M830110-10K
M830110-10K
    ETHERTRONICS
    GPS ANTENNA 8X3X1.3MM
M830110-10K 数据手册
PRODUCT Data Sheet: GPS Part No. M830110 SavviTM Embedded Ceramic GPS Antenna 1.575 GHz KEY BENEFITS DESIGN ADVANTAGES Ethertronics’ Savvi series of Isolated Magnetic Dipole™ (IMD) antennas deliver on the key needs of device designers for higher functionality and performance in smaller/thinner designs. These innovative antennas provide compelling advantages for GPS enabled cell phones, navigation equipment, and other mobile devices. TECHNOLOGY ADVANTAGES Real-World Performance and Implementation Ceramic antennas may look alike on the outside, but the important difference is inside. Other antennas may contain simple PiFA or monopole designs that interact with their surroundings, complicating component layout or changing performance with use position. Ethertronics’ antennas utilize patented IMD technology to deliver a unique size and performance combination. Stays in Tune High RF isolation means IMD antennas resist detuning regardless of usage position. And one standardized part can typically be placed in a variety of locations. Smallest Effective Size IMD antennas require a smaller keep-out area for surrounding components, leading to a smaller effective size. High Performance IMD’s high efficiency and simple design rules lower development risk and speed time-to-market without sacrificing performance. Plus, high RF selectivity eliminates the cost and space for band-pass circuitry. More information is available on our Website at www.ethertronics.com/resources/. Best in Class Performance—Smallest Occupied Volume • Powerful combination of 78% peak efficiency and simple implementation guidelines. • Minimal ground clearance and component “keep out” area. Very low component height. • High selectivity eliminates the need for additional filters and frees up board space. High Tolerance to Frequency Shifts • IMD’s high RF isolation resists antenna de-tuning that can otherwise impair reception. • Single part works for various PCB sizes and layouts. Quicker Time-to-Market • Fewer design changes. • Simpler implementation—no matching networks. RoHS Compliant • Antennas comply with appropriate RoHS Directives. END USER ADVANTAGES Superior Range • Greater antenna efficiency means longer range and a better end user experience. Exceptional Coverage • Better coverage results in improved performance while inside buildings, cars or other areas where signal reflection occurs. Faster Acquisition Times • Users experience faster signal acquisition for GPS readings. SERVICE AND SUPPORT Extensive RF Experience • Our Savvi ceramic antennas are supported by extensive application notes, and when needed, by the expertise of RF engineers who have integrated hundreds of antenna designs into wireless devices. Global Operations & Design Support • Ethertronics’ global operations encompass an integrated network of design centers that provide local customer support. ETHERTRONICS 9605 Scranton Road, Suite 300 | San Diego, CA 92121 - USA | www.ethertronics.com tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: GPS Antenna Ethertronics’ SavviTM GPS Embedded Antenna Specifications Ethertronics produces a wide variety of standard and custom antennas to meet user needs. Below are the typical specs for a GPS application. Electrical Specifications Typical Characteristics (inside an enclosure) BT/GPS GPS Antenna Antenna 1.575 GHz Average Peak Gain Gain Average Average Efficiency Efficiency VSWR VSWR Match Match 75% 2.0:1 max 1.7:1 Feed Front Point to Impedance Back Ratio 50 ohms-6unbalanced dB Feed Point Power Impedance Handling 50 ohms .5 Watt unbalanced cw Power Polarization Handling Mechanical Specifications 1.78 -2.5 dBi .5 Linear Watt cw Size Mounting 8x3x1.3mm Surface mount Tape & Reel Packaging M830110: Minimum Order Quantity of 99,000 pcs. Order multiples of 4,500 pcs. M830110-1K: Minimum Order Quantity of 1,000 pcs. Order multiples of 1,000 pcs. Typical Efficiency, Return Loss Antenna Radiation Patterns Typical Performance Ethertronics’ Test Board PCB: 40x80mm The efficiency and return loss, indicated below, will shift about 12 MHz toward the GPS carrier frequency when antennas are placed in wireless devices. 1.575 GHz Band Phi = 0o Plane Phi = 90o Plane Theta = 90o Plane z (θ=0o) y (Φ=90o) x (Φ=0o) © 2011 Ethertronics. All rights reserved. Ethertronics, the Ethertronics logo, shaping antenna technology, Savvi, Isolated Magnetic Dipole and the iMD logo are trademarks of Ethertronics. All other trademarks are the property of their respective owners. Specifications subject to change and are dependent upon actual implementation. GPS 08/05/11
M830110-10K 价格&库存
很抱歉,暂时无法提供与“M830110-10K”相匹配的价格&库存,您可以联系我们找货
