DATASHEET
Part No. P822601/P822602
Product: Embedded FR4
Broadband LTE/5G/LPWA
antenna
Part No. P822601 / P822602
Universal Broadband FR4 Embedded LTE / LPWA Antenna
698 – 960 MHz / 1710 – 2200 MHz / 2300 – 2400 MHz / 2500 – 2700 MHz / 3300– 3800 MHz
Supports: Broadband LTE (OCTA-BAND), LTE CAT-M, NB-IoT, SigFox, LoRa, Cellular LPWA, RPMA, CBRS
KYOCERA AVX's Universal Broadband Embedded LTE/LPWA antenna
utilizes Isolated Magnetic Dipole™ (IMD) technology which address the
challenges facing today’s product designers. IMD’s high performance and
isolation characteristics offer better connectivity and minimal interference.
Mirrored version variant offered as P822602.
Stays in Tune
KYOCERA AVX antennas use patented IMD technology in many antenna
configurations to provide high performance. IMD antennas requires a smaller
design keep-out area, carry lower program development risk which
yields a quicker time-to-market, without sacrificing RF performance.
*Mirrored version offered as P822602
Electrical Specifications
Typical P822601/P822602 performance 140 x 50 mm PCB
LTE/LPWA Antenna
698 - 960 MHz
1700 - 2700 MHz
3300 - 3800 MHz
KEY BENEFITS
Reduced Costs and
Time-to-Market
8/25/2022
3300-3800
(n78)
Peak Gain
2.6 dBi
4.4 dBi
3.4 dBi
1.8 dBi
2.8 dBi
Average
Efficiency
68%
76%
52%
46%
59%
< 3.0:1
< 2.5:1
< 2.5:1
Linear
2 Watt CW
50 Ω unbalanced
Mechanical Specifications & Ordering Part Number
Ordering Part #
Dimensions (mm)
Mounting Type
Variant
APPLICATIONS
2300-2400
(Band 40)
Feed Point
Impedance
Comply with latest RoHS requirements
2500-2700
(B7)
Power
Handling
Reliability
Medical
applications
Home
automation
Smart
metering
M2M,
Industrial
devices
IoT
Firstnet
1710-2200
Polarization
KYOCERA AVX’s technology
helps you deliver more advanced
ergonomic designs without
adverse impact on product
performance.
698-960
VSWR Match
Standard antenna eliminates
design fees and cycle time
associated with a custom solution;
getting products to market faster.
Greater Flexibility with
Unique Form Factors
Frequency
(MHz)
Weight (grams)
Healthcare
Point of Sale
Tracking
NB-IoT
Sigfox
LoRa
Cellular
LPWA
RPMA
LTE CAT-M
P822601
P822602
49.6 x 8.0 x 3.2
49.6 x 8.0 x 3.2
SMT (P&P)
P822602 : Mirrored version of P822601
2.63
Packaging
Tape and Reel
Storage Temperature/
Humidity
+5°C to +35°C
45~75%
(Sealed shipping package)
Operating Temperature
TDS-ANT-0053 | Rev. 1
Demo Board
Proprietary
-40 to +85 C
P822601-01 (P822601)
P822602-01 (P822602)
www.KYOCERA-AVX.com
DATASHEET | Part No. P822601 / P822602
P822601 / P822602 Universal Broadband Embedded LTE/LPWA Antenna Specifications.
KYOCERA AVX produces a wide variety of standard and custom antennas to meet user needs.
LTE Bands covered by (P822601/P822602)
LTE Band Frequency Band (MHz) Uplink (UL) (MHz) Downlink (DL) (MHz) Region
1
2100
1920 - 1980
2110 - 2170
Global
2
1900
1850 - 1910
1930 - 1990
NAM
3
1800
1710 - 1785
1805 - 1880
Global
4
1700
1710 - 1755
2110 - 2155
NAM
5
850
824 - 849
869 - 894
NAM
6
850
830 - 840
875 - 885
APAC
7
2600
2500 - 2570
2620 - 2690
EMEA
8
900
880 - 915
925 - 960
Global
9
1800
1749.9 - 1784.9
1844.9 - 1879.9
APAC
10
1700
1710 - 1770
2110 - 2170
NAM
11
1500
1427.9 - 1447.9
1475.9 - 1495.9
Japan
12
700
699 - 716
729 - 746
NAM
13
700
777 - 787
746 - 756
NAM
14
700
788 - 798
758 - 768
NAM
17
700
704 - 716
734 - 746
NAM
18
850
815 - 830
860 - 875
Japan
19
850
830 - 845
875 - 890
Japan
832 - 862
791 - 821
EMEA
21
1500
1447.9 - 1462.9
1495.9 - 1510.9
Japan
22
3500
3410 - 3490
3510 - 3590
EMEA
23
2000
2000 - 2020
2180 - 2200
NAM
24
1600
1626.5 - 1660.5
1525 - 1559
NAM
25
1900
1850 - 1915
1930 - 1995
NAM
26
850
814 - 849
859 - 894
NAM
27
850
807 - 824
852 - 869
NAM
28
700
703 - 748
758 - 803
APAC,EU
29
700
N/A
717 - 728
NAM
30
2300
2305 - 23151
2350 - 2360
NAM
31
450
452.5 - 457.5
462.5 - 467.5
Global
32
1500
N/A
1452 - 1496
EMEA
33
1900
1900 - 1920
34
2000
2010 - 2025
35
1850
1850 - 1910
36
1900
1930 - 1990
37
1900
1910 - 1930
38
2600
2570 - 2620
39
1900
1880 - 1920
40
2300
2300 - 2400
41
2500
2496 - 2690
42
3500
3400 - 3600
43
3700
3600 - 3800
© 2022 KYOCERA AVX
Covered
Yes
No
Yes
No
Yes
No
Yes
No
Yes
tel +(1) 858.550.3820
email: antenna.info@kyocera-avx.com
1 Avx Blvd, Fountain Inn, SC 29644
Antenna Dimensions (P822601)
Typical antenna dimensions (mm)
Part Number
A
B
C
P822601
49.6 ± 0.2
8.0 ± 0.2
3.2 ± 0.32
A
B
Top View
Pin#
Description
C
1
Feed
2
Ground
3
Dummy Pad
4
Low Band Tuning
5
High Band Tuning
6
Dummy Pad
7
Dummy Pad
Front View/Height
Pin #7
Pin #6 Pin #1
Pin #4
Pin #2
Pin #5
Pin #3
Bottom View
© 2022 KYOCERA AVX
Antenna Dimensions (P822602)
Part Number
A
B
C
P822602
49.6 ± 0.2
8.0 ± 0.2
3.2 ± 0.32
A
B
Top View
Pin#
Description
1
Feed
2
Ground
3
Dummy Pad
4
Low Band Tuning
5
High Band Tuning
6
Dummy Pad
7
Dummy Pad
C
Front View/Height
Pin #1
Pin #4
Pin #7
Pin #6
Pin #3
Pin #2
Pin #5
Bottom View
© 2022 KYOCERA AVX
VSWR and Efficiency Plots
Low Band VSWR
Low Band Efficiency
High Band VSWR
High Band Efficiency
Band 7 VSWR
© 2022 KYOCERA AVX
Band 7 Efficiency
Band 40 VSWR
Band 40 Efficiency
n78 VSWR
n78 Efficiency
© 2022 KYOCERA AVX
Antenna Radiation Patterns – Low / High Band (LTE)
X
Y
High Band measured at
1800, 1900, 2100 MHz
Low Band measured at
700, 750, 850, 900 MHz
Z
© 2022 KYOCERA AVX
Antenna Radiation Patterns – Band 40, Band 7
X
Y
Band 7 measured at
2600 MHz
Band 40 measured at
2350 MHz
Z
© 2022 KYOCERA AVX
Antenna Radiation Patterns – n78
X
Y
n78 measured at
3500 MHz
Z
© 2022 KYOCERA AVX
Antenna Layout (P822601)
Typical layout dimensions (mm)
Pin #5
Pin #6
Pin #7
Pin #2
Pin #1
Pin #4 Pin #3
Antenna
Outline
Via
Pi Matching Via
Network
Additional VIAS: Diam. 0.2mm to be placed around antenna,
(no vias on transmission lines).
Via holes must be covered by solder mask
50Ω
Transmission
line
Pin Descriptions
Pin# Description
1
Feed
2
Ground
3
Dummy Pad
4
Low Band Tuning
5
High Band Tuning
6
Dummy Pad
7
Dummy Pad
1710 – 3800 MHz
Tuning
*P822602 uses the same layout but mirrored.
698 -960 MHz
Tuning
Default Pi Matching Network values with instructions can be
found under Antenna Matching Network.
© 2022 KYOCERA AVX
Antenna Layout (P822602)
Pin #5
Pin #6
Pin #2
Pin #3 Pin #4
Pin #1
Pin #7
Antenna
Outline
Via
Via
Additional VIAS : Diam. 0.2mm to be placed around antenna,
Pin Descriptions
50Ω
Transmission
line
Pi Matching
Network
Pin# Description
1
Feed
2
Ground
3
Dummy Pad
4
Low Band Tuning
5
High Band Tuning
6
Dummy Pad
7
Dummy Pad
698 -960 MHz
Tuning
1710 – 3800 MHz
Tuning
*P822601 uses the same layout but mirrored.
found under Antenna Matching Structure.
© 2022 KYOCERA AVX
Antenna Matching Structure (P822601)
Typical matching values on 140 x 50 mm PCB
Pin #3
Demo Board Front View
Pin #5
Pin #1
Demo Board Back View
Pin #2
Pin #6
Pin #7
Pin #4
Antenna Matching
[ P2 ]
[ R9 ]
[ R7 ]
[ R1 ]
[ P4 ]
Via
[ S2 ]
[ P3 ]
[ R5 ]
Via
1710-3800 MHz Tuning
[ R8 ]
[ R6 ]
[ S1 ]
[ P1 ]
698-960 MHz Tuning
[ R2 ]
[ R4 ]
[ R3 ]
(Antenna Matching):
pads are directly inline with
the antenna feed trace.
(1710 – 3800 MHz Tuning)
Pin Descriptions
R1
Pin# Description
1
Feed
2
Ground
3
Dummy Pad
4
Low Band Tuning
5
High Band Tuning
6
Dummy Pad
7
Dummy Pad
1
2
3
4
5
R3
R2
6
R4
7
(698 – 960 MHz Tuning)
S1
(Antenna Matching)
P1
R7
R6
R5
R8
S2
P2
P3
P4
R9
50ohm
*P822602 uses same matching values
Default Matching
Tolerance
© 2022 KYOCERA AVX
P1
24nH
± 20%
S1
2.4pF
± 0.25pF
P2
DNI
N/A
P3
DNI
N/A
S2
1.0nH
± 0.3nH
P4
0.3pF
± 0.1pF
R1-R4
DNI
N/A
R5-R9
DNI
N/A
Demo Board Back
698-960 MHz Tuning
*P822602 uses same tuning method but on mirrored layout
Ex. Tuning Layout
(1) Shift Frequency Lower (Adding Components)
*Bridging gaps with 0 ohm resistors shifts resonant
frequency lower
[ R8 ]
[ R2 ]
[ R7 ]
[ R9 ]
[ R4 ]
[ R3 ]
[ R5 ]
[ R1 ]
[ R6 ]
(2) Shift Frequency Higher (Cut Bridge Traces)
*Cut Trace between pads shifts resonant frequency
higher
© 2022 KYOCERA AVX
Antenna Demo Board (P822601-01)
Demo Board Front/Back View
140.0 mm
50.0 mm
© 2022 KYOCERA AVX
Antenna Demo Board (P822602-01)
140.0 mm
50.0 mm
© 2022 KYOCERA AVX
Recommended Reflow Soldering Profile
The recommended method for soldering the antenna to the board is forced convection reflow soldering. The following
suggestions provide information on how to optimize the reflow process for the FR4 antenna:
*Adjust the reflow duration to create good solder joints without raising the antenna temperature
beyond the allowed maximum of 260° C.
© 2022 KYOCERA AVX
