1002289
    ETHERTRONICS
    833MHz, 2.2GHz LTE Flat Patch RF Antenna 700MHz ~ 960MHz, 1.71GHz ~ 2.7GHz Connector, U.FL Adhesive
1002289 数据手册
DATASHEET Part No. 1002289 Product: LTE / Cellular FPC Embedded Antenna Part No.1002289 LTE / Cellular Wide Band FPC Embedded Antenna 700 / 750 / 850 / 900 / 1800 / 1900 / 2100 / 2700 MHz Supports: Broadband LTE (OCTA-BAND), LTE CAT-M, NB-IoT, SigFox, LoRa, Cellular LPWA, RPMA, Firstnet KYOCERA AVX LTE cellular embedded antenna 1002289 address the challenges facing today’s product designers. Based on a flexible substrate for easier integration, high performance and isolation characteristics, this antenna offers better connectivity. In addition, 1002289 supports all the worldwide cellular bands for LTE with backward compatibility. The 1002289 is offered in many standard cable lengths ranging up to 200mm. Ordering part number guide is located at end of document for selection ease. LTE / Cellular FPC Embedded Antenna Low Band : 698 - 960 MHz High Band: 1710 - 2690 MHz KEY BENEFITS Reduced Costs and Time-to-Market Standard antenna eliminates design fees and cycle time associated with a custom solution; getting products to market faster. Greater Flexibility with Unique Form Factors KYOCERA AVX technology helps you deliver more advanced ergonomic designs without adverse impact on product performance. RoHS Compliant Products are the latest RoHS version compliant. APPLICATIONS • • • • • • Medical applications Home automation Smart metering M2M, Industrial devices IoT Firstnet 9/27/2021 • • • • • • • • • • Automotive Healthcare Point of Sale Tracking NB-IoT Sigfox LoRa Cellular LPWA RPMA LTE CAT-M Electrical Specifications Typical Characteristics, using 75 x 140 mm ground plane with 7.6 mm cable. Antenna is mounted directly on plastic material. Frequency (MHz) 698 - 960 MHz 1710 – 2690 MHz Average Efficiency (Longer Edge) 74% 58% Average Efficiency (Shorter Edge) 67% 63% Peak Gain (Longer Edge) 2.9 dBi 4.3 dBi Peak Gain (Shorter Edge) 1.8 dBi 4.2 dBi VSWR Match Feed Point Impedance Polarization Power Handling Radiation Pattern 2.5:1 max 50 ohms unbalanced Linear 2 Watts CW Omni-directional Mechanical Specifications & Ordering Part Number Ordering Part # Dimensions (mm) Weight (grams) Connector / Cable (mm) Mounting 1002289 53.6 x 25.1 x 0.2 (1.6 high at cable solder connection) 0.86 U.FL compatible connector Length: 7.6, Cable diameter: 1.13, Color: Black using 3M468 Adhesive *Additional variations with different cable lengths, colors and connectors are available. Proprietary www.KYOCERA-AVX.com DATASHEET | Part No. 1002289 LTE / Cellular Band KYOCERA AVX Embedded Antenna Specifications. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Test Setup Typical performance with 7.6 mm cable Antenna Location 1 Antenna located at the end of the long edge of the PCB In this position, the antenna is located 3 mm away from the PCB and 3 mm above the PCB Antenna Location 2 Antenna located at the end of the short edge of the PCB. In this position, the antenna is located 2 mm away from the PCB and 3 mm above the PCB © 2021 KYOCERA AVX tel +(1) 858.550.3820 email: eth.info@KYOCERA-AVX.com DATASHEET | Part No. 1002289 LTE / Cellular Band KYOCERA AVX Embedded Antenna Specifications. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. VSWR, Efficiency and Peak Gain Plots Typical performance with 7.6 mm (Location 1 & Location 2) Low Band VSWR High Band VSWR Low Band Efficiency High Band Efficiency Low Band Peak Gain High Band Peak Gain © 2021 KYOCERA AVX tel +(1) 858.550.3820 email: eth.info@KYOCERA-AVX.com DATASHEET | Part No. 1002289 LTE / Cellular Band KYOCERA AVX Embedded Antenna Specifications. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Radiation Patterns Typical performance with 7.6 mm cable Antenna Location 1 Antenna Location 2 © 2021 KYOCERA AVX tel +(1) 858.550.3820 email: eth.info@KYOCERA-AVX.com DATASHEET | Part No. 1002289 LTE / Cellular Band KYOCERA AVX Embedded Antenna Specifications. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Mechanical Dimensions Typical antenna dimensions (mm) Part Number A (mm) B (mm) C (mm) D (mm) E (mm) F (mm) 1002289 53.6 ± 0.3 25.1 ± 0.3 0.2 ± 10% 7.6 ± 3.0 1.6 (max) 25 ± 3.0 *Total Height of 1.6 mm includes the cable solder connection *Height “C” of 0.2 mm includes FPC + adhesive thicknesses AA D D B B FF Top Top View View C Side View Front View E *(Adhesive) Bottom View © 2021 KYOCERA AVX tel +(1) 858.550.3820 email: eth.info@KYOCERA-AVX.com DATASHEET | Part No. 1002289 LTE / Cellular Band KYOCERA AVX Embedded Antenna Specifications. KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs. Ordering Part Numbers Typical antenna dimensions (mm) Part Number A (mm) B (mm) C (mm) D (mm) Cable Length E (mm) F (mm) 1002289 53.6 ± 0.3 25.1 ± 0.3 0.2 ± 10% 7.6 ± 3.0 1.6 (max) 25 ± 3.0 1002289F0-AA10L0025 53.6 ± 0.3 25.1 ± 0.3 0.2 ± 10% 25.0 ± 3.0 1.6 (max) 42.4 ± 3.0 1002289F0-AA10L0050 53.6 ± 0.3 25.1 ± 0.3 0.2 ± 10% 50.0 ± 3.0 1.6 (max) 67.4 ± 3.0 1002289F0-AA10L0065 53.6 ± 0.3 25.1 ± 0.3 0.2 ± 10% 65.0 ± 3.0 1.6 (max) 82.4 ± 3.0 1002289F0-AA10L0075 53.6 ± 0.3 25.1 ± 0.3 0.2 ± 10% 75.0 ± 3.0 1.6 (max) 92.4 ± 3.0 1002289F0-AA10L0080 53.6 ± 0.3 25.1 ± 0.3 0.2 ± 10% 80.0 ± 3.0 1.6 (max) 97.4 ± 3.0 1002289F0-AA10L0100 53.6 ± 0.3 25.1 ± 0.3 0.2 ± 10% 100.0 ± 3.0 1.6 (max) 117.4 ± 3.0 1002289F0-AA10L0110 53.6 ± 0.3 25.1 ± 0.3 0.2 ± 10% 110.0 ± 3.0 1.6 (max) 127.4 ± 3.0 1002289F0-AA10L0120 53.6 ± 0.3 25.1 ± 0.3 0.2 ± 10% 120.0 ± 3.5 1.6 (max) 137.4 ± 3.0 1002289F0-AA10L0150 53.6 ± 0.3 25.1 ± 0.3 0.2 ± 10% 150.0 ± 4.0 1.6 (max) 167.4 ± 3.0 1002289F0-AA10L0160 53.6 ± 0.3 25.1 ± 0.3 0.2 ± 10% 160.0 ± 4.0 1.6 (max) 177.4 ± 3.0 1002289F0-AA10L0200 53.6 ± 0.3 25.1 ± 0.3 0.2 ± 10% 200.0 ± 4.0 1.6 (max) 217.4 ± 3.0 *Total Height of 1.6 mm includes the cable solder connection *Height “C” of 0.2 mm includes FPC + adhesive thicknesses © 2021 KYOCERA AVX tel +(1) 858.550.3820 email: eth.info@KYOCERA-AVX.com
1002289 价格&库存
很抱歉,暂时无法提供与“1002289”相匹配的价格&库存,您可以联系我们找货
