DATASHEET
Part No. 1002427
Product: GPS/ISM
SMT stamping Antenna
Part No. 1002427
Embedded GPS ISM Stamped metal SMT Antennas
915GHz, 1.5GHz
Ethertronics’ 1002427 stamped metal SMT antenna delivers the device
designers’ key needs for higher functionality and performance in smaller /
thinner designs. This innovative antenna provides compelling advantages
for all GPS or ISM enabled handheld devices, media players and other
mobile devices.
Unique Form Factors Support Advanced Industrial Designs
Smaller, more efficient on board embedded antennas break through
restrictive design rules and provide new freedom in component placement.
Stamped Metal Antenna
ISM/GPS
Greater Flexibility
Ethertronics’ first-in-class IMD technology enables you to develop concept
designs that are more advanced and that deliver superior performance in
reception critical applications.
868MHz, 915MHz, 1.5 GHz
KEY BENEFITS
Versatile Antenna
Ethertronics 1002427 can be used
to support GPS and ISM bands,
allowing reduced BOM complexity
while maintaining great
performances.
Quicker Time-to-Market
By optimizing antenna size,
performance and emissions,
customer and regulatory
specifications are more easily met.
Reliability
Fully compliant with the European
RoHS Directive 2011/65/EU.
Electrical Specifications
Typical Characteristics, in free space using 50x100mm PCB, different
layout used for each frequency
Frequency
GPS
1560—1606 MHz
ISM
868 MHz
ISM
915 MHz
Peak Gain
3.0 dBi
1.0 dBi
1.0 dBi
75%
63.4%
60%
Average Efficiency
VSWR Match
Feed Point Impedance
Polarization
Power Handling
2.0:1.0 max
50 ohms unbalanced
Linear
2 Watt CW
Mechanical Specifications
APPLICATIONS
Embedded design
Cellular, Headsets, Tablets
Gateway, Access Point
M2M, Industrial devices
Handheld
Size
Mounting
Weight
Packaging
9/29/2016
Proprietary and confidential.
31.20x3.20x1.80 mm
Surface mount
0.1 g
Tape & Reel,
5,400 pieces per box, 1,800 per reel
www.ethertronics.com
DATASHEET | Part No. 1002427
1002427 GPS ISM layout performances
Ethertronics produces a wide variety of standard and custom antennas to meet user needs.
Below are the typical performances.
Typical VSWR and Efficiency Plots
Measured on 50x100mm PCB demo board
ISM VSWR
GPS VSWR
ISM Efficiency
GPS Efficiency
Typical antenna dimensions
For reference only
All dimensions provided in this document are for informational purposes only.
© 2016 Ethertronics Incorporated.
tel +(1) 858.550.3820 | fax +(1) 858.550.3821
email: info@ethertronics.com
5501 Oberlin Drive, Suite 100 San Diego, CA 92121 - USA
1002427 GPS layout performances
GPS Antenna Radiation Patterns
Typical Performances on Ethertronics’ 50x100mm PCB Test Board
GPS Antenna board layout
*All dimensions provided in this document are for informational purposes only.
1002427 ISM layout performances
ISM Antenna Radiation Patterns
ISM Antenna board layout
很抱歉,暂时无法提供与“1002427”相匹配的价格&库存,您可以联系我们找货
