A Tallysman Accutenna®
TW3865 / TW3867 GPS L1/L2 + GLONASS G1/G2 + BeiDou B1 + Galileo E1
A
The TW3865 and TW3867 employ Tallysman’s unique
Accutenna technology providing dual band GPS L1 & L2,
GLONASS G1 & G2, BeiDou B1, and Galileo E1 coverage and is
especially designed for precision dual frequency positioning.
The antennas feature a precision tuned, circular dual feed,
stacked patch element. The signals from the two orthogonal
feeds are combined in a hybrid combiner, amplified in a wideband LNA, then band-split for narrow filtering in each band
and further amplified prior to recombination at the output.
The TW3867 has a strong pre-filter to mitigate intermodulated signal interference from LTE and other cellular
bands.
Both antennas offer excellent axial ratio and a tightly grouped
phase center.
They cover GPS L2 (1227.6MHz), GLONASS G2 (1248MHz
centre), GPS
L1/WAAS/EGNOS/MSAS
(1575.42MHz),
GLONASS G1 (1602MHz, centre), BeiDou B1 (1561 MHz , 1589
MHz), and Galileo E1 (
The OEM antennas are supplied with a standard 60mm
diameter circular ground plane, with a coaxial cable
terminated with your choice of connector (right angle MCX is
shown in the drawing). Mounting holes are provided for
attachment to larger ground planes. Custom tuning and
ground plane options may be available, depending on
purchase level commitment.
Applications
Precision GPS position
Dual Frequency RTK receivers
Military & Security
Network Timing and Synchronization
Features
Benefits
Very low Noise Preamp,
Axial ratio L1: ≤1dB typ. 1.5 dB max
Tight Phase Center Variation
LNA Gain 28 dB typ.
Low current: 24 mA typ.
ESD circuit protection: 15 KV
Invariant performance from: +2.5 to 12VDC
Ideal for dual frequency RTK and PPP
surveying systems
Great multipath rejection
Increased system accuracy
Great signal to noise ratio
RoHS and REACH compliant
Specifications (Measured a Vcc = 3V, and Temperature=25°C)
Antenna
Patch Architecture
L2 Gain (100mm ground plane), 1227.6-1246MHz
L1 Gain (100mm ground plane), 1557MHz-1606MHz
Axial Ratio, L1/G1/E1/B1, L2/G2
1dB Bandwidth,
Polarization
Electrical
Bandwidth
Overall LNA Gain
Gain Variation with Temperature.
LNA Noise Figure
VSWR (at LNA output)
Supply Voltage Range
EMI Immunity
Supply Current
ESD Circuit protection
Out-of-Band Rejection
L1
30 dB
30 dB
>35 dB
>1284 MHz
>32 dB
Mechanicals & Environmental
Mechanical Size, Ground Plane
Operating Temperature Range
Weight
Attachment Method
Environmental
Shock
Vibration
Warranty
Circular, Dual Feed, Dual Stacked Patch
3 dBic Min at Zenith on 100mm Ground Plane
4.5 dBic Min at Zenith on 100mm Ground Plane
≤1dB typ. 1.5 dB max; ≤1.5 dB typ. 2dB max
L2: 1227MHz-1250MHz
L1: 1557MHz–1606MHz
RHCP,
60mm diameter, 0.75mm thick, see mechanical drawing
-40°C to +85°C
70 g (excluding cable)
Through hole screws in ground plane
Vertical axis: 50 G, other axes: 30 G
3 axis, sweep = 15 min, 10 to 200 Hz sweep: 3 G
One year – parts and labour
Ordering Information
TW3865 – GPS L1/L2 + GLONASS G1/G2 + BeiDou B1 + Galileo E1 antenna
33-3865-xx-yyyy-zz
TW3867 - GPS L1/L2 + GLONASS G1/G2 + BeiDou B1 + Galileo E1 antenna
33-3867-xx-yyyy-zz
Where xx = connector type, yyyy = cable length in mm and zz = assigned by Tallysman for custom tuning
Please refer to the Ordering Guide (http://www.tallysman.com/orderingguide.php) for the current and complete list of available
connectors.
Tel +1 613 591 3131
36 Steacie Drive, Ottawa ON K2K 2A9 Canada
Fax 613 591 3121
sales@tallysman.com
The information provided herein is intended as a guide only and is subject to change without notice. This document is not to be
regarded as a guarantee of performance. Tallysman Wireless Inc. hereby disclaims any or all warranties and liabilities of any kind. ©
2010 Tallysman Wireless Inc. All rights reserved.
Rev 3.7
很抱歉,暂时无法提供与“33-3865-05-0150”相匹配的价格&库存,您可以联系我们找货
