Underside View
Top View
(this side faces
the passenger)
(this side faces
the sky)
Stingray
MA203w.AB.002
Specification
Part No.
MA.203w.AB.002
Product Name
Stingray
GPS/Penta-band Cellular Adhesive Antenna
Feature
High gain LNA up to 32dB
(GSM/CDMA/PCS/DCS/UMTS/GPRS/EDGE/ HSPA)
Height 10.8mm Diameter 55.1mm
Waterproof IP67 Version
ROHS Compliant
SPE-11-8-002/C/SS |
page 1 of 11
MA.203W.A.A301111.B301111
1. Introduction
This is a combination high performance
GPS and Penta-band Cellular (GSM/CDMA/
PCS/DCS/ / UMTS / GPRS / EDGE/ HSPA)
antenna to simplify AVL or Fleet
management antenna systems worldwide.
Its high quality low profile covert housing
can be attached onto the glass or even out
of sight under the dashboard.
This combination of a high gain GPS
antenna and a leading edge penta band
cellular antenna is ideal for those
applications that require durability,
small size and covert installation,
and reliable reception and transmission
crossing through different mobile networks.
1.1 Features
GPS
High LNA Gain up to 32 dB
Antenna Gain 30 ± 2 dB
Miniaturized to 55.15x12mm
Low Noise 1.5 dB max
Cellular
Advanced Penta-Band Cellular Antenna
(GSM/CDMA/PCS/DCS/UMTS/GPRS/EDGE/HSPA)
Other
Water Resistant IP 67
Quality textured covert design. Low profile
UV resistant ABS housing
Comes with high grade 3M double sided tape for quick and easy mounting
Optional cables and connectors
SPE-11-8-002/C/SS |
page 2 of 11
2. Specification
2.1 Performance Specifications
Items
GPS Patch Antenna
Cellular Antenna
Features
High performance GPS ceramic patch
antenna with cutting edge low
noise amplifier
CDMA: 824~896MHz
DCS: 1710~1880MHz
PCS: 1850~1990MHz
GSM: 880~960MHz
Centre Frequency
1593MHz ± 2MHz(Free Space)
As above
Gain
-3.0dB typ.
As patterns
Axial Ratio :2.0 dB max
Polarization
RHCP
Bandwidth
10 MHz min
VSWR
1.92 Max.
Impedance
50Ω
50Ω
Cable / Connector
Standard 1/2/3/5/10mRG-174
Cables and Connectors Fully Customizable
10dB Typ
Return Loss
Size
59.8mm * 16mm
Housing
UV resistant ABS
*Note: Specifications may be subject to change
2.2 LNA GPS Antenna
Parameter
Specification
Frequency (MHz)
1575.42 ± 1.023MHz
Gain
28dB Typical
Output Impedance
50Ω
Output VSWR
1.92 Max
DC Power Input
2.7-3.3V
Noise Figure
1.5dB Typ.
Power Consumption
6mA
SPE-11-8-002/C/SS |
page 3 of 11
3. GPS Ceramic Patch Antenna
3.1 Free Space
Tr1
S22 Log Mag 10.00dB / Ref 0.000dB [F2]
50.00
>1 1.5930000 GHz -17.330 dB
40.00
30.00
20.00
10.00
0.000
-10.00
1
1
-20.00
-30.00
-40.00
-50.00
1 Start 1.3 GHz
IFBW 30 kHz
Stop 1.9 GHz C?
SPE-11-8-002/C/SS |
page 4 of 11
3.2 With Housing, Glass Mount
S22 REVERSE REFLECTION
LOG MAGNITUDE
CHN2
REF = 0.000 dB
TRANSMISSION / REFLECTION
10.000 dB/DIV
1 :
-16.548 dB
1 575.420 000 MHz
1
1 300.000 000 MHz
S22 REVERSE
IMPEDANCE
1 900.000 000 MHz
REFLECTION
1
.5
2
.2
49.225 Ω
-14.901 j Ω
1 575.420 000 MHz
5
1
1 :
-5
-. 5
-2
SPE-11-8-002/C/SS |
page 5 of 11
4. GSM Radiation Patterns
XZ Plane
YZ Plane
880 MHz
345
345
330
315
300
295
75
-20
-10
dB
90
105
255
240
60
75
270
-30
dB
90
120
225
135
150
210
195
165
180
-10
105
150
195
-20
255
135
210
45
295
120
225
30
300
60
-30
15
315
45
270
30
165
180
960 MHz
345
345
330
315
300
295
75
-20
-10
dB
90
105
255
240
120
225
135
150
210
195
180
165
30
45
300
60
-30
15
315
45
270
30
60
295
75
270
-30
-20
-10
dB
90
105
255
240
120
225
135
150
210
195
180
165
SPE-11-8-002/C/SS |
page 6 of 11
XZ Plane
YZ Plane
1710 MHz
345
345
330
315
300
295
75
-20
-10
dB
90
105
255
240
60
75
270
-30
dB
90
120
225
135
150
210
195
165
180
-10
105
150
195
-20
255
135
210
45
295
120
225
30
300
60
-30
15
315
45
270
30
165
180
1880 MHz
345
345
330
315
300
295
75
-20
-10
dB
90
105
255
240
120
225
135
150
210
195
180
165
30
45
300
60
-30
15
315
45
270
30
60
295
75
270
-30
-20
-10
dB
90
105
255
240
120
225
135
150
210
195
180
165
SPE-11-8-002/C/SS |
page 7 of 11
5. GSM Antenna Return Loss
5.1 Free Space
Tr1
50.00
40.00
30.00
20.00
1
2
3
4
5
6
7
>8
824.00000 MHz
960.00000 MHz
1.7100000 GHz
1.8800000 GHz
1.9300000 GHz
1.9900000 GHz
2.1100000 GHz
2.1700000 GHz
-5.0445 dB
-3.8019 dB
-2.2491 dB
-6.5139 dB
-10.088 dB
-16.920 dB
-9.6193 dB
-6.4489 dB
10.00
0.000
-10.00
8
1
3
2
1
4
7
5
-20.00
6
-30.00
-40.00
-50.00
Start 100 MHz
IFBW 30 kHz
Stop 3 GHz Cor !
SPE-11-8-002/C/SS |
page 8 of 11
5.2 With Housing, Glass Mount
Tr1
S11 Log Mag 10.00dB / Ref 0.000dB [F2]
50.00
40.00
30.00
>1
2
3
4
5
6
824.00000 MHz
960.00000 MHz
1.7100000 GHz
1.8800000 GHz
1.9300000 GHz
1.9900000 GHz
-10.236 dB
-2.1987 dB
-18.335 dB
-8.4259 dB
-7.7409 dB
-7.7409 dB
20.00
10.00
0.000
1
2
-10.00
-20.00
45
6
1
3
-30.00
-40.00
-50.00
1 Start 100 MHz
IFBW 30 kHz
Stop 3 GHz Cor!
SPE-11-8-002/C/SS |
page 9 of 11
6. Drawings
Name
Material
Finish
QTY
1
Housing
ABS
Black
1
2
Round Label
Art Paper
White
1
3
Scotch Brand Acrylic Foam Tape
3M 4612
White Liner
1
4
Heat Shrink Tube
PE
Black
2
5
Cellular Label
Coated Paper
Blue
1
6
GPS Label
Coated Paper
Orange
1
Name
Spec
XX
Cable Length
3000mm ± 30mm
Finish
QTY
YY
Cable Type
RG174
Black
2
ZZ
Connector Type
SMA(M) ST
Gold
2
1
SPE-11-8-002/C/SS | page 10 of 11
5 包裝規格
5.1 每個小 PE 袋放置 1 天線
【1pcs antenna per small PE bag】
5.2 每個箱子放置 80 個小 PE 袋,如下圖所示
【80 small PE bag per box】
5.3 封口時須注意
可壓到天線,裝入需平整 可雜
7. Packaging
【Antenna should be placed flat and neat in the PE bag. Hot seal the PE bag without
pressing or damage the antenna】
5.4 清點每袋
可短缺
1pcs antenna
per small PE bag
each PE bag】
【Confirm
the quantity
80 small
PE bag perin
box
MA.203
小
PE PE
bag袋
層
108pcs/pad
每層 10PCS
箱子
80 pcs per carton
LESS OTHER SPECIFIED TOLERANCES ON:
X.X=±
X.XX=
NGLES=±
HOLEDIA=±
Taoglas makes
no warranties based on the
CALE: xxxx
UNIT:mm
accuracy
or
completeness
the Wayne
contents
RAWN BY:Jason
CHECKED of
BY:
of
this
document
and
reserves
the
to
ESIGNED BY: Eason APPROVED BY: right
Wayne
changes to specifications and
TITLE:make
MA.203W
Antenna Assembly
O NO: PSP-13-8-xxxx
product descriptions at any time
without notice.
Taoglas reserves all rights to this document
and the information contained herein.
DOCUMENT
N O.
MA.203W.AB.002
Reproduction, use or disclosure to
third parties without express permission
is strictly prohibited.
Copyright © Taoglas
PAGE Ltd.
REV.
(MA.203W.A.A301111.B301111
PAGE
8
D 01
| page 11 of 11
OFSPE-11-8-002/C/SS
8
很抱歉,暂时无法提供与“MA203W.AB.002”相匹配的价格&库存,您可以联系我们找货
