.3
57.2
53.9
49.9
53.2
51.6
27.4
Impedance
50Ω
Polarization
Linear
Radiation Pattern
Omni
Input Power
50 W
Antenna
Tested PowerRadiation Patterns3.Antenna 10 W
Characteristics
4.
Mechanical
Height
255mm
Base Diameter
16mm
Whip Diameter
4mm
Antenna
Casing Radiation Patterns
ABS
Connector
SMA Male
Environmental
4.
Temperature Range
-40°C to 85°C
Antenna
Humidity
Non-condensing 65°C 95% RH
Characteristics
4.
Antenna Radiation Patterns3.Antenna
Characteristics2.
SPE-11-8-142-K
Specifications
www.taoglas.com
4
5G/4G Bands
Band Number
5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA
Uplink
Downlink
1
UL: 1920 to 1980
DL: 2110 to 2170
2
UL: 1850 to 1910
DL: 1930 to 1990
3
UL: 1710 to 1785
DL: 1805 to 1880
4
UL: 1710 to 1755
DL: 2110 to 2155
5
UL: 824 to 849
DL: 869 to 894
7
UL: 2500 to 2570
DL:2620 to 2690
8
UL: 880 to 915
DL: 925 to 960
9
UL: 1749.9 to 1784.9
DL: 1844.9 to 1879.9
11
UL: 1427.9 to 1447.9
DL: 1475.9 to 1495.9
12
UL: 699 to 716
DL: 729 to 746
13
UL: 777 to 787
DL: 746 to 756
14
UL: 788 to 798
DL: 758 to 768
17
UL: 704 to 716
DL: 734 to 746
18
UL: 815 to 830
DL: 860 to 875
19
UL: 830 to 845
DL: 875 to 890
UL: 832 to 862
DL: 791 to 821
21
UL: 1447.9 to 1462.9
DL: 1495.9 to 1510.9
22
UL: 3410 to 3490
DL: 3510 to 3590
23
UL:2000 to 2020
DL: 2180 to 2200
24
UL:1625.5 to 1660.5
DL: 1525 to 1559
25
UL: 1850 to 1915
DL: 1930 to 1995
26
UL: 814 to 849
DL: 859 to 894
27
UL: 807 to 824
DL: 852 to 869
28
UL: 703 to 748
DL: 758 to 803
29
UL: -
DL: 717 to 728
30
UL: 2305 to 2315
DL: 2350 to 2360
31
UL: 452.5 to 457.5
DL: 462.5 to 467.5
32
UL: -
DL: 1452 – 1496
35
1850 to 1910
38
2570 to 2620
39
1880 to 1920
40
2300 to 2400
41
2496 to 2690
42
3400 to 3600
43
3600 to 3800
48
3550 to 3700
66
UL: 1710-1780
DL: 2110-2200
71
617 to 698
74/75/76
1427 to 1518
77
3300 to 4200
78
3300 to 3800
79
4400 to 5000
SPE-11-8-142-K
Covered
www.taoglas.com
5
3.
4.
3.1
Return Loss
Characteristics
4.
-10
-15
-20
(dB)
4.
-25
Characteristics
-30
Free Space
-35
4.
L - Bracket
-40
500
1000
1500
2000
(MHz)
Characteristics
3.2
4.
100
2500
3000
3500
Efficiency
90
80
4.
70
60
4.
50
40
30
10
Free Space
L - Bracket
800
1000
Characteristics
1200
1400
1600
1800
2000
2200
2400
2600
2800
3000
3200
3400
3600
(MHz)
4.
SPE-11-8-142-K
www.taoglas.com
6
3.3
Peak Gain
7
6
5
4
3
(dBi)
2
1
Free Space
-2
-3
L - Bracket
-4
600
800
1000
1200
1400
1600
1800
2000
2200
2400
2600
2800
3000
3200
3400
3600
(MHz)
3.4
Average Gain
-2
(dB)
-3
-4
-5
-6
Free Space
-7
L - Bracket
-8
600
800
1000
1200
1400
1600
1800
2000
2200
2400
2600
2800
3000
3200
3400
3600
(MHz)
SPE-11-8-142-K
www.taoglas.com
7
4.
Radiation Patterns
4.
4.
4.1
Antenna Stand Alone
4.
Antenna Radiation
Y Patterns
4.
Antenna ZRadiation Patterns
X
4.
4.
4.
4.
SPE-11-8-142-K
www.taoglas.com
8
XY Plane
XZ Plane
X
X
Y
X
Z
X
Y
X
X
Y
SPE-11-8-142-K
Z
Z
www.taoglas.com
9
4.2
Antenna with Ground plane (30*30cm)
Y
Z
X
SPE-11-8-142-K
www.taoglas.com
10
XY Plane
XZ Plane
X
X
Y
Z
X
X
Y
X
X
Y
SPE-11-8-142-K
Z
Z
www.taoglas.com
11
4.3
Antenna with L-Bracket
Y
Z
X
SPE-11-8-142-K
www.taoglas.com
12
XY Plane
XZ Plane
X
X
Y
X
Z
X
Y
X
X
Y
SPE-11-8-142-K
Z
Z
www.taoglas.com
13
5.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-11-8-142-K
Mechanical Drawing
www.taoglas.com
14
6.
Packaging
6. 1pc FW.90.SMA.M
Packaging5.
Mechanical Drawing
per PE Bag
6.
50mm
Bag Dimension: 200*100mm
Weight: 50g
Packaging
400mm
7.
Mechanical
Drawing
50pcs FW.90.SMA.M per Large PE Bag
6.
Packaging5.
6.
Packaging
360mm
Bag Dimensions: 520*360mm
Weight: 2.5Kg
Mechanical Drawing
520mm
7. 200pcsApplication
Note6. Packaging
FW.90.SMA.M per Carton
Dimensions: 360*310*160mm
Weight: 10.2Kg
7.
Application Note
7.
7.
310mm
360mm
160mm
Mechanical
Drawing
6.
Packaging5.
SPE-11-8-142-K
Mechanical Drawing
www.taoglas.com
15
Changelog for the datasheet
SPE-11-8-142 - FW.90.SMA.M
Revision: K (Current Version)
Date:
Changes:
Changes Made by:
2020-03-20
Updated to show new data
Jack Conroy
Previous Revisions
Revision: E
Revision: J
Date:
Changes:
Changes Made by:
2019-08-16
Updated to new format
Dan Cantwell
Revision: I
Date:
Changes:
Changes Made by:
2014-03-21
Updated spec to include 698~798MHz and also for
2570~2690Mhz
Aine Doyle
Revision: D
Date:
Changes:
Changes Made by:
2017-08-04
Updated as per PCN-17-8-026
Andy Mahoney
Revision: H
Date:
Changes:
Changes Made by:
Changes Made by:
Andy Mahoney
Changes Made by:
SPE-11-8-142-K
Changes Made by:
Date:
Changes:
Changes Made by:
2012-03-23
Packaging Details Updated
Made by Andy Mahoney
Revision: B
2017-04-04
Added LTE Band Table
Peter Monahan
Revision: F
Date:
Changes:
2012-07-08
Revision: C
2017-05-02
Update as per PCN
Revision: G
Date:
Changes:
Date:
Changes:
Date:
Changes:
2012-02-27
Changes Made by:
Revision: A (Original First Release)
2014-06-08
Retested
Date:
Notes:
2011-11-22
Aine Doyle
Author:
Wayne Yang
www.taoglas.com
16
www.taoglas.com
SPE-11-8-142-K
© Taoglas
www.taoglas.com
17
很抱歉,暂时无法提供与“FW.90.SMA.M”相匹配的价格&库存,您可以联系我们找货
