Specification
Model No.
FXP100
Part No.
FXP100.07.0100A
Product Name
Flexible WiMAX antenna
Features
High Efficiency Wide-Band Antenna
31*53*0.2mm
International Patent#: US 2009/0189825 A1
RoHS
REVISION STATUS
Version
Date
Page
Revision Description
01
20 November 2008
All
New release
Prepared
Approved
Matthias John,
AHFR
© All Rights Reserved - International Patent Pending
Taoglas Limited, Unit 3 Enniscorthy Technology Centre, Enniscorthy, Co. Wexford, Ireland
www.taoglas.com
1.
Introduction
This flexible wideband WiMAX antenna has been designed by DIT Antenna High Frequency and
Research Centre in Dublin, Ireland. Taoglas and DIT have developed this range of solutions following
years of expertise and collaboration in design of high performance antennas.
1.1 Key Advantages
1. Highest efficiency in small size 31*53*0.2mm.
2. Flexible – can be fitted to curved surfaces
3. Highly reliable and robust
4. Rectangular shape - Easy to integrate. Other antenna designs come in irregular shapes and sizes
making them hard to integrate.
2.0 Electrical Characteristics
No
Parameter
Specification
1
Working Frequency
21004320MHz
2
Dimensions
31*53*0.2mm
3
VSWR
2 max (depends on the special environment)
4
Polarization
Linear
5
Impedance
50
6
Operating Temperature
-40°C+105°C
7
Termination
Cu (Environmentally Friendly Pb Free)
* Actual Electrical value will depend on customer ground plane size
www.taoglas.com
3.0 Key Antenna Performance Indicators
Measured in chamber
Gain (Ground Length: 33mm, Coax Cable Length: 150mm, UF-L Connector)
WiMAX Antenna peak gain parameter Summary
Band (GHz)
2.1
2.3
2.5
2.7
2.9
3.1
3.3
3.5
3.7
3.9
4.1
4.3
Peak Gain (dBi)
1.2
1.9
2.1
2.5
2.6
3.2
2.1
1.3
1.5
1.2
1.5
2.6
Measured S11
S11 (dB)
4.32
2.1
-10
-15
-20
-25
-30
-35
1
2
3
4
5
Frequency (GHz)
www.taoglas.com
Radiation Efficiency
Efficiency
90%
80%
70%
60%
50%
40%
30%
20%
10%
0%
1000
(MHz)
1500
2000
2500
3000
3500
4000
4500
5000
www.taoglas.com
Radiation Pattern
www.taoglas.com
4.0 Drawings
4.1 Shape and Dimensions
Antenna only
on 31x33mm Ground plane
www.taoglas.com
5.0
Sensitivity to Ground plane Dimensions (Simulation)
5.1
Ground plane Width W
5.2
Ground plane Length, L
www.taoglas.com
5.3 Handset Ground plane, 45mm × 110mm
W
L
www.taoglas.com
5.3.1 Sweeping length L, (W=45mm)
5.3.2 Sweeping width W (L=110mm)
www.taoglas.com
很抱歉,暂时无法提供与“FXP100.07.0100A”相匹配的价格&库存,您可以联系我们找货
