SPECIFICATION
Part No. :
MA650.ST.AB.002.dz
Product Name :
Spartan ST Antenna 2in1 MA650
Low Profile Screw-Mount (Permanent Mount)
3G/2G/GPS-GLONASS-GALILEO combination
antenna
Feature :
1 x 3G/1G Antenna (824~960MHz,
1710~2170MHz)
0.3m NFC200 Coaxial Cable
Fakra Jack Connector Code D Violet
● 1 x GPS/GLONASS/GALILEO 1575.42/1602MHz
Antenna
0.3m RG174 Coaxial Cable
Fakra Jack Connector Code C Blue
IP69K and IP67 Waterproof
High Efficiency / Peak Gain Outdoor Antenna
Advanced RF Design and Materials
Heavy Duty – Integrated Metal Base/ Ground-plane
Dims: 147.5mm: Height 35.6mm
Custom cables and connectors available
RoHS Compliant
SPE-15-8-043/A/WY Page 1 of 20
1. Introduction
The Spartan MA650.ST antenna is an omni-directional, heavy-duty, fully IP69K and IP67
waterproof external M2M antenna for use in telematics, transportation, and remote
monitoring applications.
This
unique
antenna
delivers
powerful
3G/2G
antenna
technology
and
GPS/GLONASS/GALILEO for next generation high bandwidth telematics navigation systems.
We have packed 2 high efficiency and gain antennas in an extremely robust IP69K direct
mount antenna package. The antenna has its own ground-plane and can radiate on any
mounting environment like metal or plastic without affecting performance. The cables are
low loss allowing for lengths of up to 5 meters (16 ‘ and 4.85 “), critical for buses, trains,
and other commercial transport applications.
For industries such as commercial vehicle telematics, remote monitoring, smart meter
systems, construction equipment, at only 40mm high, the Spartan provides an unobtrusive,
robust, rugged antenna that is durable even in extreme environments. This model is specific
designed for automotive market with Fakra Jack generation II connectors which provide
high connector reliability in vibrant usage application.
Customized cable length and connector versions are available upon request.
SPE-15-8-043/A/WY Page 2 of 20
2. Specification Table
3G/2G Antenna
Frequency (MHz)
Peak Gain (dBi)
Average Gain (dBi)
Efficiency (%)
824~894
880~960
1710~1880
1850~1990
1920~2170
30cm
0.65
0.16
4.05
4.05
3.64
1m
2.64
1.97
3.46
3.97
3.46
2m
1.60
1.24
3.32
3.26
2.73
3m
2.17
1.34
2.87
3.01
2.56
5m
-0.82
-1.34
1.57
2.22
1.72
30cm
-4.76
-5.43
-3.48
-2.45
-4.10
1m
-4.26
-5.78
-3.79
-2.86
-4.23
2m
-4.46
-6.35
-4.12
-3.38
-5.32
3m
-4.80
-5.97
-4.91
-3.61
-5.08
5m
-5.61
-6.56
-6.35
-4.34
-5.81
30cm
33.89
29.95
47.05
57.47
40.88
1m
38.06
27.70
43.75
52.18
38.82
2m
36.11
24.40
40.27
46.10
31.16
3m
33.56
23.25
34.56
43.83
32.12
5m
27.96
23.10
25.00
36.89
27.06
Return loss (dB)
< -5
Polarization
Linear
Impedance
50Ω
Cable
0.3m NFC200 standard, fully customizable
Connector
FAKRA, standard, fully customizable
Maximum Input Power
5W
SPE-15-8-043/A/WY Page 3 of 20
GPS-GLONASS-GALILEO
Center Frequency
GPS/GALILEO:1575.42±3 MHz
GLONASS:1602±0.5 MHz
Gain
3 ±1 dBic typ.
VSWR
1.5:1 Max
Impedance
50Ω
Cable
0.3m RG174 standard, fully customizable
Connector
FAKRA Connector, fully customizable
LNA Electrical Properties
Center Frequency
Impedance
VSWR
Return Loss
DC Power Input
50 Ohm
< 1.5:1
10 dB Min.
32 dB Min. @ 5.0V
28 dB Min. @ 3.3V
21 dB Min. @ 1.8V
1.8V~5.0V
Noise Figure @3.3V
1.6dB
Power Consumption
10mA @ 3.3V
Gain
MECHANICAL
Antenna Dimensions
147.5*145.6*35.6mm
Casing
Wonderloy PC-540 PC/ABS Alloy
Waterproof
IP69K and IP67
Thread
M20*1.5P
Weight
570g
Recommended Assembly Torque
29.4 N∙m
Maximum Assembly Torque
39.2 N∙m
ENVIRONMENTAL
Operation Temperature
-40°C to 85°C
Storage Temperature
-40°C to 90°C
Humidity
Non-condensing 65°C 95% RH
SPE-15-8-043/A/WY Page 4 of 20
3. Cellular Antenna Characteristics
3.1. Return Loss
3.2. Peak Gain
SPE-15-8-043/A/WY Page 5 of 20
3.3. Average Gain
3.4. Efficiency
SPE-15-8-043/A/WY Page 6 of 20
3.5. Radiation Patterns
SPE-15-8-043/A/WY Page 7 of 20
3.5.1. 2D Radiation Patterns
XY Plane
X
Y
X
Y
SPE-15-8-043/A/WY Page 8 of 20
XZ Plane
Z
X
Z
X
SPE-15-8-043/A/WY Page 9 of 20
3.5.2. 3D Radiation Patterns
@824MHz
@880MHz
@960MHz
@1710MHz
SPE-15-8-043/A/WY Page 10 of 20
@1880MHz
@1990MHz
@2170MHz
SPE-15-8-043/A/WY Page 11 of 20
4. GPS-GLONASS-GALILEO Antenna
Characteristics
4.1. Block diagram
4.2. Antenna Return Loss
SPE-15-8-043/A/WY Page 12 of 20
4.3. Smith Chart
4.4. 3D Efficiency Table (passive antenna)
Frequency
(MHz)
Return
Loss(dB)
Impedance(Ω)
Gain 0˚
Gain 0˚
H-Plane(dBic) E-Plane(dBic)
1575.42
-36.3
50.3 + j 1.4
3.34
3.77
1598
-25.8
51.5 + j 4.9
3.49
3.63
1602
-41.5
50.6 – j 0.5
3.23
3.35
1606
-25.3
48.8 – j 5.2
2.93
3.05
SPE-15-8-043/A/WY Page 13 of 20
4.5. LNA S-parameter
4.6. LNA Noise Figure
SPE-15-8-043/A/WY Page 14 of 20
4.7. Radiation Pattern
2D-radiation pattern Free Space @1575.42MHz
Red Line:H-plane ; Blue Line:E-plane
SPE-15-8-043/A/WY Page 15 of 20
2D-radiation pattern Free Space @1602MHz
SPE-15-8-043/A/WY Page 16 of 20
5. Drawing
SPE-15-8-043/A/WY Page 17 of 20
6. Installation
SPE-15-8-043/A/WY Page 18 of 20
7. Packaging
SPE-15-8-043/A/WY Page 19 of 20
SPE-15-8-043/A/WY Page 20 of 20
很抱歉,暂时无法提供与“MA650.ST.AB.002.DZ”相匹配的价格&库存,您可以联系我们找货
