SPECIFICATION
Part No.
TI.10.0111.HT
Product Name
433MHz ISM Band Terminal Antenna
Omni-directional 0dBi
HIGH TEMPERATURE
Features
SMA(M) Plug Connector
Dupont® Hytrel® High Temperature Resistant TPEE
Housing (up to 150°C)
Low Profile and Robust Handling
48.2mm Antenna Dimensions
IP65
RoHS Compliant
SPE-13-8-063/C/PK
Page 1 of 5
1.
Introduction
The TI.10 HT series are robust miniature 433MHz omni-directional antennas
suitable for high temperature applications. The TI.10 terminal SMA plug mount
antenna is ideal for mobile small form factor applications. At only 48.2mm in
length an omni-directional pattern with a peak gain 0dBi ensures constant
reception and transmission. The antenna housing is made of Dupont® Hytrel®
TPEE material which is durable in high temperature application environments up
to 150°C. This material is proven in the automotive industry applications, thus
allowing the antenna to be placed nearer the engine or heat generating
components.
2.
Key Antenna Performance Indicators
Parameter
Specification
Applications
433MHz ISM Band
Frequency
433.05~434.79MHz
Peak Gain
0dBi
Return Loss
-17dB
Impedance
50 Ohms
Radiation Pattern
Omni-directional
Polarization
Linear
VSWR
Power handling
5W
Housing
Dupont® Hytrel® TPEE
Connector
SMA(M) plug
Operation Temperature
-40°C to + 150°C
Storage Temperature
-40°C to + 105°C
Relative Humidity
40% to 95%
Dimensions
Length: 48.2mm
Weight
8.5g
SPE-13-8-063/C/PK
Page 2 of 5
3. Antenna Parameters
3.1 VSWR Data
SPE-13-8-063/C/PK
Page 3 of 5
3.2 Return Loss Data
SPE-13-8-063/C/PK
Page 4 of 5
4.
Mechanical Drawing
SPE-13-8-063/C/PK
Page 5 of 5
很抱歉,暂时无法提供与“TI.10.0111.HT”相匹配的价格&库存,您可以联系我们找货
