IEEE 802.11 Antennas
Model Name
ANT-WD-A-RF-0305 ANT-WS-AB-RM-05-180 ANT-WS-AB-RM-05-200
Frequency Range
ANT-WS-A-NF-09
ANT-WS-A-NF-09-150
2.4/5 GHz
2.4 GHz
2.4 GHz
2.4~2.5 GHz
2.4~2.5 GHz
Omni-directional
Omni-directional
Omni-directional
Omni-directional
Omni-directional
Typical Antenna Gain
3/5 dBi
5 dBi
5 dBi
9 dBi
9 dBi
Impedance
50 Ohm
50 Ohm
50 Ohm
50±5 Ohm
50±5 Ohm
Polarization Linear
Vertical
Vertical
Vertical
Linear
Linear
RG-316
RG-174
RG-58/U
360°
360°
360°
360°
360°
10°
10°
≦2
≦2
≦2
1:1.3 Max
1:1.3 Max
15W max
15W max
RP-SMA(Male)
RP-SMA(Male)
RP-SMA(Male)
N-type(Female)
N-type(Female)
RP-SMA(Female) to
RP-SMA(Female) to
N-type(Male) to
RP-SMA(Male)
RP-SMA(Male)
-20~65°C
-20~65°C
-30~85°C
-20~60°C
-20~60°C
160mm length
236.4mm length
196.6mm length
420mm length
420mm length
with 180cm cable
with 200cm cable
166g
125g
Radiation
Cable Type
HPBW / Horizontal
HPBW / Vertical
V.S.W.R
Power Handling
Antenna Connector
Cable Connector
Operating Temperature
Antenna Profile
Weight
26g
RP-SMA(Male)
with 150cm cable
430g
520g
Ordering Information
ANT-WD-A-RF-0305
IEEE 802.11 a/b/g 2.4/5 GHz, Dual Band, omni-directional antenna, 3/5dBi, RP-SMA(F)
ANT-WS-AB-RM-05-180
IEEE 802.11 b/g 2.4 GHz, Single Band, omni-directional antenna, 5dBi, RP-SMA(M), with 180cm Cable, with Base
ANT-WS-AB-RM-05-200
IEEE 802.11 b/g 2.4 GHz, Single Band, omni-directional antenna, 5dBi, RP-SMA(M), with 200cm Cable, with Base
ANT-WS-A-NF-09
IEEE 802.11 b/g 2.4~2.5 GHz, Single Band, omni-directional antenna, 9dBi, N-type(F)
ANT-WS-A-NF-09-150
IEEE 802.11 b/g 2.4~2.5 GHz, Single Band, omni-directional antenna, 9dBi, N-type(F), with150 cm cable
Connector Types
N Type
(Male)
N Type
(Female)
RP-SMA Type
(Male)
RP-SMA Type
(Female)
SMA Type
(Male)
SMA Type
(Female)
Atop Technologies, Inc.
Technologies
TEL:+886-3-5508137
FAX:+886-3-5508131
sales@atop.com.tw
http://www.atop.com.tw
Design and specification are subjected to change without notice.
All product names referenced herein are registered trademarks of their respective companies.
CA_Antenna_E:v1-110830
ANT-WS-AB-RM-05-180 价格&库存
很抱歉,暂时无法提供与“ANT-WS-AB-RM-05-180”相匹配的价格&库存,您可以联系我们找货
