PRODUCT: Single Band WLAN Antenna
Part No. 1002295
PresttaTM WLAN with through hole
features — Embedded Antenna
2.4 GHz (802.11 b/g/n)
KEY BENEFITS
DESIGN ADVANTAGES
Ethertronics’ Prestta series of Isolated Magnetic
Dipole™ (IMD) stamped metal antennas address the
challenges facing today’s product designers. IMD’s
high performance and isolation characteristics offer
better connectivity and minimal interference.
IMD antennas can be used in a variety of devices:
Access Points, Gateways, Routers
Industrial Handhelds
WiFi enabled Televisions & Monitors
STB
M2M
TECHNOLOGY ADVANTAGES
Stays in Tune
IMD antenna technology
provides superior RF field
containment, resulting in
less interaction with
surrounding components.
Ethertronics IMD antennas
resist
de-tuning;
providing a robust radio
link regardless of the
usage position.
Prestta WLAN antennas use patented IMD technology
in a stamped metal configuration to provide high
performance. IMD antennas requires a smaller design
keep-out area, carry lower program development risk
which yields a quicker time-to-market, without
sacrificing RF performance.
Quicker Time-to-Market
By optimizing antenna size, performance and
emissions, customer and regulatory specifications are
more easily met.
Greater Flexibility
Ethertronics’ first-in-class IMD technology enables you
to develop concept designs that are more advanced
and that deliver superior performance in reception
critical applications.
RoHS Compliant
Ethertronics’ antennas are fully compliant with the
European RoHS Directive 2011/65/EU.
END USER ADVANTAGES
Unique Form Factors Support Advanced
Industrial Designs
Smaller, more efficient IMD embedded antennas break
through restrictive design rules and provide new
freedom in component placement.
Superior Range & Signal Strength
Better antenna function means longer range and
greater sensitivity to critically precise signals—
delivering greater customer satisfaction while building
brand loyalty.
SERVICE AND SUPPORT
Extensive RF Experience
Our WLAN antennas are supported by documentation,
and when needed, by the expertise of RF engineers
who have integrated hundreds of antenna designs into
wireless devices.
Global Operations & Design Support
Ethertronics’ global operations supports an integrated
network of design centers that can take projects from
concept to production.
ETHERTRONICS
5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com
Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com
PRODUCT: Embedded Dual Band antenna WLAN b/g/n - 1002295
Ethertronics’ Internal (Embedded) Antenna Specifications.
Below are the typical specs.
Electrical Specifications
Typical Characteristics on
120x180mm PCB
2.400 - 2.485 GHz
Peak Gain
Average Efficiency
Return Loss
Feed Point Impedance
Mechanical Specifications
120x180mm PCB
Dimensions
Weight
Packaging
2.95 dBi
70%
≤ -10dB
50 Ω unbalanced
15.60 x 16.10 x 9.70 mm (thickness 0.5mm)
0.75g
Delivered in Trays.
Return Loss in the 2.4GHz band
Efficiency in the 2.4GHz band in %
ETHERTRONICS
Radiation Patterns Set-Up
Typical Characteristics on 120x180mm PCB
Radiation Patterns at 2.44 GHz band
ETHERTRONICS
Below are the typical dimensions and footprint.
Main Dimensions (in mm)
PCB Slot for throughhole Mounting.
TOP VIEW
BOTTOM VIEW
*Dimensions and Tolerances on data sheet are for reference only.
3D View of Antenna on PCB
Clearance Needed around the
Feed pad only.
Au plated Pads for GND
connection.
Au plated Feed Pad
Based upon Final PCB stackup, a 50 Ohms line needs to
be designed and connected at
this location.
© 2016 Ethertronics. All rights reserved. Ethertronics, the Ethertronics logo, shaping antenna technology, Prestta, Isolated Magnetic Dipoleand the
iMD logo are trademarks of Ethertronics. All other trademarks are the property of their respective owners.
Specifications subject to change and are dependent upon actual implementation.
1002295 02Feb2016
很抱歉,暂时无法提供与“1002295”相匹配的价格&库存,您可以联系我们找货
