SRFWG018-100
SRFWG018-100
    ANTENOVA(安诺亚)
    WLAN/GNSS: ASPER ANT-100MM CABLE
SRFWG018-100 数据手册
Asper Part No: SRFWG018 Asper 2.4G / GNSS Antenna Part No. SRFWG018 1. flexiiANT ® Product Specification Features         2. Dual Antenna for 1559 – 1609 MHz and 2.4 – 2.5 GHz applications ® Wi-Fi, Bluetooth, GNSS. Maintains high performance with good isolation within device: DFI (Designed For Integration) 1.13mm diameter RF cable with IPEX MHF connector Self-Adhesive mounted Quick integration minimizes design cycle High performance Available in 3 standard cable lengths Description Asper is a dual antenna that combines two separate antenna systems within a single flexible form factor. Intended for use with Wi-Fi, Bluetooth with positioning applications. Simple integration with plug and play simplicity. This product specification shows the performance of the antenna to cover a typical BT / Wi-Fi and GNSS bands: 2.4-2.5GHz / 1559-1609MHz. 3. Applications        Sport cameras Trackers Dash cams Portable Devices Network Devices Wearable devices MIMO Systems Antennas for Wireless M2M Applications Product Specification Page 1 Asper Part No: SRFWG018 4. Part Number Asper: SRFWG018-xxx Note. -xxx refers to cable length option: 5. Part Number Cable Length SRFWG018-100 100mm SRFWG018-150 150mm SRFWG018-200 200mm General Data Product name Asper Part Number SRFWG018 Frequency 1559 – 1609 MHZ; 2.4-2.5GHz Polarization Linear Operating temperature -40°C to +85°C Impedance with matching 50 Ω Weight < 0.5 g Antenna Assembly type FPC Self-adhesive 3M 468MP Dimensions (Antenna) 81.0 x 14.0 x 0.15 (mm) Cable length 100 /150 / 200 Connection MHF IPEX 6. RF Characteristics 1559 – 1609 MHz 2.4 – 2.5 GHz Peak gain 4.25dBi 5.6dBi Average gain -1.1dBi -0.6dBi Average efficiency >75% >85% -18.4dB -14.5dB 1.3:1 1.4:1 Maximum return loss Maximum VSWR Conditions All data measured in a loaded condition adhered to a plastic carrier free space. Antennas for Wireless M2M Applications Product Specification Page 2 Asper Part No: SRFWG018 7. RF Performance 1559-1609MHz 7.1 Return Loss 5 [dB] Atyune 0 -5 -10 -15 3 -20 1 2 -25 4 -30 -35 1450 [MHz] 1500 MARKERS: MHz RD8018-GNSS.S1P - S11 1: 1573.42 2: 1577.42 1550 1600 dB MHz -21.61 -23.41 1650 1700 dB 3: 1563 4: 1587 -18.47 -26.08 7.2 VSWR 10 [] Atyune 9 8 7 6 5 4 3 2 3 1 1450 1500 1550 MARKERS: MHz RD8018-GNSS.S1P - S11 1: 1573.42 2: 1577.42 1 2 4 [MHz] 1600 1650 1700 MHz 1.18 1.14 3: 1563 4: 1587 1.27 1.10 Antennas for Wireless M2M Applications Product Specification Page 3 Asper Part No: SRFWG018 7.3 Antenna patterns GNSS 7.3.1 1559 MHz – 1609 MHz 3D pattern at 1575 MHz Drag to rotate pattern and PCB by using Adobe Reader (Click to Activate) Antennas for Wireless M2M Applications Product Specification Page 4 Asper Part No: SRFWG018 7. RF Performance 2.4-2.5GHz 7.1 Return Loss 5 [dB] Atyune 0 -5 -10 1 2 -15 -20 -25 -30 -35 2300 [MHz] 2350 MARKERS: MHz RD8018-Wifi.s1p - S11 1: 2400 2: 2500 2400 2450 2500 2550 2600 dB -14.51 -14.72 7.2 VSWR 10 [] Atyune 9 8 7 6 5 4 3 2 1 1 2300 2 [MHz] 2350 2400 2450 2500 2550 2600 MARKERS: MHz RD8018-Wifi.s1p - S11 1: 2400 2: 2500 1.46 1.45 Antennas for Wireless M2M Applications Product Specification Page 5 Asper Part No: SRFWG018 7.3 Antenna patterns 7.3.1 2400 MHz – 2500 MHz 3D pattern at 2.45GHz Drag to rotate pattern and PCB by using Adobe Reader (Click to Activate) Antennas for Wireless M2M Applications Product Specification Page 6 Asper Part No: SRFWG018 7.4 Isolation The antennas isolation to each other is shown here tested free space. The isolation is
SRFWG018-100 价格&库存
很抱歉,暂时无法提供与“SRFWG018-100”相匹配的价格&库存,您可以联系我们找货
