DATASHEET
Part No. M620720
Product: 868/915MHz
Ceramic Antennas
Part No. M620720
ISM SavviTM Ceramic Antennas
868MHz / 915MHz
Ethertronics’ Savvi series of Isolated Magnetic Dipole™ (IMD) antennas
deliver on the key needs of device designers for higher functionality and
performance in smaller/thinner designs. These innovative antennas provide
compelling advantages for ISM enabled handheld devices, media players
and other mobile devices.
Real-World Performance and Implementation
Ceramic antennas may look alike on the outside, but the important
difference is inside. Other antennas may contain simple PiFA or monopole
designs that interact with their surroundings, complicating layout
or changing performance with use position. Ethertronics’ antennas utilize
patented IMD technology to deliver a unique size and performance
combination.
ISM / M2M / IoT
868 / 915 MHz
Greater Flexibility
Ethertronics’ first-in-class IMD technology enables you to develop concept
designs that are more advanced and that deliver superior performance in
reception critical applications.
KEY BENEFITS
Electrical Specifications
Typical Characteristics, on 40x100mm PCB,
frequency of operation depends on tuning
Stay-in-Tune
IMD antenna technology
provides superior RF field
containment, resulting in less
interaction with surrounding
components.
Quicker Time-to-Market
By optimizing antenna size,
performance and emissions,
customer and regulatory
specifications are more easily
met.
Reliability
Fully compliant with the
European RoHS Directive
2011/65/EU.
868-870 MHz
Peak Gain
2.56 dBi
Average Efficiency
58%
VSWR Match
2.6:1 max
Feed Point Impedance
50 ohms unbalanced
Polarization
Linear
Power Handling
0.5 Watt CW
Mechanical Specifications
Size
6.00x2.00x1.1mm
Mounting
APPLICATIONS
Embedded design
Cellular, Headsets, Tablets
Gateway, Access Point
M2M, Industrial devices
Handheld
10/20/2016
902—928 MHz
Surface mount
Weight
Packaging
0.1 g
Tape & Reel,
M620720 – 1,000 pieces per reel
M620720-10K – 10,000 pieces per reel
Demo Board
Proprietary and confidential.
M620720-01
www.ethertronics.com
DATASHEET | Part No. M620720
868/915MHz Ethertronics’ SavviTM Embedded Antenna Specifications
Ethertronics produces a wide variety of standard and custom antennas to meet user needs.
Below are the typical performances.
Typical Return Loss and Efficiency Plots
Measured on 40x100mm demo board, tuned at 915MHz
Antenna Radiation Patterns
Typical Performances on Ethertronics’ 40x100mm PCB Test Board
Measured at 915 MHz
Antenna Layout
Tuning values for references only
M620720
Default matching circuit components :
Major tuning
Minor tuning
868-870 MHz
902—928 MHz
6.8 pF
4.7 pF
82 pF
*All dimensions provided in this document are for informational purposes only.
© 2016 Ethertronics Incorporated.
tel +(1) 858.550.3820 | fax +(1) 858.550.3821
email: info@ethertronics.com
5501 Oberlin Drive, Suite 100 San Diego, CA 92121 - USA
很抱歉,暂时无法提供与“M620720”相匹配的价格&库存,您可以联系我们找货
