Impexa 2.4 GHz SMD Antenna
Part No. A6150
gigaNOVA®
Product Specification
1 Features
Designed for 2.4 GHz applications: Bluetooth®, Wi-Fi® (802.11b/g), ZigBee®, etc.
Easy to integrate
Low profile design for use with no ground beneath the antenna
High efficiency
Light weight
Intended for SMD mounting
Supplied in tape on reel
2 Description
Impexa is intended for use with all 2.4 GHz applications. The antenna uses a ground plane
in order to radiate efficiently, but this ground plane must not extend underneath the
antenna itself.
The antenna has the feed location on the left of the antenna.
3 Applications
Mobile phones
PDAs
PNDs
Headsets
PMPs / MP3s
Laptops
PC-Cards
Sensors
Antennas for Wireless M2M Applications
1
Product Specification AE040034-J
Part No. A6150
4 Part numbers
Impexa A6150
5 General data
Product name
Impexa 2.4 GHz
Part Number
A6150
Frequency
2.4 – 2.5 GHz
Polarization
Linear
Operating temperature
-40 ºC to +85 ºC
Impedance with
matching
50 Ω
Weight
0.05 g
Antenna type
SMD
Dimensions
6.1 x 3.9 x 1.1 [mm]
6 Electrical characteristics
Typical performance
Peak gain
1.0 dBi
Average gain
-1.9 dBi
Average efficiency
Maximum Return Loss
Maximum VSWR
65%
-10 dB
Conditions
All data measured on Antenova’s reference boards,
part numbers A6150-U1 and A6250-U1
Data given for the 2.4 – 2.5 GHz frequency range
1.9:1
2
Part No. A6150
7 Electrical performance
7-1 Return Loss
[dB]
mtool5
-10
-20
-30
-40
2200
2300
2400
2500
2600
[MHz]
2700
7-2 VSWR
mtool5
5
4
3
2
1
2200
[MHz]
2300
2400
2500
2600
2700
3
Part No. A6150
7-3 Antenna patterns
Z
dBi
5
-15
X
XY plane
ZY plane
Y
-35
XZ plane
Patterns show combined polarisations
measured on reference board A6150-U1
4
Part No. A6150
8 Antenna dimensions
Impexa
L
W
H
Length
Width
Height
6.1 ± 0.2
3.9 ± 0.2
1.1 ± 0.2
Dimensions in mm
9 Antenna footprint
Impexa (Part No: A6150)
* CAD files of the antenna footprint are available to download from
www.antenova-m2m.com
J
K
O
S
T
1.3 ± 0.1
3.4 ± 0.1
≥ 0.5 ± 0.1
1 ± 0.1
1 ± 0.1
Dimensions in mm
Dimension O stated is a minimum. Depending on the application, it can be
increased to optimise the antenna performance. For more details, please contact
sales@antenova- m2m.com
5
Part No. A6150
10 Electrical interface
10-1 Transmission lines
Ω
All transmission lines should be designed to have a characteristic impedance of 50
The length of the transmission lines should be kept to a
minimum
Any other parts of the RF system like transceivers, power amplifiers, etc, should also be
designed to have an impedance of 50 Ω
Once the material for the PCB has been chosen (PCB thickness and dielectric constant), a
coplanar transmission line can easily be designed using any of the commercial software
packages for transmission line design. For the chosen PCB thickness, copper thickness and
substrate dielectric constant, the program will calculate the appropriate transmission line width
and gaps on either side of the track so the characteristic impedance of the coplanar
transmission line is 50 Ω .
10-2 Matching circuit
The antenna requires a matching circuit that must be optimized for each customer’s product.
The matching circuit will require up to three components and the following pad layout should be
designed into the device so the correct circuit can be installed.
The antenna feed pad is indicated in the drawing above. Additional pads are for mechanical
attachment only and should not be grounded.
6
Part No. A6150
In addition to the matching circuit, a separate DC blocking capacitor will also be required
between the radio and the antenna matching circuit.
Note: The component values for the matching circuit will vary depending on the size of
the PCB and surrounding components. The impedance of the antenna should be measured
before selecting suitable matching components. Antenova M2M offers this service on request.
Contact sales@antenova-m2m.com for further information.
10-3 Antenna placement
Antenova M2M strongly recommends placing the antenna near the edge of the board.
Maximum antenna performance is achieved by placing the antenna towards one of the corners
of the PCB.
Additional ground and components near the antenna should be at a distance of at least 2 mm.
Where possible the antenna should be clear of ground from both sides, although the antenna
can work well with a minimum clearance of D ≥ 2 mm as shown in the drawing above.
7
Part No. A6150
10-4 Reference boards
The reference boards have been designed for evaluation purposes of Impexa 2.4 GHz and
they include a SMA female connector
Impexa
Part No. A6150-U1
Dimensions in mm
To order a reference board contact sales@antenova-m2m.com.
8
Part No. A6150
11 Soldering
This antenna is suitable for lead free soldering.
The reflow profile should be adjusted to suit the device, oven and solder paste, while
observing the following conditions:
- The maximum temperature should not exceed 240 ºC
- However for lead free soldering, a maximum temperature of 255 ºC for no more than
20 seconds is permitted.
- The antenna should not be exposed to temperatures exceeding 120 ºC more than 3
times during the soldering process.
12 Hazardous material regulation conformance
The antenna has been tested to conform to RoHS requirements. A certificate of
conformance is available from Antenova M2M’s website.
13 Packaging
13-1 Optimal storage conditions for packaged reels
Temperature
-10ºC to 40ºC
Humidity
Less than 75% RH
Shelf Life
18 Months
Storage place
Away from corrosive gas and direct sunlight
Packaging
Reels should be stored in unopened sealed
manufacturer’s plastic packaging.
Note: Storage of open reels of antennas is not recommended due to possible oxidization of pads on
antennas. If short term storage is necessary, then it is highly recommended that the bag containing
the antenna reel is re-sealed and stored in like storage conditions as in above table.
9
Part No. A6150
13-2 Tape characteristics
Impexa
[Part Number: A6150]
W
F
E1
P0
P1
P2
A0
B0
K0
T
D0
D1
24 ± 0.3
11.5 ± 0.1
1.75 ± 0.1
4 ± 0.1
8 ± 0.1
2 ± 0.1
4.3 ± 0.2
6.6 ± 0.2
1.5 ± 0.2
0.3 ± 0.05
Min 1.5
Min 1.5
Dimensions in mm
Quantity
Leading Space
Trailing Space
1000 pcs / reel
50 blank antenna
holders
37 blank antenna
holders
12
Revised 5 November 2015
Part No. A6150
13-3 Reel dimensions
Width
24 mm
Reel
Diameter
Hub
Diameter
Shaft
Diameter
180 mm
(7”)
50 mm
(2”)
13 mm
13-4 Box dimensions
Width
W
Breadth
B
Thickness
H
195 mm
195 mm
37 mm
13-5 Bag properties
Reels are supplied in protective plastic packaging
13-6 Reel label information
Impexa
13
Part No. A6150
Corporate Headquarters
North America Headquarters
Asia Headquarters
Antenova Ltd.
nd
2 Floor, Titan Court
3 Bishop Square
Hatfield
AL10 9NA
Antenova Ltd.
100 Brush Creek Road, Suite 103
Santa Rosa
California, 95494
USA
Antenova Asia Ltd.
4F, No. 324, Sec. 1, Nei-Hu Road
Nei-Hu District
Taipei 11493
Taiwan, ROC
Tel:
+44 1223 810600
Email: sales@antenova-m2m.com
Tel:
+1 707 890 5202
Tel:
+886 (0) 2 8797 8630
Fax:
+886 (0) 2 8797 6890
Copyright Antenova Ltd. All Rights Reserved. Antenova , Antenova M2M , gigaNOVA , the Antenova
product family names, and the Antenova and Antenova M2M logos are trademarks and/or registered trademarks
of Antenova Ltd. Any other names and/or trademarks belong to their respective companies.
The materials provided herein are believed to be reliable and correct at the time of print. Antenova does not
warrant the accuracy or completeness of the information, text, graphics or other items contained within these
information. Antenova further assumes no responsibility for the use of this information, and all such
information shall be entirely at the user’s risk.
14
很抱歉,暂时无法提供与“A6150”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+5.038361000+0.60945
- 3000+4.704943000+0.56912
- 5000+4.445635000+0.53775
