SPECIFICATION
Part No.
PC17.07.0070A
Product Name
Miniature 2.4GHz PCB antenna with cable and
connector
Feature
24*11*0.8mm
High efficiency antenna for Wi-Fi/ Bluetooth/
ZigBee applications
IPEX MHFI Connector (U.FL compatible)
Stable efficiency, gain and radiation patterns
Cable and Connector fully customizable
RoHS Compliant
SPE-11-8-015/F/ZL
Page 1 of 9
1. Introduction
The PC.17 is an ultra-miniature PCB antenna working on 2.4GHz band for Wi-Fi,
Bluetooth and ISM applications. It consists of a robust antenna and mini coaxial
cable. At only 24mm*11mm*0.8mm it has been especially developed to fit
into the smallest spaces and still deliver optimum performance.
Cable and connector are fully customizable.
Many module manufacturers specify peak gain limits for any antennas that are
to be connected to that module. Those peak gain limits are based on free-space
conditions. In practice, the peak gain of an antenna tested in free-space can
degrade by at least 1 or 2dBi when put inside a device. So ideally you should go
for a slightly higher peak gain antenna than mentioned on the module
specification to compensate for this effect, giving you better performance.
Upon testing of any of our antennas with your device and a selection of
appropriate layout, integration technique, or cable, Taoglas can make sure any
of our antennas’ peak gain will be below the peak gain limits. Taoglas can then
issue a specification and/or report for the selected antenna in your device that
will clearly show it complying with the peak gain limits, so you can be assured
you are meeting regulatory requirements for that module.
For example, a module manufacturer may state that the antenna must have
less than 2dBi peak gain, but you don’t need to select an embedded antenna
that has a peak gain of less than 2dBi in free-space. This will give you a less
optimized solution. It is better to go for a slightly higher free-space peak gain
of 3dBi or more if available. Once that antenna gets integrated into your device,
performance will degrade below this 2dBi peak gain due to the effects of GND
SPE-11-8-015/F/ZL
Page 2 of 9
plane, surrounding components, and device housing. If you want to be
absolutely sure, contact Taoglas and we will test. Choosing a Taoglas antenna
with a higher peak gain than what is specified by the module manufacturer and
enlisting our help will ensure you are getting the best performance possible
without exceeding the peak gain limits.
2. Specification
Parameter
Communication System
Bluetooth
2401-2480
Multi-Standard
Wi-Fi
Zigbee
2412-2462
2410-2480
Efficiency (%)
44%
Peak Gain
0.9dBi
Average Gain
-3.6dBi
Return Loss
- 12dB
Impedance
50 Ohms
VSWR
≤1.5:1
Polarization
Linear
Power Handled
2W
2.4GHz ISM
2400-2483.5
MECHANICAL
Dimensions
10.75 X 24 X 0.8 mm
Connector
MHFI (U.FL Compatible)
Cable Standard
Mini-Coax 1.13 mm
ENVIRONMENTAL
Operation Temperature
-40 ºC ~ +85 ºC
Storage Temperature
-40 ºC ~ +85 ºC
RoHS Compliant
Yes
SPE-11-8-015/F/ZL
Page 3 of 9
3. Antenna performance
3.1. Return Loss
3.2. Maximum Gain
SPE-11-8-015/F/ZL
Page 4 of 9
3.3. Average Gain
3.4. Antenna efficiency
SPE-11-8-015/F/ZL
Page 5 of 9
4. Radiation Property
y
z
x
4.1. Radiation Patterns
X-Y Plane
Y
X
SPE-11-8-015/F/ZL
Page 6 of 9
X-Z plane
Z
X
SPE-11-8-015/F/ZL
Page 7 of 9
5. Antenna Drawing
SPE-11-8-015/F/ZL
Page 8 of 9
6. Packaging
SPE-11-8-015/F/ZL
Page 9 of 9
很抱歉,暂时无法提供与“PC17.07.0070A”相匹配的价格&库存,您可以联系我们找货
