DATASHEET
Part No. 1001826
Product: ISM 868 MHz
Embedded PCB
Antenna with Cable
Part No. 1001826
ISM 868 MHz Embedded PCB Antenna with Cable
868 MHz
Supports: Tracking, Smart Home, Agriculture, Automotive, Healthcare, Digital Signage, Wearables, Industrial Devices
Ethertronics’ ISM antennas deliver on the key needs of device designers for
higher functionality and performance in smaller/thinner designs. These
innovative antennas provide compelling advantages for 868 MHz ISM
enabled handheld devices, media players and other mobile devices.
Real-World Performance and Implementation
Antennas may look alike on the outside, but the important difference is
inside. Other antennas may contain simple PIFA or monopole designs that
interact with their surroundings, complicating layout or changing
performance with use position. Ethertronics’ antennas utilize patented
Isolated Magnetic Dipole (IMD) technology to deliver a unique size and
performance combination.
Electrical Specifications
Typical performance on 100 x 65 mm PCB
868 MHz
KEY BENEFITS
Stay-in-Tune
IMD antenna technology
provides superior RF field
containment, resulting in
less interaction with
surrounding components.
Quicker Time-to-Market
By optimizing antenna size,
performance and
emissions, customer and
regulatory specifications
are more easily met.
Reliability
Products are the latest
RoHS version compliant.
Frequency
868 - 870 MHz
Peak Gain
-9 dBi
Average Efficiency
7.5%
Return Loss
Feed Point Impedance
Polarization
Power Handling
Embedded
design
Cellular,
Headsets,
Tablets
Gateway,
Access
Point
Handheld
21-Nov-18
Telematics
Tracking
Healthcare
M2M,
Industrial
devices
Smart Grid
OBD-II
50 ohms unbalanced
Linear
0.5 Watt CW
Mechanical Specifications & Ordering Part Number
Size (mm)
Weight (grams)
APPLICATIONS
< -2.5 dB
Cable/Connector (mm)
1001826
34.00 x 7.0 x 0.8
0.83
Length: 100
Diameter: 1.13
Color: Black
Connector: U.Fl compatible
Mounting
Adhesive on bottom side on antenna
Packaging
PE bags
Proprietary
www.ethertronics.com
DATASHEET | Part No. 1001826
ISM 868 Embedded PCB Antenna Specifications
Ethertronics produces a wide variety of standard and custom antennas to meet user needs.
VSWR, Efficiency Plots (Tuned @ 868MHz)
Return Loss
Efficiency
30
-7
Efficiency (%)
Return Loss (dB)
-2
-12
-17
-22
-27
865
870
875
Frequency (MHz)
880
860
865
870
875
Frequency (MHz)
880
Antenna Radiation Patterns
Measured @ 868 MHz
Test Setup
© 2018 Ethertronics
tel +(1) 858.550.3820 | fax +(1) 858.550.3821
email: eth.info@avx.com
5501 Oberlin Drive, Suite 100 San Diego, CA 92121 - USA
Antenna Demo Board
Typical layout dimensions (mm)
Part Number
A (mm)
B (mm)
C (mm)
D (mm)
1001826
34.0 ± 0.3
7.0 ± 0.3
101.35 ± 3.0
2.3 (max)
A
C
B
Top View
D
Front View/Height
Adhesive
Bottom View
© 2018 Ethertronics
很抱歉,暂时无法提供与“1001826”相匹配的价格&库存,您可以联系我们找货
