SPECIFICATION
Part No.
MA252.A.LB.001
Product Name
Sentinel Adhesive Mount 2in1 GNSS & LTE Antenna
Ideal for IoT and Automotive Applications
Feature
Small Size, High Performance
1*LTE (4G/3G/2G) Antenna
1*GPS-GLONASS-GALILEO-BeiDou Active Antenna
IP67 Waterproof
High Efficiency
Low Profile Housing – Only 14mm in Height
2M CFD-200 and RG-174 Cables
SMA(M) Connectors
Dims: 139*76*14mm
RoHS Compliant
SPE-16-8-068/A/WY
Page 1 of 38
1.
Introduction
The MA252 Sentinel 2in1 LTE and GPS/GLONASS/GALILEO/BeiDou L1 Antenna is an
omnidirectional, fully IP67 waterproof external M2M antenna for use in telematics,
transportation and remote monitoring applications worldwide. It is designed to be
mounted directly on glass or plastic in the interior of vehicles.
It is the smallest high performance solution in the market, 50% smaller than the
previous generation, with higher efficiency and wider bandwidth to cover emerging
LTE bands. Its performance is comparable with much larger permanent roof mount
antennas and now offers a convenient and economical alternative in-cabin mounting
solution.
Typical applications include;
HD video over LTE
First Responder and Emergency Services
Automotive vehicle tracking
Telematics
It is mounted via high quality, first tier automotive approved, 3M adhesive.
In-house world leading dielectric ceramic antenna technology inside allows for smaller
size antennas without loss in efficiency. It delivers powerful performance for
worldwide 4G LTE bands at 700MHz/800MHz/1700MHz/1800MHz/2600MHz, plus
GPS-GLONASS-GALILEO-BeiDou for next generation location accuracy.
4G wireless applications demand high speed data uplink and downlink. High efficiency
is necessary to achieve the required signal to noise ratio and throughput required to
solve these challenges. Taoglas also takes care to have high isolation between the
two MIMO antennas to prevent self-interference. Low loss cables are used to keep
efficiency high over long cable lengths.
SPE-16-8-068/A/WY
Page 2 of 38
The IP67 waterproof housing measures just 139*76*14mm with 3M foam adhesive.
The antenna can be mounted internally or externally on a vehicle. The LTE coaxial
cable is 2m low loss CFD-200 with SMA(M) connectors. The GPS-GLONASS-GALILEOBeiDou cable is RG-174 with SMA(M) connector.
Customized cable and connector versions are also available. The antenna also comes
in a 3in1 2*LTE MIMO and GNSS or a single LTE only variant. Contact your regional
Taoglas sales office for support.
SPE-16-8-068/A/WY
Page 3 of 38
2.
Specification Table
4G/3G/2G Antenna
Frequency (MHz)
In free
space
On 2mm
ABS
base
On glass
base
LTE700
LTE800
GSM850
698~803
703~803
824~894
GSM900
DCS
1710~18
880~960
80
Efficiency (%)
60.75
66.44
58.01
60.59
PCS
1850~19
90
UMTS1
1920~21
70
LTE2300
2305
~2360
LTE2600
2490~26
90
76.05
69.53
66.91
61.59
56.87
51.86
30cm
1M
41.77
39.89
58.99
56.33
2M
37.22
52.23
52.91
54.49
61.97
54.72
44.70
3M
34.74
48.42
49.06
48.24
54.54
47.85
37.97
5M
29.75
40.81
41.20
37.70
42.12
37.06
29.04
30cm
41.14
54.04
57.58
66.82
76.00
66.82
55.38
1M
39.29
51.61
54.99
60.94
69.48
61.51
50.51
2M
36.67
47.83
50.15
54.81
61.93
54.64
43.54
3M
34.22
44.34
46.52
48.52
54.49
47.79
36.98
5M
29.32
37.37
39.06
37.92
42.08
37.01
28.29
30cm
43.33
55.50
58.33
63.40
63.83
55.87
56.49
1M
41.38
53.00
55.71
57.82
58.35
51.42
51.52
2M
38.62
49.13
50.81
52.03
52.01
45.69
44.42
3M
36.04
45.54
47.12
46.04
45.77
39.95
37.74
5M
30.91
38.38
39.57
36.00
35.35
30.95
28.86
30cm
-3.87
-2.29
-2.17
-1.81
-1.19
-1.81
-2.48
1M
-4.07
-2.49
-2.37
-2.21
-1.58
-2.17
-2.88
2M
-4.37
-2.82
-2.77
-2.66
-2.08
-2.68
-3.53
3M
-4.67
-3.15
-3.10
-3.20
-2.63
-3.27
-4.23
5M
-5.34
-3.89
-3.85
-4.26
-3.76
-4.37
-5.40
30cm
-3.89
-2.68
-2.41
-1.78
-1.19
-1.83
-2.60
1M
-4.09
-2.88
-2.61
-2.18
-1.58
-2.18
-3.00
2M
-4.39
-3.21
-3.01
-2.64
-2.08
-2.70
-3.64
3M
-4.69
-3.54
-3.33
-3.17
-2.64
-3.28
-4.35
5M
-5.36
-4.28
-4.09
-4.24
-3.76
-4.39
-5.51
30cm
-3.65
-2.56
-2.34
-1.99
-1.95
-2.60
-2.50
1M
-3.85
-2.76
-2.54
-2.39
-2.34
-2.95
-2.90
2M
-4.15
-3.09
-2.94
-2.84
-2.84
-3.47
-3.54
3M
-4.45
-3.42
-3.27
-3.38
-3.40
-4.05
-4.25
5M
-5.12
-4.16
-4.03
-4.44
-4.52
-5.16
-5.41
Average Gain (dBi)
In free
space
On 2mm
ABS
base
On glass
base
SPE-16-8-068/A/WY
Page 4 of 38
LTE3500
3400
~3600
4G/3G/2G Antenna
LTE700
LTE800
GSM850
Frequency (MHz)
698
~803
703
~803
824
~894
880
1710
~960
~1880
Peak Gain (dBi)
30cm
1.22
1.89
2.73
1M
1.02
1.69
2.53
2M
0.72
1.29
3M
0.42
0.99
In free
space
On 2mm
ABS base
On glass
base
GSM900
DCS
PCS
UMTS1
LTE2300
LTE2600
LTE3500
1850
~1990
1920
~2170
2305
~2360
2490
~2690
3400
~3600
4.69
4.69
4.27
4.15
4.29
4.29
3.87
3.75
2.13
3.79
3.79
3.37
3.05
1.73
3.29
3.29
2.87
2.35
5M
-0.28
0.19
1.03
2.19
2.19
1.67
1.15
30cm
0.76
1.57
1.79
3.68
3.68
3.22
3.24
1M
0.56
1.37
1.59
3.28
3.28
2.86
2.84
2M
0.26
0.97
1.19
2.78
2.78
2.36
2.14
3M
-0.04
0.67
0.89
2.28
2.28
1.82
1.44
5M
-0.74
-0.13
0.09
1.18
1.18
0.66
0.24
30cm
1.86
1.94
2.06
3.10
2.90
2.90
3.66
1M
1.66
1.74
1.86
2.70
2.50
2.50
3.26
2M
1.36
1.44
1.46
2.30
2.00
2.00
2.56
3M
1.06
1.14
1.06
1.70
1.40
1.40
1.86
0.46
0.34
0.36
0.70
0.30
0.30
0.75
5M
Impedance
Polarization
Return Loss
Input Power
Center Frequency
Passive Antenna Efficiency
(without cable loss)
Passive Antenna Average
gain(without cable loss)
Passive Antenna Peak
VSWR
Impedance
Axial Ratio
Polarization
50Ω
Linear
< -6dB
5W
BeiDou: 1561.098±2.046MHz
GPS/GALILEO: 1575.42±1.023MHz
GLONASS: 1602±5MHz
BeiDou: 62.2%
GPS/GALILEO: 65.86%
GLONASS: 75.07%
BeiDou: -2.03
GPS/GALILEO: -1.81
GLONASS: -1.25
BeiDou:1.7
GPS/GALILEO:3.03
GLONASS:4.22
< 3:1
50Ω
BeiDou: 8.97
GPS/GALILEO: 12.48
GLONASS: 20.6
RHCP
SPE-16-8-068/A/WY
Page 5 of 38
Center Frequency
Output Impedance
LNA and Filter Electrical Properties
GLONASS: 1602±5MHz
50Ω
VSWR
< 2:1
Return Loss
< -10dB
LNA Gain, Current Draw,
and Noise Figure
@GPS/GALILEO
Voltage
LNA
Gain(Typ)
Current
Draw (Typ)
Noise
Figure(Typ)
Min 1.8V
25.34
5mA
2.30
Typ 3.0V
28.63
10mA
2.69
Max 5.5V
32.79
23mA
2.98
Total specification(Through Antenna, SAW Filter, and LNA)
Frequency
Gain@3V(dB)
Output Impedance
Antenna Dimensions
Housing
Waterproof
Connector
Cable type
Cable length
Weight
Operation Temperature
Storage Temperature
Humidity
1561.098±2.046 MHz
28.06
1575.42±1.023 MHz
1602±5 MHz
28.63
27.84
50Ω
MECHANICAL
139.27*76.27*14mm
ABS
IP67
SMA(M) ST
LTE : CFD-200
GPS/GLONASS/GALILEO/BeiDou : RG-174
2000mm
280g
ENVIRONMENTAL
-40°C to 85°C
-40°C to 85°C
Non-condensing 65°C 95% RH
SPE-16-8-068/A/WY
Page 6 of 38
3.
Antenna Characteristics
3.1. LTE Characteristics
Test Setup
In free space
On 2mm ABS
On glass
SPE-16-8-068/A/WY
Page 7 of 38
Return Loss
Efficiency
SPE-16-8-068/A/WY
Page 8 of 38
Average Gain
Peak Gain
SPE-16-8-068/A/WY
Page 9 of 38
3.2. GPS/GLONASS/BeiDou Characteristics
Return Loss
Smith Chart
SPE-16-8-068/A/WY
Page 10 of 38
Efficiency
Average Gain
SPE-16-8-068/A/WY
Page 11 of 38
Peak Gain
Axial Ratio
3.2.6.1.
BeiDou
SPE-16-8-068/A/WY
Page 12 of 38
3.2.6.2. GPS/GALILEO
3.2.6.3. GLONASS
SPE-16-8-068/A/WY
Page 13 of 38
LNA Gain and Noise Figure
LNA Gain @3.0V
LNA Noise Figure @3.0V
SPE-16-8-068/A/WY
Page 14 of 38
3.3. 2D Radiation Pattern
Test Setup
Y
Y
X
X
Z
Z
In free space
On 2mm ABS
Y
X
Z
On the glass base
SPE-16-8-068/A/WY
Page 15 of 38
LTE with 2M cable length in free space
XY Plane
X
Y
SPE-16-8-068/A/WY
Page 16 of 38
XZ Plane
Z
X
SPE-16-8-068/A/WY
Page 17 of 38
YZ Plane
Z
Y
SPE-16-8-068/A/WY
Page 18 of 38
LTE with 2M cable length on the 2mm ABS
XY Plane
X
Y
SPE-16-8-068/A/WY
Page 19 of 38
XZ Plane
Z
X
SPE-16-8-068/A/WY
Page 20 of 38
YZ Plane
Z
Y
SPE-16-8-068/A/WY
Page 21 of 38
LTE with 2M cable length on the glass
XY Plane
X
Y
SPE-16-8-068/A/WY
Page 22 of 38
XZ Plane
Z
X
SPE-16-8-068/A/WY
Page 23 of 38
YZ Plane
Z
Y
SPE-16-8-068/A/WY
Page 24 of 38
XY Plane
X
Y
XZ Plane
YZ Plane
SPE-16-8-068/A/WY
Page 25 of 38
3.4. 3D Radiation Pattern
704MHz
960MHz
1710MHz
2170MHz
2690MHz
SPE-16-8-068/A/WY
Page 26 of 38
704MHz
960MHz
1710MHz
2170MHz
2690MHz
SPE-16-8-068/A/WY
Page 27 of 38
704MHz
960MHz
1710MHz
2170MHz
2690MHz
SPE-16-8-068/A/WY
Page 28 of 38
1561MHz
1575.42MHz
1602MHz
SPE-16-8-068/A/WY
Page 29 of 38
4.
Drawing
SPE-16-8-068/A/WY
Page 30 of 38
5.
Packaging
SPE-16-8-068/A/WY
Page 31 of 38
6.
Application Note
Taoglas provides antennas with different cable lengths and various base mounting
options to indicate its performance to act as a reference for a customer’s design.
In Free Space
LTE
Return Loss
SPE-16-8-068/A/WY
Page 32 of 38
Efficiency
Average Gain
SPE-16-8-068/A/WY
Page 33 of 38
Peak Gain
On 2mm ABS
LTE
Return Loss
SPE-16-8-068/A/WY
Page 34 of 38
Efficiency
Average Gain
SPE-16-8-068/A/WY
Page 35 of 38
Peak Gain
On glass base
LTE
Return Loss
SPE-16-8-068/A/WY
Page 36 of 38
Efficiency
Average Gain
SPE-16-8-068/A/WY
Page 37 of 38
Peak Gain
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document
and reserves the right to make changes to specifications and product descriptions at any time without
notice.
Taoglas reserves the rights to this document and the information contained herein. Reproduction, use or
disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-16-8-068/A/WY
Page 38 of 38
很抱歉,暂时无法提供与“MA252.A.LB.001”相匹配的价格&库存,您可以联系我们找货
