SPECIFICATION
Part No.
MA251.A.BI.001
Product Name
Sentinel Adhesive Mount 2*LTE MIMO Antenna
Ideal for IoT / M2M / Automotive Applications
Feature
Smallest High Performance MIMO
2 x LTE MIMO 1&2 Antennas
4G Allowing Fallback to 3G & 2G
IP67 Waterproof
High Efficiency
Low Profile Housing – Only 14mm in Height
2M CFD-200 and RG-174 Cables
SMA(M) Connectors
Dims: 139*76*14mm
RoHS Compliant
SPE-16-8-067/A/WY
Page 1 of 54
1.
Introduction
The MA251 Sentinel 2in1 adhesive mount 4G 2*LTE MIMO antenna is an
omnidirectional, fully IP67 waterproof external M2M antenna for use in telematics,
transportation and remote monitoring applications worldwide. It is designed to be
mounted directly on glass or plastic in the interior of vehicles.
It is the smallest high performance solution in the market, 50% smaller than the
previous generation, with higher efficiency and wider bandwidth to cover emerging
LTE bands. Its performance is comparable with much larger permanent roof mount
antennas and now offers a convenient and economical alternative in-cabin mounting
solution.
Typical applications include;
HD video over LTE
First Responder and Emergency Services
Automotive vehicle tracking
Telematics
It is mounted via high quality, first tier automotive approved, 3M adhesive.
In-house world leading dielectric ceramic antenna technology inside allows for smaller
size antennas without loss in efficiency. It delivers powerful 2*2 MIMO antenna
technology for worldwide 4G LTE bands at 700MHz/ 800MHz/ 1700MHz/ 1800MHz
/2300MHz /2600MHz, while allowing fallback to all common worldwide 3G and 2G
frequency bands.
4G wireless applications demand high speed data uplink and downlink. High efficiency
and high gain MIMO antennas are necessary to achieve the required signal to noise
ratio and throughput required to solve these challenges. Taoglas also takes care to
have high isolation between the two MIMO antennas to prevent self-interference. Low
loss cables are used to keep efficiency high over long cable lengths.
SPE-16-8-067/A/WY
Page 2 of 54
The IP67 waterproof housing measures just 139*76*14mm with 3M foam adhesive.
The antenna can be mounted internally or externally on a vehicle. Both MIMO 1 and
MIMO 2 coaxial cables are 2m low loss CFD-200 with SMA(M) connectors.
Customized cable and connector versions are also available. The antenna also comes
in a 2in1 LTE/GNSS or a single LTE only variant. Contact your regional Taoglas sales
office for support.
SPE-16-8-067/A/WY
Page 3 of 54
2.
Specification Table
4G/3G/2G MIMO 1 Antenna
Frequency (MHz)
In free space
On 2mm ABS
base
On the glass
base
In free space
On the 2mm
ABS base
On the glass
base
In free space
On the 2mm
ABS base
On glass base
LTE700
GSM850
GSM900
698~803
824~894
880~960
1710~1880
Efficiency (%)
DCS
PCS
UMTS1
LTE2600
1850~1990
1920~2170
2490~2690
30cm
1M
2M
41.77
39.89
37.22
58.99
56.33
52.23
60.75
58.01
52.91
66.44
60.59
54.49
76.05
69.53
61.97
66.91
61.59
54.72
56.87
51.86
44.70
3M
5M
30cm
34.74
29.75
41.14
48.42
40.81
54.04
49.06
41.20
57.58
48.24
37.70
66.82
54.54
42.12
76.00
47.85
37.06
66.82
37.97
29.04
55.38
1M
2M
39.29
36.67
51.61
47.83
54.99
50.15
60.94
54.81
69.48
61.93
61.51
54.64
50.51
43.54
3M
5M
30cm
34.22
29.32
43.33
44.34
37.37
55.50
46.52
39.06
58.33
48.52
37.92
63.40
54.49
42.08
63.83
47.79
37.01
55.87
36.98
28.29
56.49
1M
2M
3M
41.38
38.62
36.04
53.00
49.13
45.54
55.71
50.81
47.12
57.82
52.03
46.04
58.35
52.01
45.77
51.42
45.69
39.95
51.52
44.42
37.74
5M
30.91
38.38
39.57
36.00
Average Gain(dBi)
35.35
30.95
28.86
30cm
1M
2M
-3.87
-4.07
-4.37
-2.29
-2.49
-2.82
-2.17
-2.37
-2.77
-1.81
-2.21
-2.66
-1.19
-1.58
-2.08
-1.81
-2.17
-2.68
-2.48
-2.88
-3.53
3M
5M
30cm
-4.67
-5.34
-3.89
-3.15
-3.89
-2.68
-3.10
-3.85
-2.41
-3.20
-4.26
-1.78
-2.63
-3.76
-1.19
-3.27
-4.37
-1.83
-4.23
-5.40
-2.60
1M
2M
-4.09
-4.39
-2.88
-3.21
-2.61
-3.01
-2.18
-2.64
-1.58
-2.08
-2.18
-2.70
-3.00
-3.64
3M
5M
30cm
-4.69
-5.36
-3.65
-3.54
-4.28
-2.56
-3.33
-4.09
-2.34
-3.17
-4.24
-1.99
-2.64
-3.76
-1.95
-3.28
-4.39
-2.60
-4.35
-5.51
-2.50
1M
2M
3M
-3.85
-4.15
-4.45
-2.76
-3.09
-3.42
-2.54
-2.94
-3.27
-2.39
-2.84
-3.38
-2.34
-2.84
-3.40
-2.95
-3.47
-4.05
-2.90
-3.54
-4.25
5M
-5.12
-4.16
-4.03
-4.44
Peak Gain(dBi)
-4.52
-5.16
-5.41
30cm
1M
2M
1.22
1.02
0.72
1.89
1.69
1.29
2.73
2.53
2.13
4.69
4.29
3.79
4.69
4.29
3.79
4.27
3.87
3.37
4.15
3.75
3.05
3M
5M
0.42
-0.28
0.99
0.19
1.73
1.03
3.29
2.19
3.29
2.19
2.87
1.67
2.35
1.15
30cm
1M
2M
0.76
0.56
0.26
1.57
1.37
0.97
1.79
1.59
1.19
3.68
3.28
2.78
3.68
3.28
2.78
3.22
2.86
2.36
3.24
2.84
2.14
3M
5M
30cm
-0.04
-0.74
1.86
0.67
-0.13
1.94
0.89
0.09
2.06
2.28
1.18
3.10
2.28
1.18
2.90
1.82
0.66
2.90
1.44
0.24
3.66
1M
2M
1.66
1.36
1.74
1.44
1.86
1.46
2.70
2.30
2.50
2.00
2.50
2.00
3.26
2.56
3M
5M
1.06
0.46
1.14
0.34
1.06
0.36
1.70
0.70
1.40
0.30
1.40
0.30
1.86
0.75
SPE-16-8-067/A/WY
Page 4 of 54
4G/3G/2G MIMO 2 Antenna
Frequency (MHz)
LTE700
GSM850
GSM900
DCS
PCS
UMTS1
LTE2600
698~803
824~894
880~960
1710~1880
1850~1990
1920~2170
2490~2690
Efficiency (%)
In free space
30cm
1M
2M
3M
5M
30cm
On 2mm ABS
base
On glass base
1M
2M
3M
5M
30cm
1M
2M
3M
5M
46.24
44.16
33.45
31.95
35.37
33.78
54.05
49.29
57.08
52.17
51.87
47.71
67.48
61.55
41.21
38.46
29.61
27.44
30.81
28.56
44.42
39.27
46.50
40.93
42.38
37.07
53.09
45.10
33.09
50.50
48.23
23.13
40.14
38.33
24.00
42.93
41.00
30.73
53.67
48.95
31.59
56.84
51.96
28.70
53.32
49.05
34.48
66.89
61.01
45.01
42.01
35.53
32.93
37.39
34.66
44.10
39.00
46.31
40.76
43.57
38.10
52.61
44.68
36.10
48.41
46.24
27.75
37.93
36.22
29.12
39.94
38.14
30.51
54.71
49.90
31.46
61.77
56.48
29.51
61.21
56.36
34.17
66.66
60.79
43.15
40.27
34.63
33.57
31.11
26.22
34.78
32.25
27.09
44.97
39.76
31.11
50.34
44.28
34.18
50.04
43.76
33.90
52.42
44.51
34.04
Average Gain(dBi)
-3.54
-3.74
-4.77
-4.97
-4.51
-4.71
-2.69
-3.09
-2.46
-2.84
-2.89
-3.24
-1.71
-2.11
-4.04
-4.34
-5.30
-5.63
-5.11
-5.44
-3.55
-4.08
-3.34
-3.90
-3.76
-4.34
-2.75
-3.46
5M
30cm
1M
-5.01
-3.08
-3.28
-6.37
-3.98
-4.18
-6.20
-3.67
-3.87
-5.15
-2.72
-3.12
-5.02
-2.47
-2.86
-5.45
-2.76
-3.11
-4.63
-1.75
-2.15
2M
3M
-3.58
-3.88
-4.51
-4.83
-4.27
-4.60
-3.57
-4.11
-3.36
-3.91
-3.63
-4.21
-2.79
-3.50
5M
30cm
1M
-4.55
-3.31
-3.51
-5.58
-4.22
-4.42
-5.36
-3.99
-4.19
-5.17
-2.64
-3.04
-5.04
-2.11
-2.50
-5.32
-2.14
-2.50
-4.67
-1.77
-2.17
2M
3M
5M
-3.81
-4.11
-4.77
-4.75
-5.08
-5.82
-4.59
-4.92
-5.67
-3.49
-4.03
-5.09
-3.00
-3.55
-4.67
-3.02
-3.60
-4.71
-2.82
-3.52
-4.69
30cm
In free space
On 2mm ABS
base
On the glass
base
1M
2M
3M
Peak Gain(dBi)
In free space
On 2mm ABS
base
On glass base
30cm
1M
3.75
3.55
1.34
1.14
1.45
1.25
4.53
4.13
3.17
2.77
3.32
2.92
4.17
3.77
2M
3M
5M
3.25
2.95
2.35
0.74
0.44
-0.31
0.85
0.54
-0.25
3.73
3.23
2.13
2.27
1.77
1.77
2.42
1.82
0.72
3.07
2.37
1.17
30cm
1M
2M
3.78
3.58
3.28
2.32
2.12
1.74
2.39
2.19
1.79
3.45
3.05
2.55
4.37
3.97
3.47
4.37
3.97
3.47
5.63
5.23
4.53
3M
5M
2.98
2.38
1.42
0.72
1.49
0.72
2.05
0.95
2.87
1.77
2.87
1.77
3.73
2.63
30cm
1M
2M
3.35
3.15
2.85
1.54
1.34
1.03
2.10
1.90
1.50
3.15
2.75
2.35
3.86
3.46
2.96
3.86
3.46
2.96
3.75
3.35
2.71
3M
2.55
0.64
1.10
1.85
2.36
2.36
2.01
5M
1.95
0.64
0.40
0.75
1.26
1.26
0.91
SPE-16-8-067/A/WY
Page 5 of 54
Envelope Correlation Coefficient
Impedance
Polarization
Return Loss
Input Power
All Bands < 0.3
50Ω
Linear
< -6dB
5W
MECHANICAL
Antenna Dimensions
139.27*76.27*14mm
Housing
ABS
Waterproof
IP67
Connector
SMA(M) ST
Cable type
LTE: CFD-200
Cable length
2000mm
Weight
235g
ENVIRONMENTAL
Operation Temperature
-40°C to 85°C
Storage Temperature
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
SPE-16-8-067/A/WY
Page 6 of 54
3.
Antenna Characteristics
3.1. LTE Characteristics
Test Setup
In free space
On 2mm ABS
On glass
SPE-16-8-067/A/WY
Page 7 of 54
Return loss (MIMO 1)
Return loss (MIMO 2)
SPE-16-8-067/A/WY
Page 8 of 54
Isolation
Efficiency (MIMO 1)
SPE-16-8-067/A/WY
Page 9 of 54
Efficiency (MIMO 2)
Average Gain (MIMO 1)
SPE-16-8-067/A/WY
Page 10 of 54
Average Gain (MIMO 2)
Peak Gain (MIMO 1)
SPE-16-8-067/A/WY
Page 11 of 54
Peak Gain (MIMO 2)
Envelope Correlation Coefficient (ECC)
SPE-16-8-067/A/WY
Page 12 of 54
3.2. 2D Radiation Pattern
Test Setup
X
X
Y
Y
Z
Z
In free space
On 2mm ABS
X
Y
Z
On glass base
SPE-16-8-067/A/WY
Page 13 of 54
LTE with 2M cable length in free space (MIMO 1)
XY Plane
SPE-16-8-067/A/WY
Page 14 of 54
XZ Plane
SPE-16-8-067/A/WY
Page 15 of 54
YZ Plane
SPE-16-8-067/A/WY
Page 16 of 54
LTE with 2M cable length in free space (MIMO 2)
XY Plane
SPE-16-8-067/A/WY
Page 17 of 54
XZ Plane
SPE-16-8-067/A/WY
Page 18 of 54
YZ Plane
SPE-16-8-067/A/WY
Page 19 of 54
LTE with 2M cable length on the 2mm ABS (MIMO 1)
XY Plane
SPE-16-8-067/A/WY
Page 20 of 54
XZ Plane
SPE-16-8-067/A/WY
Page 21 of 54
YZ Plane
SPE-16-8-067/A/WY
Page 22 of 54
LTE with 2M cable length on the 2mm ABS (MIMO 2)
XY Plane
SPE-16-8-067/A/WY
Page 23 of 54
XZ Plane
SPE-16-8-067/A/WY
Page 24 of 54
YZ Plane
SPE-16-8-067/A/WY
Page 25 of 54
LTE with 2M cable length on the glass (MIMO 1)
XY Plane
SPE-16-8-067/A/WY
Page 26 of 54
XZ Plane
SPE-16-8-067/A/WY
Page 27 of 54
YZ Plane
SPE-16-8-067/A/WY
Page 28 of 54
LTE with 2M cable length on the glass (MIMO 2)
XY Plane
SPE-16-8-067/A/WY
Page 29 of 54
XZ Plane
SPE-16-8-067/A/WY
Page 30 of 54
YZ Plane
SPE-16-8-067/A/WY
Page 31 of 54
3.3. 3D Radiation Pattern
704MHz
960MHz
1710MHz
2170MHz
2690MHz
SPE-16-8-067/A/WY
Page 32 of 54
704MHz
960MHz
1710MHz
2170MHz
2690MHz
SPE-16-8-067/A/WY
Page 33 of 54
704MHz
960MHz
1710MHz
2170MHz
2690MHz
SPE-16-8-067/A/WY
Page 34 of 54
704MHz
960MHz
1710MHz
2170MHz
2690MHz
SPE-16-8-067/A/WY
Page 35 of 54
704MHz
960MHz
1710MHz
2170MHz
2690MHz
SPE-16-8-067/A/WY
Page 36 of 54
704MHz
960MHz
1710MHz
2170MHz
2690MHz
SPE-16-8-067/A/WY
Page 37 of 54
4.
Drawing
SPE-16-8-067/A/WY
Page 38 of 54
5.
Packaging
SPE-16-8-067/A/WY
Page 39 of 54
6.
Application Note
The antenna is tested with different cable lengths and various base mounting options
to indicate its performance to act as a reference for a customer’s design.
In Free Space
LTE MIMO 1
Return Loss
SPE-16-8-067/A/WY
Page 40 of 54
Efficiency
Average Gain
SPE-16-8-067/A/WY
Page 41 of 54
Peak Gain
LTE MIMO 2
Return Loss
SPE-16-8-067/A/WY
Page 42 of 54
Efficiency
Average Gain
SPE-16-8-067/A/WY
Page 43 of 54
Peak Gain
Isolation of MIMO 1 and MIMO 2
SPE-16-8-067/A/WY
Page 44 of 54
On 2mm ABS
LTE MIMO 1
Return Loss
Efficiency
SPE-16-8-067/A/WY
Page 45 of 54
Average Gain
Peak Gain
SPE-16-8-067/A/WY
Page 46 of 54
LTE MIMO 2
Return Loss
Efficiency
SPE-16-8-067/A/WY
Page 47 of 54
Average Gain
Peak Gain
SPE-16-8-067/A/WY
Page 48 of 54
On glass base
LTE MIMO 1
Return Loss
SPE-16-8-067/A/WY
Page 49 of 54
Efficiency
Average Gain
SPE-16-8-067/A/WY
Page 50 of 54
Peak Gain
LTE MIMO 2
Return Loss
SPE-16-8-067/A/WY
Page 51 of 54
Efficiency
Average Gain
SPE-16-8-067/A/WY
Page 52 of 54
Peak Gain
SPE-16-8-067/A/WY
Page 53 of 54
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document
and reserves the right to make changes to specifications and product descriptions at any time without
notice.
Taoglas reserves the rights to this document and the information contained herein. Reproduction, use
or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-16-8-067/A/WY
Page 54 of 54
很抱歉,暂时无法提供与“MA251.A.BI.001”相匹配的价格&库存,您可以联系我们找货
