Telescopic Antenna SMA - 75 MHz to 1 GHz
(ANT500)
W R L- 130 02
Description: This ANT500 is a telescopic antenna designed for operation from 75
MHz to 1 GHz with a total length that is configurable from 20 cm to 88 cm long. Each
ANT500 is constructed of stainless steel and features an SMA male connector,
rotating shaft, and adjustable elbow.
The ANT500 is a 50 ohm antenna designed to match HackRF One. It is the perfect
first antenna for general purpose use with HackRF One but we won’t stop you from
using it with different projects!
https://www.sparkfun.com/products/13002
8/3/2016
很抱歉,暂时无法提供与“WRL-13002”相匹配的价格&库存,您可以联系我们找货
