SPECIFICATION
Part No.
MA600.W.A.ABC.001
Product Name
MA600.W Spartan Screw-mount
3in1 Combination Antenna – White Version
GPS/GLONASS/GALILEO 1575~1602MHz
Cellular – GSM/CDMA/HSPA/UMTS
Dual band Wi-Fi 2.4GHz / 5.8GHz
Feature
High performance outdoor antenna
Custom cables and connectors available
White Housing
RoHS Compliant ✓
Mounted Profile
Mounted on White Roof
SPE-12-8-088/D/ZL
Page 1 of 23
MA600.W.A301111.B305111.C305111
1.
Introduction
The Spartan MA600.W antenna is a white, heavy-duty, fully IP67 waterproof
external M2M antenna for use in telematics, transportation and remote
monitoring applications.
The Spartan is unique in the market because it combines a 3in1
GPS/GLONASS/GALILEO, Cellular (2G and 3G) and Wi-Fi, heavy-duty antenna
with high efficiency in a compact format. The antenna screws down permanently
onto a roof or metal panel and can be pole or wall-mounted with a metal bracket.
The white color is ideal for mounting on white truck roofs or cabs or industrial
equipment.
For industries such as commercial vehicle telematics, remote monitoring, smart
meter systems and construction equipment, the Spartan provides a robust,
rugged antenna that is durable, even in extreme environments.
All while still maintaining 20dB isolation between antennas. It uses high-shielded
PTFE dielectric ultra low-loss cables that maintain low attenuation at all
frequency bands, with an average 0.3dB per meter (0.1dB per foot), compared to
0.7dB for RG58 and 1.2dB for RG174. Because of this, the Spartan maximizes
chances of passing PTCRB and network approvals first time. The Spartan also has
excellent GPS/GLONASS/GALILEO reception without need to attach to an
external ground-plane due to coupling to its unique own metal base.
Note: for ground-isolation antennas use the MA605 version with Isolation
Gaskets. Also available in Black.
SPE-12-8-088/D/ZL
Page 2 of 23
2.
Specification
GPS-GLONASS-GALILEO
Centre Frequency
1575.42MHz / 1602MHz
Bandwidth
10MHz
Radiation Efficiency
50(without cable)
Passive Gain @
4.0 typ(with ψ=140mm ground)
Zenith
VSWR
2
Impedance
50Ω
DC Power Input
3 ~ 5V
Range
DC input
MHz
3.3V
4.0V
5.5V
1575.42
1602
1575.42
1602
1575.42
1602
2
2
2
2
2
2
29.2
29
31
31
32.3
32
Noise Figure
3.1
3.1
3.2
3.2
3.4
3.4
Power Consumption
7.5
7.5
9.4
9.4
15
15
VSWR
LNA Gain
Band Attenuation
1520MHz: -20dB
1520MHz: -20dB
1520MHz: -20dB
1642MHz: -20dB
1642MHz: -20dB
1642MHz: -20dB
Cable
3m RG-174 standard, fully customizable
Connector
SMA(M) standard, fully customizable
CELLULAR
Frequency (GHz)
824~896
880~960
1710~1880
1850~1990
1710~2170
Peak Gain (dBi)
2.1
-0.2
2.9
3.0
5.1
Average (dBi)
-4.7
-7.5
-2.7
-3.1
-3.1
Efficiency
35%
20%
51%
49%
49%
Impedance
50Ω
Polarization
Linear
Radiation Pattern
Omnidirectional
Cable
3m CFD200 standard, fully customizable
Connector
SPE-12-8-088/D/ZL
Page 3 of 23
Wi-Fi
Frequency (GHz)
2.4~2.5
4.7~5.0
5.0~5.4
5.4~5.9
Peak Gain (dBi)
2.1
2.9
3.8
2.8
Average Gain (dBi)
-2.3
-3.6
-3.3
-3.8
Efficiency
60%
44%
46%
42%
VSWR
很抱歉,暂时无法提供与“MA600.W.A.ABC.001”相匹配的价格&库存,您可以联系我们找货
