SPECIFICATION
Part No.
MA741.B.BI.001
Product Name
Pantheon Antenna 2in1 MA.741
LTE Cellular 4G/3G 2*2 MIMO
Screw-Mount (Permanent Mount)
Feature
2 x LTE Cellular (2G/3G/4G) Antennas (MIMO)
Works for LTE/GSM/GPRS/CDMA/UMTS/HSPA
698~960MHz, 1710~2170MHz, 2300~2700MHz
IP67 Waterproof
High Efficiency / Peak Gain Outdoor Antenna
3M CFD-200 SMA(M)
RoHS Compliant
SPE-15-8-032/C/WY
Page 1 of 21
1. Introduction
The MA741 Pantheon LTE 4G MIMO 2*2 antenna is an omnidirectional, heavy-duty,
fully IP67 waterproof external M2M antenna for use in telematics, transportation, and
remote monitoring applications. It includes two LTE MIMO antennas with the highest
efficiency and peak gain possible. This is necessary for today's high speed data uplink
and downlink systems in applications such as real time video, for maximum
throughput and highest signal-to-noise ratio.
The antenna elements operate at all common 2G, 3G, and 4G LTE bands worldwide
698-960MHz, 1710-2170MHz, 2300~2700MHz.
The housing is an extremely robust IP67 direct mount antenna package with excellent
isolation (10dB+). The antenna has its own ground-plane and can radiate on any
mounting environment like metal or plastic without affecting performance. For cable
length requests above 5 metres contact Taoglas for advice about suitability for
application.
The connectors and cable length are customizable. The enclosure is also available in
White, MA741.W.B.BI.001.
SPE-15-8-032/C/WY
Page 2 of 21
2. Specification Table
2G/3G/4G MIMO1
XIII, 17
(NA)
XX (EU)
V (NA)
VIII (EU)
III (EU)
II (NA)
IV (NA)
I (EU)
VII (EU)
Peak Gain
698803
4.16
791862
2.47
824894
2.47
880960
2.58
17101880
1.54
18501990
2.31
17102155
2.31
19202170
2.24
25002690
3.01
Efficiency
62.41
58.02
61.74
58.56
55.45
63.19
59.89
63.93
56.19
Average Gain
-2.08
-2.39
-2.10
-2.34
-2.56
-2.00
-2.24
-1.95
-2.51
Frequency
Return Loss
很抱歉,暂时无法提供与“MA741.B.BI.001”相匹配的价格&库存,您可以联系我们找货
