A Tallysman Accutenna®
TW3440/TW3442 GPS/GLONASS 40dB Timing Antenna
The
TW3440/TW3442 employs Tallysman’s unique Accutenna
technology, covering the GPS L1, GLONASS L1, and SBAS (WAAS,
EGNOS & MSAS) frequency bands (1574 to 1606 MHz). They are
especially designed for timing, mobile, precision and military
applications. They provide truly circular response over the antenna’s
entire bandwidth thereby producing superior multipath signal
rejection.
The TW3440/TW3442 each feature a highly circular dual-feed
wideband patch element, with a three stage
Low Noise Amplifier.
This configuration
provides excellent axial ratio that is constant
across the full frequency band. An optional
tight pre-filter is available with part number
TW3442 to protect against saturation by high
level sub-harmonics and L-Band signals.
The TW3440/TW3442 is housed in a
permanent mount industrial-grade weatherproof enclosure, and is available with a wide
variety of connectors. The antenna is available with either
a flat or a conical radome.
Conical radomes are
recommended for permanent locations to ward off birds
and shed ice / snow.
Shown with low profile radome,
conical radome also available
Applications
GPS / GLONASS Long cable Mobile/fixed Installations
High Accuracy & Mission Critical Global Positioning
Precision Agriculture, Mining & Construction
Military & Security
Law Enforcement & Public Safety
Features
Benefits
Great axial ratio: 1 dB typ.
High gain LNA: 40 dB min.
Low noise LNA: 1dB/3.5dB typ TW3440/TW3442
Available sharp pre-filter (TW3442)
Low current: 19 mA typ.
Wide supply voltage: 2.5 to 16 VDC
IP67 weather proof housing
Available conical radome (Timing Apps)
Excellent circular polarisation
Long Cable Runs
Excellent signal to noise ratio
Excellent multipath rejection
Exceptional out-of-band rejection (TW3442)
Increased system accuracy
Ideal for harsh environments
RoHS and REACH compliant
Specifications Vcc = 3V, over full bandwidth, T=25°C
Antenna
Architecture
1 dB Bandwidth
Antenna Gain (with 100mm ground plane)
Axial Ratio (over full bandwidth)
Dual, Quadrature Feeds
32 MHz
4.25 dBic
1 dB typ., 3 dB max.
Electrical
Architecture
TW3440: One LNA per feed ->Combiner ->SAW -> 2-Stage LNA
TW3442: (SAW-> LNA) per feed ->Combiner -> SAW -> 2 Stage LNA,
Filtered LNA Frequency Bandwidth
Polarization
LNA Gain1575.42 to 1606 MHz
Gain flatness
Group Delay (TW3442 w/o cable)
Out-of-Band Rejection
32 dB (TW3440)
>50dB (TW3442)
>25 dB
>50dB
>35 dB
>70dB
很抱歉,暂时无法提供与“33-3440-01-01”相匹配的价格&库存,您可以联系我们找货
