SPECIFICATION
Part No.
WPC.25A.07.0150C
Product Name
2.4GHz Ceramic Patch Antenna on integral
ground with cable and connector
Feature
High antenna RF efficiency
150mm 1.13 IPEX MHFI
RoHS compliant
SPE-11-8-130/G/SS
Page 1 of 10
1. Introduction
The WPC.25A 2.4GHz Ceramic Patch Antenna with cable works on Wi-Fi, Zigbee,
Bluetooth and ISM band at 2.4GHz. This antenna comprises of a 2.4GHz
25*25*4mm embedded patch with mini-coax cable and connector for
connectivity and a PCB carrier to mount the antenna. The antenna has its own
ground PCB carrier and is therefore ground independent.
Many module manufacturers specify peak gain limits for any antennas that are
to be connected to that module. Those peak gain limits are based on free-space
conditions. In practice, the peak gain of an antenna tested in free-space can
degrade by at least 1 or 2dBi when put inside a device. So ideally you should go
for a slightly higher peak gain antenna than mentioned on the module
specification to compensate for this effect, giving you better performance.
Upon testing of any of our antennas with your device and a selection of
appropriate layout, integration technique, or cable, Taoglas can make sure any
of our antennas’ peak gain will be below the peak gain limits. Taoglas can then
issue a specification and/or report for the selected antenna in your device that
will clearly show it complying with the peak gain limits, so you can be assured
you are meeting regulatory requirements for that module.
For example, a module manufacturer may state that the antenna must have
less than 2dBi peak gain, but you don’t need to select an embedded antenna
that has a peak gain of less than 2dBi in free-space. This will give you a less
optimized solution. It is better to go for a slightly higher free-space peak gain of
3dBi or more if available. Once that antenna gets integrated into your device,
performance will degrade below this 2dBi peak gain due to the effects of GND
SPE-11-8-130/G/SS
Page 2 of 10
plane, surrounding components, and device housing. If you want to be
absolutely sure, contact Taoglas and we will test. Choosing a Taoglas antenna
with a higher peak gain than what is specified by the module manufacturer and
enlisting our help will ensure you are getting the best performance possible
without exceeding the peak gain limits.
2. Specification
Wi-Fi
Frequency (MHz)
2400~2500
Peak Gain (dBi)
> 0.5
Average Gain (dBi)
>-2.5
Efficiency (%)
> 50
Impedance
50Ω
Polarization
Broadly Linear
Input Power
10 W
MECHANICAL
Dimensions
25*25*5.5mm
Cable type
1.37 mini coaxial cable
Cable length
150mm
Connector
IPEX MHF1
ENVIRONMENTAL
Temperature Range
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
SPE-11-8-130/G/SS
Page 3 of 10
3. Antenna Characteristics
3.1 Return loss
s1
s1
-5
S11(dB )
-10
-15
-20
-25
-30
2000
2100
2200
2300
2400
2500
2600
2700
2800
2900
3000
Freq(M H z)
3.2 Antenna Efficiency
Efficiency (% )
100
Efficiency (% )
90
80
Efficiency(% )
70
60
50
40
30
2410
2420
2430
2440
2450
2460
2470
2480
2490
2500
Freq(M H z)
SPE-11-8-130/G/SS
Page 4 of 10
3.3 Peak Gain
Peak G ain (dB i)
4
Peak G ain (dB i)
3.5
Peak G ain (dB i)
3
2.5
2
1.5
1
0.5
2410
2420
2430
2440
2450
2460
2470
2480
2490
2500
Freq(M H z)
4. Antenna Radiation Pattern
4.1 Antenna Stand Alone
y
z
x
SPE-11-8-130/G/SS
Page 5 of 10
4.2 XZ plane
330
2400M
2420M
2440M
2460M
2480M
2500M
30
300
60
-10
Hz
Hz
Hz
Hz
Hz
Hz
-15
-20
270
-25
90
240
120
210
150
180
4.3 YZ plane
330
30
2400M
2420M
2440M
2460M
2480M
2500M
-5
300
60
-10
-15
Hz
Hz
Hz
Hz
Hz
Hz
-20
-25
270
90
240
120
210
150
180
SPE-11-8-130/G/SS
Page 6 of 10
4.4 XY plane
330
30
2400M
2420M
2440M
2460M
2480M
2500M
-5
300
60
-10
-15
Hz
Hz
Hz
Hz
Hz
Hz
-20
-25
270
90
240
120
210
150
180
SPE-11-8-130/G/SS
Page 7 of 10
5. Mechanical Drawing
SPE-11-8-130/G/SS
Page 8 of 10
WPC25A
ISM 2.4 GHz Antenna
1131
6. Packaging
Each Antenna is packaged in a PE Bag 100mm*150mm
SPE-11-8-130/G/SS
Page 9 of 10
10 Antennas are then packaged in an Outer PE Bag: 250mm*200mm
SPE-11-8-130/G/SS
Page 10 of 10
很抱歉,暂时无法提供与“WPC.25A.07.0150C”相匹配的价格&库存,您可以联系我们找货
