33-3400-01-01
    TALLYSMANWIRELESS
    ANTENNA GPS/GLONASS TNC FEMALE
33-3400-01-01 数据手册
A Tallysman Accutenna® TW3400/TW3402 GPS/GLONASS Antenna The TW3400/TW3402 employs Tallysman’s unique Accutenna technology covering the GPS L1, GLONASS L1 and SBAS (WAAS, EGNOS & MSAS) frequency band (1574 to 1606 MHz). They are especially designed for precision industrial, agricultural and military applications. . They provide truly circular response over the antennas’ entire bandwidth thereby producing superior multipath signal rejection. The TW3400/TW3402 feature a highly circular dualfeed wideband patch element, with a two stage Low Noise Amplifier, comprised of one input LNA per feed, a mid section SAW to filter the combined output, and a final output gain stage. This configuration provides excellent axial ratio that is constant across the full frequency band. An optional tight pre-filter is available on the TW3402 to protect against saturation by high level sub-harmonic and L-Band signals. TW3400 Dimensions (mm) Flat radome is shown, Conical Radome also available The TW3400/TW3402 is housed in a permanent mount industrial grade weather-proof enclosure. Two options for pole mounting are available an L-bracket (P/N#23-0040-0) or a pipe mount (P/N#23-0065-0). Applications • • • • • • High Accuracy & Mission Critical Global Positioning Precision Agriculture, Mining & Construction Military & Security Avionics Law Enforcement & Public Safety Fleet Management & Asset Tracking Features • • • • • • • Great axial ratio: 1 dB typ. Low noise LNA: 1 dB High rejection SAW filter High gain LNA: 26 dB typ. Low current: 13 mA typ. Wide voltage input range: 2.5 to 16 VDC IP67 weather proof housing Benefits • • • • • • • Excellent circular polarisation Excellent multipath rejection Excellent signal to noise ratio Great out of band signal rejection Increased system accuracy Ideal for harsh environments RoHS and REACH compliant TW3400/TW3402 GPS/GLONASS Antenna Specifications Antenna Architecture 1 dB Bandwidth Antenna Gain (with 100mm ground plane) Axial Ratio (over full bandwidth) Dual, Quadrature Feeds 30 MHz 4.25 dBic 50dB (TW3402) >25 dB >50dB >35 dB >75dB
33-3400-01-01 价格&库存
很抱歉,暂时无法提供与“33-3400-01-01”相匹配的价格&库存,您可以联系我们找货
