DATASHEET
Part No. M830520
Product: 2.4/5GHz
Ceramic Antenna
Part No. M830520
WIFI SavviTM Ceramic Antennas
2.4GHz, 5GHz
Ethertronics’ Savvi series of Isolated Magnetic Dipole™ (IMD) antennas
deliver on the key needs of device designers for higher functionality and
performance in smaller/thinner designs. These innovative antennas provide
compelling advantages for a full WIFI dual band enabled handheld devices,
media players and other mobile devices.
Real-World Performance and Implementation
Ceramic antennas may look alike on the outside, but the important
difference is inside. Other antennas may contain simple PiFA or monopole
designs that interact with their surroundings, complicating layout
or changing performance with use position. Ethertronics’ antennas utilize
patented IMD technology to deliver a unique size and performance
combination.
WIFI
2.4 & 5 GHz
Greater Flexibility
Ethertronics’ first-in-class IMD technology enables you to develop concept
designs that are more advanced and that deliver superior performance in
reception critical applications.
KEY BENEFITS
Electrical Specifications
Typical Characteristics, on 40x80mm PCB
Stay-in-Tune
IMD antenna technology
provides superior RF field
containment, resulting in less
interaction with surrounding
components.
Quicker Time-to-Market
By optimizing antenna size,
performance and emissions,
customer and regulatory
specifications are more easily
met.
Reliability
Fully compliant with the
European RoHS Directive
2011/65/EU.
APPLICATIONS
Embedded design
Cellular, Headsets, Tablets
Gateway, Access Point
M2M, Industrial devices
Handheld
10/19/2016
WLAN a/b/g Frequency
Peak Gain
Average Efficiency
VSWR Match
Feed Point Impedance
Polarization
Power Handling
2.4 - 2.5 GHz (b,g)
4.9 - 5.8 GHz (a)
1.1 dBi
3.2 dBi
54%
69%
2.6:1 max
3.0:1 max
50 ohms unbalanced
Linear
0.5 Watt CW
Mechanical Specifications
Size
8.0x3.0x1.3mm
Mounting
Surface mount
Weight
Packaging
Demo Board
Proprietary and confidential.
0.2 g
Tape & Reel,
M830520 – 1,000 pieces per reel
M830520-4.5K – 4,500 pieces per reel
M830520-01
www.ethertronics.com
DATASHEET | Part No. M830520
2.4/5GHz Ethertronics’ SavviTM Embedded Antenna Specifications
Ethertronics produces a wide variety of standard and custom antennas to meet user needs.
Below are the typical performances.
Typical Return Loss and Efficiency Plots
Measured on 40x80mm demo board
Antenna Layout
For references only, tuning varies based on
application
2
M830520
*All dimensions provided in this document are for informational purposes only.
© 2016 Ethertronics Incorporated.
tel +(1) 858.550.3820 | fax +(1) 858.550.3821
email: info@ethertronics.com
5501 Oberlin Drive, Suite 100 San Diego, CA 92121 - USA
Antenna Radiation Patterns
Typical Performances on Ethertronics’ 40x80 PCB Test Board
Measured at 2.4 GHz
WLAN b,g
Measured at 5.1 GHz
WLAN a
很抱歉,暂时无法提供与“M830520-01”相匹配的价格&库存,您可以联系我们找货
