SPECIFICATION
Part No.
PC30.09.0100A
Product Name
FR4 Penta-band GSM Antenna
100mm 1.13 coax MMCX(M)RA
Feature
High antenna RF efficiency
RoHS compliant
SPE-12-8-058/A/ZL
Page 1 of 7
I. Introduction
PC30 is a custom-designed FR4 quad-band GSM antenna for a tracking device.
This RoHS compliant antenna has high RF efficiency with the tracking device to
meet PTCRB requirement.
II.
Specification (Free Space)
Specifications
Penta-band Cellular
Communication System
AMPS
GSM
DCS
PCS
UMTS
Frequency (MHz)
824 ~ 896
880~960
1710~1880
1850~1990
1710~2170
Average Efficiency
17%
38%
60%
70%
68%
Gain
2dBi
Impedance
50 Ohm
Radiation Pattern
Omni-directional
Polarization
Linear
PCB
FR4 74.70 x 8.20 x 0.8 mm
Connector
MMCX(M)RA
Cable
1.13
Cable Length
100 mm
Operation Temperature
-40°C ~ +85°C
Storage Temperature
-40°C ~ +85°C
Please note that Cables and Connectors are Customizable, customized solution will have an MOQ
SPE-12-8-058/A/ZL
Page 2 of 7
III. Electrical Property
III.1 Test Setup
Satimo SG64 3D-chamber is used for radiation and efficiency test. For the free
space test, a Styrofoam is used to fix the antenna in the testing set.
z
y
x
Antenna setup and Satimo SG64 3D-chamber.
SPE-12-8-058/A/ZL
Page 3 of 7
III.2 Radiation Pattern
The radiation pattern of PC.30 in free space as the above test setup is --
Radiation pattern of x-y plane
Radiation pattern of x-z plane
SPE-12-8-058/A/ZL
Page 4 of 7
III.3 Efficiency
80.00%
70.00%
60.00%
50.00%
40.00%
30.00%
20.00%
10.00%
0.00%
600
1000
1400
1800
2200
Frequency (MHz)
SPE-12-8-058/A/ZL
Page 5 of 7
III.4 Return Loss
A piece of Styrofoam is use to hold PC.30 at least 30cm away from any metal
surrounding objects. Agilent E5071B Network Analyzer is used for the return
Return Loss (dB)
loss measurement.
0.0
-1.0
-2.0
-3.0
-4.0
-5.0
-6.0
-7.0
-8.0
-9.0
-10.0
-11.0
-12.0
-13.0
-14.0
-15.0
-16.0
-17.0
-18.0
-19.0
-20.0
-21.0
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
2.0
2.2
2.4
2.6
2.8
3.0
Frequency (GHz)
SPE-12-8-058/A/ZL
Page 6 of 7
IV. Drawing
SPE-12-8-058/A/ZL
Page 7 of 7
很抱歉,暂时无法提供与“PC30.09.0100A”相匹配的价格&库存,您可以联系我们找货
